Question about RCA P46924 46" Rear Projection Television
Blue ghosting on dark areas of screen
There is a blue ghosting over all dark areas on the screen. My son took the back off and looked at the projectors. He said that the blue seemed to have less liquid(?) under the lens than the other two colors. Is ther supposed to be a liquid under the color projector lens? Is this "low liquid level" causing the ghosting problem?
  • 513 Answers
I think your son figured it out. check also to see if the liquid is cloudy or has any debris in it, if so it could use a change while you're at it. unless your son knows how to work on the TV(in addition to diagnosing the problem) you should have it looked at, with the advantage that now you know the problem, and what you're going to be charged for. to change the fluid, the only way to do it properly is to completely remove the CRT assembly from the set, drain it, disassemble it, clean it THOROUGHLY (I use a LOT of Windex to do it) and reassemble it paying close attention to get it together correctly. And don't forget to discharge that HV lead at the splitter blocks BEFORE doing anything else! The best way to put in the new fluid is from a squeeze bottle with a funnel shaped nozzle. A hair dying kit will have what you need, usually. you should make sure you're using the same type of liquid as was there originaly, because different liquids have different optic behavior. Have fun!
Posted on Jan 23, 2006
SOURCE:
WD 73835 has ghosting images during dark or red scenes
Make sure your contrast isn't set too high. Most ghosting is caused by either contrast, brightness or tint issues. Try adjusting these settings. Also check if there is a Dynamic contrast setting for your TV as well as this can cause ghosting also.
Apr 06, 2014 | Mitsubishi Diamond 835 Wd-73835 73" 1080p...
Dark area on screen.
i have had the same problem with the dark patch and found out it was because i had a speaker sat too close to the tv!!!
Apr 04, 2009 | Maxent MX-26X3 Television
Samsung plasma tv 42inch PS42E THDX Blue sparkles on dark areas
Hi yes i had the same problem and its basically because the tv needs a software upgrade. I contacted argos and they sent an engineer to sort it and he plugged something into the back of the tv to upgrade it. all in all it took 5 mins to do and not had a problem since.
Jan 31, 2009 | RCA PHD42600 42 in. Plasma Television
RCA 52'' Projection HDTV Blue ''ghosting''
Go to menu ,now go to setup see if convergence is on menu if not then fuse FL231 is opened 0.6 amps it is located on right side of flyback transfomer the fuse in the middle they look like small square capacitors brown there is 3 in a roll.
Dec 11, 2008 | Televison & Video
Pink highlights on LCD screen
IT SOUNDS LIKE THE MAIN BOARD IS BAD. THERE IS 2 DIFFERENT VERSIONS FOR THIS SET .AM02 UNITS OR VERSION 0001 UNITS. THE PART NUMBER IS BN94-00695E. THEY BOTH ARE ABOUT $210 + $50 CORE.
DON..
Jun 02, 2008 | Televison & Video
IN72 psychedelic traces
have the same problem took mine apart for cleaning and inspected the bulb looks like bubbles in the bulb that will hold disorted images on the screen so im going to replace bulb
Feb 04, 2008 | InFocus IN72 Multimedia Projector
Red-striped ghost images.
when you leave your TV (no matter what kind) and you leave it for long periods of time on a static image or something.. the image tends to burn in to the screen... so changing the glass would be a way to fix it.... the problem is that that kind of repairmen is more expensive and difficult than buying a new set...
Dec 24, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Dropped camera-two corners dark
Check what the actual pictures look like when they are downloaded to PC or to print. The problem may only be on the screen. It may be very expensive to replace the screen, but you might be able to live with it?
Good Luck
Oct 25, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Sony Wega KDF-55WF655 blue ghost problem after replacing lamp
It is a defective light engine and it must be replaced. I hope you have a warranty because Sony will not help you.
Apr 06, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
RCA P46924 46" Rear Projection Television Logo
75 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
