Question about Logitech MX1000 Laser Cordless (097855023933) Mouse
Changing Sensitivity I would like to assign the side buttons to change the sensitivity of the mouse (in FPS games). I don't see this option in the settings window of the mouse.
    Novelist:
    Champion:
  • 277 Answers
1. Open the SetPointTM software and assign a keystroke to the button you want to use. For further details about this procedure, launch the Help Center within SetPoint and view the mouse topic To change the task assigned to a button. 2. Click the Windows® Start button, locate the function or application you want to launch and right-click it to display a menu. (If the function or application you want to launch is not available from the Windows Start menu, use Windows Explorer to locate it and then right-click it.) 3. Select Properties. 4. In the Shortcut tab, enter a Shortcut key that is the same as the keystroke you chose at step 1. 5. Click OK.
Posted on Oct 09, 2005
How do you re-align a Wii remote?
To Adjust the Wii Remote Pointer Sensitivity, follow these steps..
Wii
  1. Access System Settings.
  2. Select "Sensor Bar."
  3. Select "Sensitivity."
  4. Aim the Wii Remote at the television.
  5. Use the + and - buttons on the Wii Remote to adjust sensitivity until only two blinking lights appear.
  6. Press the A button when done.
Wii U
  1. From the Wii U Menu, select "System Settings."
  2. Using the Left Stick, scroll to the "Wii Remote and Sensor Bar" icon and press the A Button.
  3. Select "Adjust Wii Remote Pointer Sensitivity."
  4. Tap "Next."
  5. Point the Wii Remote at the sensor bar and press the A Button.
  6. With the Wii Remote pointed at the sensor bar, press the - and + Buttons to adjust the sensitivity so that only two white dots are visible in the black window.
  7. When you are finished, press the A Button.
  8. On the Wii U GamePad screen tap "OK."
Please
Dec 14, 2017 | Nintendo Wii Console
Tip
How to change the mouse sensitivity
<p>Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.<br /> <p><br /> <p>Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.<br /> <p><br /> <p>Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."<br /> <p><br /> <p>Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.<br /> <p><br /> <p>Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.<br /> <p><br /> <p>Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.<br />
on Dec 07, 2010 | Computers & Internet
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
MY MOUSE KEEPS LEAVING THE SCREEN, AND GONE FOR 10 SECS..ITS A DELL LATTITUDE 600 NOTEBOOK-FIREFOX, XP
5
Feb 08, 2011 | Dell Lattitude D600 Notebook
I have a TOSHIBA NB100.The mouse pad is too sensitive .I can even move the cursor hovering my finger above it without touching the pad .I thinlk it causes words and letters to come out as a jumble. Is...
control panel----Mouse----Should bring you to a screen with several tabs at the top-----pointer options tab---Select a pointer speed this should slow down the mouse movement----then go to the first tab (touchpad) and you can change the touchpad sensitivity. Hope this helps
Jan 07, 2011 | Computers & Internet
Mouse sensitivity is slow.i want more then more speed of mouse pointer,i already search but nothing...pleas SIR
These are the steps to change the mouse sensitivity
Good luck
do rate the solution if got help
Dec 07, 2010 | HP P2360AA Keyboard/Mouse
My laptop is Hp TouchSmart tx2,the problm is :-The pointer moves unwnted icon it click by it self.
The problem is very simple. The sensitivity of the mouse pad is too high in your laptop i guess. Try adjusting the sensitivity of the mouse. Go to control panel-> mouse options->mouse sensitivity. Try changing the double clicking speed, mouse sensitivity etc and check your mouse operation now.
Aug 03, 2010 | HP Tablets & eReaders
My touchpad has lost sensitivity. How do I fix it?I have to use the right.left bars underneath once I make a selection.
It seems that the sensitivity for the touchpad has dipped. Hoping that you might be using Synaptic's touchpad.
See if this helps..
1.. Click Start then click Control Panel.
2.. Click Printers and Other Hardware then click Mouse.
3.. Select the Device Settings tab.
4.. Highlight Synaptics TouchPad in the list and click the Settings
button.
5.. Click the plus sign next to Sensitivity to change the sensitivity settings of the touchpad.
If you are not getting any positive result from changing the settings, you can uninstall and re-install the drivers for the same and then check it once again. If all fails, this leads to the result that the touchpad is itself damaged and you need to replace it.
Cheers!
Apr 04, 2010 | Computers & Internet
Asus A6000 entertainment-how can i slow down
This is not a computer problem, but rather a problem of the game setup.
Start your game and go to "setup" or "options" or something like that. One of the options will be related to "mouse speed" or "mouse sensitivity". Turn the speed or sensitivity down a couple of notches, save the new settings and try the game again.
Mar 16, 2010 | Computers & Internet
Slow mouse
Most games have an option to change the mouse sensitivity in the control options.
Oftentimes newer optical mice have a lower resolution that causes them to move very slowly in games.
Feb 25, 2008 | Acer (AST135-U-S3100) PC Desktop
Logitech MX1000 Laser Cordless (097855023933) Mouse Logo
100 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
