Touchscreen phones simplify the wireless world, especially when combined with voice activation. Although making calls using voice commands was an option before touchscreens became available, the method used to set up this feature is different than it is for non-touchscreen units. It can take time to master the set of procedures that will get the feature working. Step 1 Create a voice tag. Touch "Contacts" on the today screen. This opens the list of contacts on your phone. From here, do one of three things: you can hold your finger on the desired contact and then tap the "Add Voice Tag," you can select the desired contact, tap on "Menu" and then "Add Voice Tag," or you can tap the desired contact to open their personal screen and then hit "Menu" followed by "Add Voice Tag." Step 2 Record the voice tag on your phone. Touch the phone number to which you wish to add a voice tag then touch the "Record" button. Record your voice tag for that contact. An icon will be displayed to the right of the number when the voice tag is complete. You can listen to your voice tag by touching the "Play" button on the screen or you can delete it to record a new one. Step 3 Make a voice tag for a program. Tap the "Start" button on the phone. Go to "Settings" and then the "Personal" tab followed by "Voice Speed Dial." Choose the program for the voice tag and record the voice tag in the same manner as you did for the contact. To open the program with the voice tag, tap "Start," "Programs" and then "Voice Speed Dial." Step 4 Launch a program or make a call. Make a call by tapping "Start" followed by "Programs" and then "Voice Speed Dial." You will hear a beep. Say the voice tag you recorded for the person you wish to call. You can open a program via the same procedure (by speaking the voice tag created for the program). Step 5 Check the voice tags you created. Tap on "Start," "Settings," "Personal" tab and then "Voice Speed Dial." A voice tag tab appears and displays a list of your voice tags.
use the phone activation procedure... if u still having problem contact customer service and they will help if they cant help they transfer u to someone else who can help if u still having problem at this point they give u a new product key...
first you activate your subscribe packet data step no1:go to your mobile main menu press it.step no2:you saw a tools icon in your menu press it.step no3:you saw a sim icon or carrier icon press it . step no3: you saw a list of multimedia messaging or internet messaging press it.step no4:then you saw a wap gprs and mms option click the wap or gprs option and your packet data is activated if problem is not solved go to your carrier service center or call service help line thanks
For you to activate the call barring service of your Nokia 7210, follow these steps as you navigate to the menu :
Select "Menu" key
Choose "Settings"
Choose "Security"
Go to "Call Barring Service"
Please note that this feature requires a Barring Password. In order for you to change/create a barring password, navigate through the same menu options but choose "Access Codes" under the "Security" menu.
For your convenience, here's the link that will take you straight to the user's guide :
Ok, here is the step by step instructions on how to change the time and regional settings on your Samsung phone.
Open
the menu. Enter the menu by either pressing the soft buttons for menu,
or usually pressing the "OK" or center button of the directional pad.
Step 2
Choose the option that says, "Settings" or something that is closely related to that; it may also say "Phone Settings."
Step 3
Scroll down to the option "Phone Settings."
Step 4
Scroll
down and select "Time and Date." Choosing this option will take you to
the time setting page where you can change the clock settings.
Step 5
Change
the clock settings by typing in the numbers, or by using the scroll
keys to determine the correct time. When this is accomplished select
the "OK" option by pushing the "OK" button or by the center key.
Updating the Time in a Digital Signal
Step 1
Turn
the phone off. The fastest and easiest way to update the time when you
are receiving and digital signal is just to turn the phone off. This
will disconnect the phone from all cell towers.
Step 2
Turn
the phone back on. When the phone is turned back on, it will connect to
the nearest local tower and refresh the settings including the time.
This method is especially helpful when traveling across time zones.
Step 3
Adjust
the "Network" feature if available. Some phones have features in the
settings to connect to another network, or renew the license for the
network that it is currently attached to. If the phone has this
setting, it can be used in place of turning the phone off and back on.
The icon is an indicator for the Enhance Call Audio feature selected on the device. The Enhance Call Audio feature is designed to allow a user to adjust the sound quality over the earpiece of the device (e.g. Boost Bass or Boost Treble)
To improve sound quality for all phone calls, complete the following steps:
In the Phone application, display the menu and select Options.
Click General Options.
Change the Enhance Handset Call Audio or Enhance Headset Call Audio field.
Display the menu and select Save.
To improve sound quality during a phone call, complete the following steps:
1. During a phone call, display the menu and select Enhance Call Audio. 2. Select Boost Bass, Boost Treble or Normal.
To review the different Selectable Phone Equalizers during a phone call, press the L key. The enhancement specific icons are displayed on the active call screen.
