I NEED TO KNOW WHAT IS THE BUTTON BY THE POWER BUTTON TO BE USED FOR????? ALSO THE GUIDE FOR THE PRINTER IS VERY CONFUSING AND JUST NOT SPECIFIC ENOUGH FOR BEGINNERS.
  • IQUIT May 11, 2010
    Well, it you told us the models of the printer and the computer, we might ba able to provide you with an answer on both questions.
  • 3,940 Answers
No response
Posted on Sep 10, 2008
How do i fix printer error 0xF3
Error Code 0xF3 means a hardware failure. If you are still under warranty, Epson will replace it.
Oct 08, 2015 | Epson WorkForce WF 2630 Wireless Printer
Unable to close error message "Paper Jam"
unplug the printer, inspect it for paper jams, take the printer apart as far as possible and clear any paper jams in it.
for more specific instructions I will need to know the brand and model of your printer.
Thank,
Ekse
Jul 07, 2008 | Office Equipment & Supplies
No - i560 used ink tank is full (so say the warning display) I need to fix this as our IT department will not. I need to know how to fix the problem
To get round the ink tank (sponge) full problem
you can try following
first turn sponge over then
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Sep 01, 2011 | Office Equipment & Supplies
Hi I pressed the wrong button turning the TV on, now I have no sound and can't get it back. please help.
SAP (Second Audio Program) may be turned on. This used to be a widespread RCA problem maybe caused by incorrect conversion of analog signals for viewing as phony HD images. Costly class action lawsuits addressed the problem in USA. Most of the specific equipment causing the problem used by broadcast/production/satellite industries was either adjusted correctly or replaced. If the problem re-occurs, it may caused by specific TV channels or programs that you watch. Codes inserted in the signal are incorrect and confusing the RCA TV Guide and audio processing circuits. The error causes SAP to be incorrectly selected as default for all channels.
Remedies:
Change audio settings in customer adjust menu to Stereo from SAP. Sometimes the On screen TV Guide set-up must be cleared of location, etc., and set-up again.
Sometimes it is difficult to set correctly. Unplug TV for 12-24 hours and TV may reset to default stereo setting instead of SAP.
This was an active Class Action legal issue 10-15 years ago in the USA.
easyab
Feb 23, 2011 | RCA Televison & Video
Waste ink tank full message
Hi there
I can only say try this, and please call back to let us know if it worked for you so I then can gave to others to use, Thanks.
Printer on, press Additional Functions, Scan, Copy, Scan
Now you should be in service mode from there for waste ink tank reset.
2) Select Test mode which is like the last available selection
3) Select #8 Printer Test, it will do something here like cleaning then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
The menu will now say EEPRON Clear
Select Ink count which is option (0) and press set
Then press Stop/Reset Followed by the power button and then wait for it to restart.
Hope this is not to confusing
If not work you can try next.
· Printer on, press Additional Functions, Scan, Copy, Scan. Now you should be in service mode.
· Select Test mode.
· Select #8 Printer Test, push the + or - button until it says 8-3 then hit the select button.
· The menu will say EEPRON Clear
· Select Ink count which is option (0) and press set
· Then press Stop/Reset Followed by the power button and then wait for it to restart.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | Canon SmartBase MP360 All-In-One InkJet...
Unable to print /trouble shooting and routine maintenance refer to uses guide, i am not able to find my uses guide at present
first go t the printer folder by using the tray link(right system on the task bar) ...remove all errors and jobs in duty...
try again but restart and reset the printer by keeping the power button pressed a few seconds...
if the problem persist reinstall the driver ...but first remove all programs related and the folder that used to contain the driver from the program file folder...
let me know how it works...
Dec 20, 2009 | Office Equipment & Supplies
Lost directions for setting the timer ML300RTW
You posted under ML series power packs.
The manuals vary by model number, and are longer than space allowed for free answer.
Manuals appear on following page:
http://malibulights.com/customer_service/owners_manuals.aspx
I strongly recommend reading whole manual, and then you can add a comment about any specific part of manual that is confusing, along with model number, and I will help the do-it-yourselfer with best information possible.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Aug 24, 2009 | Intermatic Malibu 300W Power Pack...
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Nov 12, 2008 | Dell 3100cn Laser Printer
Cannon printer MultiPass.MP390 waste ink near full the waste ink tank(which holds the ink, used for print head cleaning) is nearly full. What do I do The printer tells me this when I am using it. It says...
1)Printer on, press Additional Functions, Scan, Copy, Scan
Now you should be in service mode from there for waste ink tank reset it is simalar to what has already been posted
2)Select Test mode which is like the last avalabe selection
3)Select #8 Printer Test, it will do something here like cleaning or something then it will come up with some other option this is where it gets a bit confusing cause now all it says is like 8-2 or 8-3 push the + or - button until it says 8-3 then hit the select button
Oct 22, 2008 | Office Equipment & Supplies
What keys do I press to determine how may pages have been used on the printer to date?
It would great if you could tell me the make and model, but I can share these ideas.
Most inkjet printers will print out some sort of configuration page if you hold down the online button while plugging in the power. Some of them you can try just holding down the online button for 8 seconds or so. However a page counter is printer model specific and may not be available on all printers.
Let me know your printer model and I hope this helps =)
Apr 03, 2008 | Office Equipment & Supplies
Computers & Internet Logo
29 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
