1993 Volkswagen Jetta Logo
Posted on Feb 27, 2018
Fuel box licking
Please help me my 1993 jetta 2.0 cli have a problem of fuel box(the small fuel box next to fuel tank)licking I want to replace it but i cant find it anywhere. will u please tell me where can i buy it Im from kzn Durban. I checked all other jettas but only jetta 2.0 cli have a fuel box.
  • Anonymous Sep 19, 2008
    fuel box is leaking through hairline crack...Need a replacement, where too look??
timothy fiscus
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Feb 27, 2018
timothy fiscus
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
366
Points
13
Vent valve or vapor canister purge valve is what I believe your referring too. You dont need to replace the complete vapor canister, just the valve itself. the valve is connected to the canister with a small 2" long rubber hose.
5 Related Answers
Anonymous
  • 24 Answers
  • Posted on Jun 16, 2008
SOURCE: starting
Does it feel like its not starting from a fuel problem? I would look at the fuel filter for the 1st culprit.
Jean Leblanc
  • 151 Answers
  • Posted on Sep 05, 2008
SOURCE: fuel box
What is a fuel box? Why do u wanna replace it??
Do u mean gas tank or gas filter??
alicantecoli
Colin Stickland
  • 22516 Answers
  • Posted on Jan 31, 2009
SOURCE: 2002 VW Jetta WAGON GAS TANK DOOR LOCKED
look for an emergency pull cable in the boot (trunk) it should have one
Anonymous
  • 10 Answers
  • Posted on Jun 25, 2009
SOURCE: I have air coming into the fuel system on my jetta diesel
NO it does not have a fuel pump in the tank. It uses vaccum.
and if their are tiny bubbles in the clear line coming from the fuel filter to the injection pump that is normal. Even when the car is not running it is normal to see bubbles in the line. hope this helps.
Anonymous
  • 463 Answers
  • Posted on Jan 24, 2011
SOURCE: What do repair cost run
That's a difficult guess because there is a wide range in hourly rates between dealerships/repair shops.
An educated guess, you are likely going to see estimates in the range of $125 to $200.
Jetta 3 cli fuel system dirt in tank
Add 2 bottles of "heet" to your gas tank...also add 1 to 2 bottles of injector and gas system cleaner...good to remember this lesson of when not to buy gas...::( Hope this helps.
I have done a conversion iv put a jetta 2 cli 1.8 motor in my golf mk 1 I want to know if I need both fuel pumps or wil the pre supply pump be enough? and because the golf had a mechanical fuel pump...
you cant just steel power.you have to have fuel pressure regulator conected with fuel pump relay and pump itself.best way would be to install fuel tank from MK4 with el.pump inside,add relay conected with ignition switch and fusible power from battery
I got a jetta cli 1992 model. My fuel gauge fluctuates while driving. Cn sumone help cos this problem is very annoying
Simple solution is keep the tank full. What you are seeing is caused by the "free surface effect" (gasoline sloshing back and forth in your tank). If you can't keep your tank full. learn to ignore it or put black tape over it. The repair will be very expensive.
Thanks for your question @ FixYa.com
2answers
6helpful
2answers
Where is my fuel filter located? my car is a 1993 VW jeta III GL
Look under the car, towards the rear passenger door, along the side of the undercarriage. It will look like a can without a label. It will have one line going in and out of each end.
3helpful
1993 Jeep Grand Cherokee Fuel Gauge not working
There could be two problems here:
1. That buoy floating tank is not working properly
2. That the electrical system that fails to submit the dashboard.
Review this information:
- ZJ-Secc-8E-Instrument-Cluster-and-Gauges
Page 2 - Fuel Gauges description
Page 4 - Voltimeter/Tachometer/Fuel Gauge/Low Fuel Inoperative
Page 10 - Specifications
- ZJ-Secc-14-Fuel-System
About Fuel Tank components
- ZJ-Secc-8W-Wiring-Diagrams
Fuel Tank and Gauge & Sensor Units Sending (Page 93 and next)
Good luck... and remember rated this help.
3helpful
2answers
1993 VW Cabriolet Fuel pump or Injector problem?
Hi. This is more of a fuel filter issue than a pump issue although, a bad fuel filter will eventually destroy a fuel pump. When the filter is restricted or clogged, this will tend to work the pump harder than normal. this will over heat the pump, therefore, shortening its life span. I recommend replacing the fuel pump and filter and, adding a fuel additive like techtron fuel injector cleaner/water remover as well.
Please rate and have a great day:)
Fuel box
Starting
Top Volkswagen Experts
ZJ Limited
ZJ Limited
Bradley
Bradley
Thomas Perkins
Thomas Perkins
Are you a Volkswagen Expert? Answer questions, earn points and help others
