Question about Sony ICD-B200 Digital Voice Recorder
Power switch I am unable to power the device off without removing my battery. Is there another way? My battery dies and I cannot turn it back on without a new battery, so it must still be on. Is there anyway to turn it off completely.
  • 1 more comment
  • ashannbri Oct 09, 2008
    ugh...maybe we are both idiots but i have the same issue, luckily the batteries last a little while if you forget to take them out but i have seriously tried EVERY button, just pushing and then pressing them for a while...even different combos...if you find something let me know but i have yet to see anything
  • Anonymous Apr 05, 2009
    Mine won't power off to the point where the display is turned off. There are no apparent power off/on buttons and the hold-switch in either position do not 'power off' the device. Is the display meant to stay on all the time? Seems like a waste of battery really.
  • Anonymous Apr 16, 2009
    me too.
I looked on sony.com - put the hold switch to the up position and it will turn off within a few seconds
Posted on Feb 06, 2009
I GOT THE SAME PROBLEME TOO.
Posted on Nov 06, 2008
Unable turn on canon 60D i was reviewing the photo
Remove the battery and memory card, switch the power switch on for a few seconds and then switch it off. Make sure the battery is fully charged, re-insert the battery and try to switch on again without the memory card in.
Oct 24, 2013 | Canon EOS 60D Digital Camera
I am unable to charge my notebook, something wrong with the outlet from the computer, the input
It might be, but we need some basic troubleshooting to determine if it is really the battery or the unit itself that has the problem. Turn off the device, then remove the cables and battery on the laptop. Press and hold the power button for 8 secs.Reinsert the cables only without the battery and turn on the device. Check if it is working fine on your system. If it is, then turn off the device and remove the cable. Then reinsert the battery w/o the cable and turn on the pc. If it wont turn on, then plug the power cable. If it is on then check if it is charging. If it is not charging then you need o replace the battery. If you plug the cable without the battery and does not turn on, then there is something wrong on the outlet or from the AC power cable or from the power port. That is the time you replace the cable.
Jul 18, 2010 | Gateway 450ROG Notebook
My montitor on my laptop went off last night, after messing with the mouse for a minute, i shut it off, now it will not come back on. when i hit the power, the light on the battery button in the front...
1. Turn OFF the Computer, remove the Battery and disconnect the AC Adapter also.
2. Press and hold the Power Switch for 5 seconds.
3. Insert the Battery in the Computer an try turning ON the Computer.
4. If the issue persists, remove the Battery, press and hold the Power Switch for 5 seconds.
5. Connect the AC Adapter and try turning ON the Computer(without Battery).
NOTE: If the Computer turns on without the Battery, connect and charge the Battery for 24 hours.
6. Disconnect all external devices that are connected to the Computer.
7. Attempt to turn ON the Computer.
8. Remove any additional Random Access Memory (RAM) that was installed in the Computer.
9. Attempt to turn ON the Computer.
This should resolve the issue.
If the issue still persists, then service may requires to resolve the issue.
Nov 22, 2009 | Gateway M-6843 Notebook
Turn off radioand turn on mp3 my screen is broke
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Sep 30, 2009 | SanDisk Sansa Clip MP3 Player
Screen says "Disconnected" and won't turn off. or load
Try these 3 resetting steps:
OR
OR
Sep 30, 2009 | SanDisk Sansa e260 MP3 Player
Wont turn on screen remains black as in not on black and it stays this way even when plugged in
OR
OR
Sep 30, 2009 | SanDisk Sansa e250 MP3 Player
Turns on - see LED display, but nothing happens
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the SanDisk website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
OR
OR
OR
Sep 29, 2009 | SanDisk Sansa m240 MP3 Player
How to reset the sansa e270
OR
OR
Sep 29, 2009 | Audio Players & Recorders
Can't change from HDMI2 back to HDMI1
You need to change via tv selections option for tv, this should be possible by selecting the source for tv feed. This should give various options to select hdmi11, hdmi12, scart1 ect. If remote not working to change look on the tv itself for the control buttons, normally on the back to 1 side (rh from front) then pressing the correct button. If this does not work try turning power off to tv for a couple of minutes and then turning back on. Hope this helps.
Apr 29, 2017 | Vizio Televison & Video
317 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
