Question about Panasonic DVD-F87 Multi-disc DVD Player
Picture keeps rolling
When I put the dvd in the picture just goes up and down. It doesn't stop so I can view the movie
    Novelist:
    Champion:
  • 277 Answers
The picture rolling is simply because the PAL decoder can't lock up to the 60Hz vertical sync pulses, even if your DVD player is set to NTSC-PAL conversion and there is no vertical hold adjustment (either external or internal) on this model set to achieve this. There is a possible alternative only if your DVD player has RGB output (not component). The JVC for example has direct RGB drive capability via the SCART input on the back panel. If you get a suitable lead you could try getting a picture this way as it bypasses the decoding and sync sep circuits in the PAL decoder chip.
Posted on Oct 03, 2005
Picture keeps rolling over
If you know electronics there's few capacitor or one need to be change. or call a technician.
Oct 15, 2012 | Sharp LC-20S7U 20 in. EDTV LCD Television
When recording a movie or program, the playback rolls forward and backward causing viewing to be awful. Sound comes through, but viewing is ruined because of the rolling picture. How do I correct this...
This is often caused by dirt on the heads or other surfaces the tape touches. I would get the top off and give it a good clean with some Servisol Video 40 (you can find that online) and some cotton buds. If that doesn't do the trick it's more serious.
May 17, 2011 | Emerson Televison & Video
Picture on tv rolls when dvd player is on.
Radio Frequency Interference (RFI) being generated by you rDVD Player.
That, or you have the DVDs settings on PAL instead of NTSC.
Mar 13, 2009 | Prosonic PD-007 DVD Player
Little white boxes rolling through picture
this is a problem with the mother board replace the mother board and then the problem will be solved
Mar 07, 2009 | Philips DVP642 DVD Player
Playing movies through usb port?
The options when you play a DVD it will appear when you are connecting ext HD it will not work.
Better you need the play in a DVD Disc to get the good sound.
Jan 06, 2009 | Philips HTS3440/37 System
Picture rolls
Same as sherpi here, player was fine, and all of sudden started rolling and never stops. Rolls with or without a disc in it...seems to play the discs fine, but never quits rolling.
Mar 08, 2008 | Spectroniq PD-1100 DVD Player
DVD Player Problems
Me three, same thing, reads 'no disc' or just won't play it. I have found that it happens more frequently on rental DVD's and that running a cleaner cd through several times helps but eventually that will even stop working. No idea what the problem is
Sep 30, 2007 | JVC TH-C5 System
Rolling picture
Not likely. They probably just need to be cleaned and re-alligned. Rates vary, but our shop charges $20 to do that.
Sep 24, 2007 | Zenith XBV442 DVD Player/VCR
MY SAMSUNG DVD+VIDEO COMBO V4600
What you're describing is a common problem for this particular unit, a bad spindle motor. In some cases the motor can be removed by the tech and torn down for cleaning.. But in a high percentage of cases shops just replace the motor... What's happening, as your symptom appears the spindle motor is beginning to spin irratically. In turn the picture can sometimes just drop out. In others it simply folds over and is unwatchable. The spindle motor is not too expensive.. Good Luck Bill
Jun 10, 2007 | Samsung DVD-V4600 DVD Player/VCR
Polaroid 0722 Player
On most of the set top DVD players you use the monitor button or the remote control menu button to access the mode that flips the display (invert). The mode is for those who mount the units to the ceiling of a vehicle for rear passengers to view. You might have to have a DVD playing at the time or just loaded in the stop mode to access the feature.
Jun 08, 2007 | Polaroid PDV-0700 Portable DVD Player
Panasonic DVD-F87 Multi-disc DVD Player Logo
256 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
