Question about Panasonic KX-T7453 Corded Phone
RINGER VOLUME I cannot turn on the ringer for this phone. We are on a multi-line system and originally this extension rang, changed phones from KX-T7433 to KX-T7453. Only manual I can download does not include 7453. Thank you.
  • Panasonic Master
  • 2,460 Answers
Go back to that original 7433. Beg, borrow, or steal one of those phones from someone else and plug it back in. Have someone call you on the intercom and make sure the AUTO ANS button is not lit. Does it ring? Now plug in your 7453 and do the same thing. Does it ring?
I think I only had one or two of those models and the ringer is a two step switch (3 positions) OFF LO HI on the side of the phone. Make sure it's set to something besides OFF.
If the phone rings on intercom but not on the outside lines, that's a different problem.
Carl
Posted on Sep 07, 2008
How to make a Nortel phone model M7310 ring
If the phone doesn't ring when called by the extension number of the phone then try to use the volume up button while someone is calling the phone. The volume is a multi-purpose button that doubles for phone volume and ringer volume. However, the only way to turn up the ringer is when a call is coming into the phone.
Feb 18, 2015 | Nortel Lands Phones
Ringer turned off. how do you turn it back on
Press either line 1 or line 2 on the face of the phone then slide the volume button up or down, for example, press line 1 and slide volume up to turn on ringer, and press line 2 and slide down to turn ringer off
Mar 06, 2012 | AT&T 972 Two-Line Memory phone
Phone does not ring on incoming calls. The manual suggests "make sure ringer is on." Where is the ringer?
Ringer On/Off and Ringer Volume 1. Make sure your phone is in idle mode. (not in Talk mode) 2. Press the VOL (- or +) button to activate the ringer volume setting. 3. Press either the LINE 1 or LINE 2 Soft key to select the desired line. 4. The LCD will display the volume range and currently-selected volume in an ascending series of bars. 5. Press the VOL (- or +) button up or down to increase or decrease the volume in steps. 6.The system will retain the last entry, it is not necessary to save or acknowledge your selection from this mode.
It is also possible you have set the DND (Do Not Disturb) feature which will also caution your phone not to ring when a call comes in.
Have a great day. Hope this helps.
Jul 05, 2011 | RCA ViSYS 2-Line Speakerphone
Hi I have a vtech Hannah Montana Cordless phone and it won't ring. It has a slash through the ringer bell on the screen. I've tried the ringer settings taking the battery out and the tone and...
These can be the only things that are causing your problems:
Ringer mute
You can mute the ringer temporarily when the telephone is ringing.
Press OFF/CLEAR or MUTE to temporarily silence the ringer. The next call will ring normally.
Ringer volume
You can change the handset ringer volume to a comfortable level. The ringer can also be turned off so the telephone does not ring when there are incoming calls.
To adjust the ringer volume:
Press MENU/SELECT to display the menu when the handset is not in use.
Press or to select >RINGER VOLUME, then press MENU/SELECT.
Press or to adjust the volume. A sample of each volume level will be played as you adjust it.
Press MENU/SELECT to save your selection. You will hear a confirmation tone.
Make sure the ringer is on (page 8).
Make sure the telephone line cord and power adapter are plugged in properly (page 2).
The handset may be too far from the telephone base. Move it closer to the telephone base.
There may be too many extension phones on the telephone line to allow all of them to ring simultaneously. Try unplugging some of them.
If the other telephones in your home are having the same problem, the problem is in the wiring or local service. Contact the local telephone company (charges may apply).
Other electronic products can cause interference to your cordless telephone. Try installing your telephone as far away as possible from the following electronic devices: wireless routers, radios, radio towers, pager towers, cellular telephones, digital telephones, intercoms, room monitors, televisions, VCRs, personal computers, kitchen appliances, and other cordless telephones.
Test a working telephone at the telephone wall jack. If another telephone has the same problem, the problem is in the telephone wall jack. Contact your local telephone company (charges may apply).
The telephone line cord might be malfunctioning. Try installing a new telephone line cord.
Wait for the handset to synchronize with the telephone base. Allow up to one minute for this to take place.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Vtech DECT 6.0 Digital Cordless Phone
How do you adjust volume on base ringer on uniden dxa15588-2
Setting the Main Base Ringer Volume
The main base has three ringer volume settings: high, low, and off. You can change
the ringer volume while in standby mode or while an incoming call is ringing.
1) Press the ringer key.
You hear the ringer at the current volume level
([ ] High, [ ] Low, [ ] off) (if you set the
main base ringer volume to off, “Ringer off” is
announced) and it is displayed on the main base.
2) Press the ringer key repeatedly until the desired ringer
option appears.
3) The system displays the new ringer volume.
Dec 30, 2009 | Uniden DXA15588-2 Twin Cordless Phone
I want to find out how to change the ringer volume or turn to ringer off
Start npressing the navacation wheel "Down" and you will see the volume of the ringer change on the display. Keep pressing untill the display reads "RINGER OFF" To turn ringer back on simply press the UP arrow on the nav wheel.
Sep 29, 2009 | Panasonic KX-T7633 Corded Phone
Lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Nov 11, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Turn off ringer on an extension?
If you have a Strata CTX phone system you need to call your dealer unless you have the software program then I can help you.
Apr 17, 2008 | Toshiba DKT-2010 Corded Phone
Ringer off, need to re-install ringer. volume control does not put ringer back on
To turn your ringer back on, you do the following. For your handset, you push Menu, scroll to ringer settings, then push select, Press select again for ringer volume, then scroll up to turn on and increase the ringer volume. Then press Save once its at the desired volume. To change your base ringer, while it is not in use, push the ringer up button until you hear the desired setting. That should fix your problems.
Dec 31, 2007 | Panasonic KX-TG2357 Cordless Phone
Programing
Here are some suggestions Volume You may adjust the ringer, speaker, handset and headset volumes independently with the VOLUME ^ and VOLUME v buttons. Your telephone comes with predetermined settings which can be adjusted to individual taste. You will hear an error tone when the maximum or minimum volume level is reached. During volume adjustment, a ?dashed line? icon shows in the display. Adjusting the Ringer Volume Press the VOLUME ^ or v button while in on-hook mode. And/or 1 Selecting a Ringer Tone You may select the ringer tone for each line independently. You may choose to turn the ringer off or select one of the four available ringer tones for each line. 1. Press STORE. The red indicator blinks indicating unit is in Store Mode. 2. Use the number pad to select a ringer tone 0 through 4 (selecting 0 turns the ringer off). 3. Press STORE and then press the desired line button. NOTE: The line indicators continue to flash for incoming calls even with the ringer disabled. You may not select the same ringer tone for both lines. Checking the Ringer Settings Check the setting or each ringer (on, off) by pressing STORE, followed by LINE 1 or LINE 2 button when the phone is on the hook. The ringer setting of the selected line will be shown in the display. If there are any further questions or comments please post here. Please rate this solution through fix-it. Thank you.
Jun 23, 2007 | GE 29485GE2 Three - Line Speakerphone w/...
Panasonic KX-T7453 Corded Phone Logo
558 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
