Question about Gateway 506GR PC Desktop
Raam I'm having installing ram. It doesn't slide straight in. I can clamp one side or the other.
  • marty42 Sep 05, 2008
    hi u can urgest the both side clams and slots dot
    What does that mean?
Hi u can urgest the both side clams and slots dot
Posted on Sep 05, 2008
How do I make adjustments on my ridged r4512 table saw?
The carriage under the table is held to the underside of the table with several bolts or screws. Loosen those screws.
Raise the blade and clamp a stiff metal straight edge to the side of the blade. Use a carbide blade and clamp the straight edge to the sides of the teeth. Move the carriage around until the straight edge is parallel with the miter gauge slots, then tighten the bolts.
Oct 12, 2014 | Ridgid Saws
Setting up a jig saw to cut a straight 1/4 inch
You will need two C clamps and a straight edge,I use a metal yard stick.Whatever you use look down the edge a make sure it's true.
Set up on the line and make sure the blade is going to cut on the waste side of the line.Measure the distance from the edge of the wood to the other side of the jigsaw glide plate and make a mark.Transfer the measurement to the other end.I move the blade up just above the surface so I can set the jig saw on the wood while I get the measurements.The last step is to clamp the straight edge down.Make sure to have the clamps with the handles down.Check under to make sure you won't run into any thing and do a dry run to check for cord hang ups.This is the best way as long as you keep the edge of the bottom jig saw plate against the straight edge.^^^^ Well that's how I do it. good luck
You can all so use the T bar attachment that slides through the bottom plate and clamps down with thumb screws.Personally I like the straight edge.
May 10, 2011 | Skil 94500 Jig Saw Rip Fence
Need to replace the cv joint boot on a 2000 buick century (outside)
First i think you should replace the cv axle instead of trying to just replace the boot, if the grease leaked out and dirt got into the joint then the joint is bad in soon you will hear noise or joint will let go. the time it take to replace the boot and the cost of the bbot i would replace the axle, you can buy a rebuilt axle for 45.00 with the exchange of the old one. heres directions to replace the boot. remove the wheel then remove the brake caliper and bracket, tie this of to side. take brake rotor off it should slide off, you may need to tap to break it free.next is to remove the center axle nut, after that you will remove the lower balljoint nut and split lower control arm from spindle, you may need a pry bar to sperate the control arm from the spindle, pull spindle out and slide axle out of the spindle.to replace the boot cut the inner and outter boot clamps, slide boot back and look inside for a clip., some use clip inside and some outside, look at shaft going into joint, see if theres a clip to open to slide cv joint out. if theres no clip then its an internal lock clip and what you need to do is hood the shaft and bang joint off shaft, you will need some help, hold the saft or use a pry bar and slide it into the rear of the inside joint between the back of the joint and the trany and give it a tug the joint will pop out of the trany this is a lot easier to work on off the car, put it in a vise, loock the shaft in vise to keep it from moving then hold outter joint straight and hit joint with hammer a few times and it will slide off, to install tap back on to lock it back on the shaft. with joint off remove old boot and clean shaft, insall new boot with clamp first then install outter clamp, install joint and grease, put grease into joint and the rest into the boot, make sure to clean the joint before installing it, after the install place the boot on the joint and clamp both clamps, install the axle, hope this helps, good luck.
Mar 20, 2011 | Buick Century Cars & Trucks
Where is the fuel filter located on a 1994 dodge ram
Fuel Filter REMOVAL & INSTALLATION CAUTION
Never smoke when working around gasoline! Avoid all sources of sparks or ignition. Gasoline vapors are EXTREMELY volatile! All 1989–93 Gasoline Engines and 1994–96 2.5L Engines The fuel filter is located in the fuel line on the inside of the left frame rail, just ahead of the crossmember. Fig. 1: Fuel filter location for gasoline engines 88471011.gif
  1. Relieve the fuel system pressure as described in Section 5.
  2. Unfasten the filter retaining screw and remove the filter from the frame rail.
  3. Wrap a shop towel around the hose connections to catch fuel spillage. Loosen the fuel hose clamps and disconnect the hoses from the filter.
  4. Remove the old fuel filter and replace it with a new one.
  5. Connect the fuel hoses and tighten the hose clamps. Position the filter on the frame rail and tighten the retaining screw to 75 inch lbs. (8 Nm).
1994–96 Gasoline Engines — Except 2.5L The fuel filter is integrated into the fuel pressure regulator which is mounted in the fuel tank. This unit is not controlled by the PCM or engine vacuum. It is calibrated to deliver approximately 35–45 psi (241–310 kPa) of fuel pressure to the injectors. If the pressure exceeds the maximum of the specified range, an internal diaphragm closes to route fuel back into the fuel tank. This system eliminates the need for conventional return lines from the engine bay and accounts for the name of the "Returnless'' fuel injection system employed in these vehicles. NOTE: Fuel tank removal is required for this procedure. Also needed will be external snapring pliers and proper hose clamp pliers, such as No. C-4124 pliers (available through Plymouth/Dodge dealers), or equivalent.
