Question about Cameras
Telascopic lens will not move out - Cameras
  • 983 Answers
Here are the tips you need to be followed
#1:
Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on.
#2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
#3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during start up. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens.
#4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
#5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum
#6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand.
Posted on Sep 05, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Sep 05, 2008
    #7: Try forcing the lens. More people have reported success with this method than with any of the other methods.
    Variations include gently pulling, rotating, and/or twisting the lens
    barrel while hitting the power button. Attempt to gently straighten or
    align the barrel if it's crooked or twisted. Another variation includes
    looking for uneven gaps around the lens barrel, and then pushing on the
    side of the lens barrel that has the largest gap (note pushing the lens
    barrel all the way in is NOT recommended as it may become stuck there).
    While doing any of the above, listen for a click that indicates that
    the lens barrel guide pins may have reseated in their guide slots. If
    you hear this click, immediately stop and try the camera
"E212" Lens problem (sensor, motor)
You have a very old copier..... Try taking the copy board glass off and the lens cover (black box) off. Try to move the lens with your hand, will it move? Move it out of HP and turn the power ON. Will the lens move, if so look where it stops.... I believe there is a drive gear that may of cracked... You have to watch were it stop moving....Good Luck
Jan 15, 2013 | Canon NP 6050 Copier
Lens is not opening
Take the lens out and look the bottom side of the lens. There is a lever that operates the aperture leaves. If the aperture leaves does not move or moving slow, you have oils on the aperture leaves which need cleaning.
If the lens is good, the camera's lever that move;s this lens' lever mechanism had gone bad. Take out the lens and watch the aperture control lever moves when you trip the shutter. If it is moving, the problem is with the lens.
May 18, 2010 | Minolta Maxxum 7000 35mm SLR Camera
Lens is stuck out
Chanches are the lens received impact damage or there is some dirt, liquid like pop that is blocking your lens from moving. Try moving the lens and see if this will dislodge the lens. View the lens from top and sides, if it is sitting on an angle it has received impact damage.
Jul 02, 2009 | Olympus FE-270 Digital Camera
Lens does not move manually
You should not try to manually retract lens because lens has few gears in loading mechanism that can be broke if you put some force in try to rotate on lens.
Feb 10, 2009 | Canon PowerShot A550 Digital Camera
Key dropped under the right side of drivers seat
you can buy a small magnet on a telascopic rod handy tool
Jan 06, 2009 | 1997 Jaguar XJ6
Unable to load playstation dics or any other discs for that matter
  1. The white plastic gear that moves the laser must make contact with the "motor". A bad contact here can cause disk read errors. Sometimes it looks Ok, but you may need to remove the lens and bend the white gear for good contact.
  2. The two rails on which the lens move must be very slippery - which can be lubricated with cooking or motor oil. Usually the holes where the rail is (on the right side of the lens) are dirty or you have to bore then out slightly, making the holes bigger.
  3. The lens uses little torx screw (black) that move the lens up and down on the rail. Usually the lens is too high and requires adjustment.
  4. Take the lens off these 2 rails and take the black plastic cover off. Turn the lense upside-down and you'll find there are 2 screws (silver, phillips or torx) that you have to remove to take the upper little lens off.
  5. Then you'll see a larger lens that is usually very dirty (this lens is a mirror to light). If that's dirty, it will give a disk read error. You'll have to take the little electric board off that you see on the other side of the big lens-mirror. It's probably dirty too, so clean it. Alcohol should work OK for this task.
  6. The lens bottom has 2 + 2 screws. You move the upper "little" lens up-down-left-right (this may require a special screwdriver)
  7. The motor "rail" that moves the lens must be very clean and oiled and the 2 rails too.
Jun 05, 2008 | Sony PlayStation 2 (PS2) Console
Dont now how to work my telascope
Zhumell Eclipse 114 with Motor Drive Reflector Telescope How to use it? I have one here? Can u give me video"How to use it" My mail: vincent261088@gmail.com
Apr 18, 2008 | Zhumell Eclipse 114 Telescope
Aperture diaphram on mamiya secor lens 80mm f/2.8
The lens has a lever marked A/M near the aperture ring. If the lever is in the 'A' position, the lens will stay wide open until you trip the control lever at the back of the lens next to the rear optics. In the 'M' setting, you can see the aperture move as you change the f-stop setting on the ring. Set the lens to anything but wide open and move the control lever with your finger. You should see that aperture move.
Jan 14, 2008 | Photography
DSC-w70 stuck lens
there actually is a little gear inside that moves the lens and since you already opened it make sure the gear is there and moves. LOTS of problems with these cameras....
Jul 30, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Cameras Logo
78 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
