Question about Rockwood AMP-295 Car Audio Amplifier
When connecting the exits of the horns a noise it is listened That should make?
  • 3 Answers
SOURCE: rockwood amp 5556 car audio amplifier no sound
Check an make sure your fuse is tight the one coming off the battery for your amp if that dosnt work try grounding your amp to the battery to make sure the ground is good
Posted on Nov 08, 2012
Rockwood amp 5556 car audio amplifier no sound
Nov 08, 2012 | Rockwood AMP-5554 Car Audio Amplifier
Can an explore 4020 amp be bridged?
Well if it's a multi channel amp it can definately be bridged. Yes, and from what I've read it is actually bridgeable at 2 ohms per 2 channels.
May 31, 2010 | Rockwood X-Plore AMP-4020 Car Audio...
I connected the hot wire of my stereo and ran it to the amp power and same thing as the ground and get NO power
you have to run a seperate power wire from ur battery 2 ur amp and the same 4 ur ground wire
Feb 27, 2010 | Rockwood X-Plore AMP-4030 Car Audio...
Rockwood 479X
i would recomend 8gage just to be safe
Oct 13, 2009 | Rockwood AMP-479 2 Channel Bridgeable...
I have a rockwood Amp-479X, need directions to install
Hello william_pric,
Look on the speaker output terminals to see if there is an indication, usually a line between the positive (+) on one to the negative (-) on the other, with the word "bridged". If the bridging terminals are not indicated, you can always try one of the positives and the other negative. If there's no sound, it must be the other two terminals. Just be careful that you don't short the terminals, and don't crank the volume up without the sub connected. Some amps don't like an infinite load.
For an input to the amp from a stock OEM radio, your best solution is to use a "line out converter", connected to the rear speaker wires. The PAC SNI-45T shown in the link is one such device. This one includes a "remote turn-on" lead for the amp. You could use a cheaper LOC and just run 12V from an accessory lead on the truck. In this case, the amp will turn on and stay on whenever the ignition switch is in the "on" or "accessories" position. If this is objectionable, mount a SPST switch somewhere convenient and wire the turn-on wire through it.
Hope this helps.
Apr 28, 2009 | Rockwood AMP-479 2 Channel Bridgeable...
Rca connection doesnt work in the amp
Hello jaylean07,
First, try another set of RCA's to see if the cable is bad. If the problem is still there, flip the channels to determine if it is the head unit or the amp. If it is the amp check the on-board fuses.
Hope this helps.
Apr 26, 2009 | Rockwood Chicago Car Audio Amplifier
Rockwood AMP-295 Car Audio Amplifier Logo
Top Rockwood Car Audio & Video Experts
Iron
Iron
bigdawg7299
matthew walsh
Level 1 Expert
Are you a Rockwood Car Audio and Video Expert? Answer questions, earn points and help others