  1. Relieve the fuel system pressure as described in Section 5. Fig. 2: With the fuel tank removed, twist and pull the fuel filter/regulator for removal from the rubber mounting grommet 88471707.gif
  2. Drain the fuel tank and remove the tank.
  3. Remove the fuel filter/regulator (which is pressed into a rubber grommet) by twisting and pulling it straight up. Fig. 3: Use snapring pliers to remove the retainer securing the cover tube to the base of the filter/regulator 88471708.gif
  4. Remove the snapring retaining the cover tube, then slide it down to reveal the clear plastic fuel tube and its retaining clamp. Fig. 4: Cut off the old tube clamp without damaging the plastic fuel tube 88471709.gif
  5. Gently cut off the old clamp without damaging the tube, then discard the clamp.
  6. Carefully pull the tube off, then remove the filter/regulator from the fuel pump module. To install:
  7. Install a new clamp over the plastic fuel tube and attach it loosely to the filter/regulator. Rotate the unit in the line until it is pointed to the driver's side of the vehicle.
  8. Tighten the clamp using hose clamp pliers such as No. C-4124 (available through the Plymouth/Dodge dealer). NOTE: Do not use conventional side cutters to tighten the clamp.
  9. Slide the cover tube up to the bottom of the filter/regulator and install the snapring.
  10. Carefully press the assembly back into the rubber grommet by hand. It should be pointed to the driver's side of the vehicle.
  11. Install the fuel tank.
Jul 14, 2010 | 1994 Dodge Ram
I am trying to replace the fuel filter on my 2001 Dodge Ram 3500 Van. I can't seem to find it. Can you tell me where it is located?
Fuel Filter for 5.2 L Removal & Installation To Remove:
NOTE: The combination fuel filter and fuel pressure regulator is located on the top of the fuel pump module.
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • The fuel tank
    • Any debris around the filter/regulator to prevent contaminants from entering the pump module
    • The fuel filter/regulator from its rubber grommet by twisting and pulling straight up CAUTION
      To prevent damage to the coiled fuel line, ensure the filter/regulator is not more than three inches from the fuel pump module.
    • The old fuel line clamp, by carefully cutting it ensuring not to damage the plastic fuel line (discard the clamp)
    • The plastic fuel line from the filter/regulator by gently pulling downward
    • The filter/regulator from the fuel pump module
To Install:
  1. Install or connect the following:
    • A new clamp over the plastic fuel line
    • The filter/regulator to the fuel line NOTE: Rotate the filter/regulator in the fuel line until it is points toward the front of the tank.
    • The line clamp to the fuel line using special Hose Clamp Pliers number C-4124 NOTE: Do not use conventional side cutters to tighten this type of clamp.
    • The filter/regulator into the rubber grommet, pressing by hand
  2. Rotate the filter/regulator until it points towards the front of the vehicle.
  3. Install the fuel tank.
  4. Check for fuel leaks.
Jul 10, 2010 | 2001 Dodge Ram 3500 Truck
Needle Change on the Elna 6003
1 - Loosen the knurled thumb screw on the right side of the needle clamp.
2 - The old needle wil probably fall out, if not you can simply pull it straight down to remove it.
3 - Slide a new needle up into the needle clamp.
4 - Tighten the knurled thumb screw on the right side of the needle clamp with your right hand while holding the needle up with your right hand.
Feb 10, 2010 | Sewing Machines
Location of coolant drain **** on 1997, ram,5.9, 1500
Have a look up under frame (rad support) for a hole in there where drain is accessible. Sometimes on side of rad, at bottom as well, or on engine side down low, on passenger side usually. They are really getting to be a pain to access now, and that's why I keep a good size drain pan around, and simply loosen off clamp on lower rad hose if it's easier to access, and slowly remove it to drain rad. When done, slide it back on good, tighten clamp, and double check it for leaks after vehicle runs for a while. Good Luck.
P.S. Don't forget, any spillage on driveway or wherever of antifreeze should be cleaned up in case of an animal/pet in area, as it can be very inviting to them, and it can cause them a slow painful death if ingested.
Dec 05, 2009 | 1997 Dodge Ram 1500 Club Cab
What holes the kickstart on a kx250f
The lever should be held on to the shaft by a clamp and pinch bolt. Both shaft a lever are splined and need s to be slide straight of. If it won't slide off, tap a scre driver in the clamp gap tospread the clamp a small amout. The kick lever should the come off.
Nov 05, 2009 | kawasaki KX 250 F Motorcycles
04 dodge ram 1500 HEMI's new brake pads won't fit
what you need to do is line clamp brake hose so you dont push dirty brake fluid back into your system..(you can use a pair of needle nose visegrips if you dont own an actual line clamp) loosen bleeder at this point, remove caliper from attatching bracket, with old pad still installed next to piston use a big C-clamp to compress piston, just make sure clamp is centered and compress slowly allowing brake fluid to escape through loosened bleeder... once compressed tighten bleeder and install caliper and pads remove lineclamp....******NOTE******* no need to bleed the system cause of lineclamp procedure... Make sure upon reassembly you use plenty of brake lube on all sliding caliper parts...Good Luck
Dec 31, 2008 | 2004 Dodge Ram 1500
I HAVE A KENMOR DRYER MODEL NUMBER GGQ8811LL0 AND I CANT OPEN THE FRON ACCES PANEL I DONT KNOW HOW
Hello Velasco,
You have what is known as a dott dryer and to open the control panel you should take a flat blade screw driver and slide it straight into the groove above the bottom panel. about 2-3 inches from each side. when you find the small clamp you should simply push the screwdriver straight into the clamp. Pull out on the side of the panel and it will open. Please make sure to disconnect all power before you open the unit as there will be wires that you could touch. Good luck and I hope this helped.
Apr 30, 2008 | Dryers
Gateway 506GR PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
