Question about Belkin (F5D5231-4) Router
Belkin F5D7320-4 (older model)
I recently tried reinstalling this router... I cannot get it to connect to the Internet... I have also connected an RJ45 to the router to try to connect to
192.168.2.1. It also doesn't work... (I do get a 'connected' indication on the
Network Connections screen (XP)...) When I try to log onto the router, IE just comes back with a 'cannot display the webpage' message... If I can't log onto the router, it pretty much makes it worthless to me... what do you
think? ....
Thanks in advance for any help you can provide... Mike
  • 4 Answers
Try assigning static ip on ur computer in the same range eg : 192.168.2.55 and default gateway : 192.168.2.1 then try to ping the default gateway and then try to login into the device if getting any reply
else try resetting the device and then try loggin into the router
Posted on Sep 11, 2008
Belkin N Modem Router F5D8636 Im having a problem with internet connection via this particular model. I get connected to the internet for about 2 hrs then it will be disconnected to the internet. However...
this is because, your ISP may refresh the ip address assigned to you for every 2 hrs.... usually belkin will understand the change of ip address and act accordingly...in you case it is not.... you can log in to router by typing 192.168.2.1 (login password: no password....leave blank and click submit...) clicking on restore factory defaults and reconfiguring the router will fix this issue... if it still didnot, then follow this link below and download the updated firmware for your router version (v1 or v2)....
http://tinyurl.com/33c37x4
once you updated the firmware, click on restore factory defaults and configure the router for your ISP....
Call 1800-2-belkin(235546) for technical assistance to configure your router...
Apr 26, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
Tip
How to fix the problem with Belkin Next generation Routers ?
How to fix the various issues with Belkin Basic, Surf, Share, Play, PlayMax Routers ?
  • Connect the DSL Modem to Router in the port named Modem (usually yellow in color) using an Ethernet cable.
  • Connect the Computer to the Router in one of the 4 ports named wired (usually grey in color) using another Ethernet cable.
  • Open internet explorer / Firefox or any of your default web browser.
  • In the address bar type the default gateway address of Belkin router 192.168.2.1
  • Belkin router setup page (RSP) will be displayed.
  • Login to the page. (password: leave it blank and click submit)
On the left side below the "utilities" select firmware update and check the current firmware version of your router.
In these updated firmwares all the problems related to various issues have been fixed.
download the latest firmware and update it.
After updating the firmware click on restore factory defaults found below the "utilities" and restore it.
then configure your router according to your internet service provider...
For Cable ISPs click here...
For embarq and centurylink ISPs click here...
For DSL & Satellite ISPs click here....
To configure the wireless part except for play & playmax click here...
on Jul 24, 2010 | Computers & Internet
I have recently bought a Belkin Wireless Router and I am unable to connect to the Internet on my laptop. What do I need to do to connect my laptop to the internet using the Belkin Wireless router?
your Internet modem or router needs to be connected to the Belkin router's WAN port with an ethernet cable. You'll then need to configure the belkin's wireless settings, it's usually a very easy "follow the prompts" kind of setup.
Oct 03, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin Wireless Router F5D8633-4 does not connect to the internet
Try first to connect to the internet using wired connection. If it connects, try to connect on wireless make sure the router is broadcasting signal.
Mar 16, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Unable to connect to internet
If you tell me the version number of your Belkin 'n'wireless router , i can fix this issue.Any Routers issue contactme,, i can help you out. copy and paste this address to Browse,Mentioned below http://techhobbies.blogspot.com/2009/03/solve-your-problem-for-free-free.html
Mar 04, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Wireless Router use with Wildblue Satelite Modem
You should be aware of a class action lawsuit that Belkin and the complaintent settled recently. The lawsuit was filed complaining that certain Belkin routers did not obtain optimal speeds as advertised.
Belkin has agreed to provide affected customers a discount program to purchase a new router. You will need to search elsewheres for the details.
Sep 28, 2008 | Belkin (F5D5231-4) Router
Main PC can't connect but others can!
I had this model of router quite some time ago. I had some bad experiences where when I tried to login to it I was unable to, the web based management interface would not respond (as you have described) . Resetting the device would resolve this I would recommend trying that. Unplug it, wait a few minuets and plug it back in. Then try again to access the management interface. 192.168.1.1 or 192.168.0.1 or whatever via a web browser.
Apr 30, 2008 | Belkin (F5D7633UK4A) Wireless Router
Router cant b found
Locate the reset button on the rear of the router.
Should be below the antenna and recessed use a paper clip or similar to hold in for 10 secs.
This will reset the router back to factory defaults.
Type in 192.168.2.1 into your browser and you should get the routers setup page. Click the login button, no password is required. You can set this up yourself once in the router setup.
Be aware this router is NOT on the Xbox live supported list.
Check link below for supported Live Routers.
http://www.xbox.com/en-US/support/connecttolive/xbox360/homenetworking/equipment.htm
If you have only bought thi recently get it swapped out if you cannot connect to live once reset.
Let me know how you get on.
Feb 26, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin (F5D5231-4) Router Logo
729 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
