Question about Apple iPod nano
Why does my iPod appears on my computer but not in iTunes?
    Scholar:
  • 57 Answers
For Mac users "iPod does not appear in iPod Updater or iTunes in Mac OS X Under some circumstances, iPod appears in the Finder in Mac OS X, but does not appear in the iTunes Source list or does not appear in the iPod Updater. Symptom iPod's disk icon appears in the Finder, but it does not appear in the iTunes Source list or in the iPod Updater. Note: The iPod may appear in iTunes, but not in the iPod Updater. Important: If you are using iPod shuffle, you must have 10.2.8 or 10.3.4 or later to connect it to your Mac over USB. Other iPods require 10.3.4 or later Products affected Mac OS X iPod (5 GB) iPod (10 GB) iPod (touch wheel) iPod (dock connector) iPod mini - USB requires Mac OS X 10.3.4 or later. iPod mini (Second Generation) - USB requires Mac OS X 10.3.4 or later. iPod (Click Wheel) - USB requires Mac OS X 10.3.4 or later. iPod with color display (including iPod photo) iPod nano Solution iPod nano Certain models of single processor Power Macintosh G5 computers may show iPod nano mounted in the Finder but not recognized in iTunes. If this happens to you, try restarting your computer and Setting Energy Saver to highest performance and turn off hard disk sleep. If you have an iPod nano, but don't have a G5, then follow the other steps below. Mac OS X 10.4.x Perform an archive installation of Mac OS X10.4. Mac OS X 10.3.x Navigate to /System/Library/Extensions. Drag the iPodDriver.kext file to the Trash (you will be required to enter an administrator account password). Download and install the Mac OS X Combined Update 10.3.9. Restart the computer when prompted to do so by the installer. Connect the iPod. Mac OS X 10.2.8 and earlier To resolve this issue with earlier versions of Mac OS X, you'll need to delete one file and reinstall iTunes. Follow each of the steps below. Step 1 Delete the file using Terminal Warning: The steps below describe how to remove a file by entering commands in the Terminal application (located in the Utilities folder inside of the Applications folder). Users unfamiliar with Terminal and UNIX-like environments should proceed with caution. The entry of incorrect commands may result in data loss or unusable system software. Open Terminal (/Applications/Utilities). Type: sudo rm -R /System/Library/Extensions/iPodDriver.kext Press Return. Enter the administrator account password when prompted. Quit Terminal. Restart the computer (From the Apple menu, choose Restart). Step 2 Reinstall iTunes Download the latest version of iTunes from the iTunes download page. Install iTunes. Restart the computer after the installation has completed. Connect iPod. Step 3 Delete the iPod.plist file Remove the following file in the your home directory and launch the iPod updater again ~/Library/Preferences/com.apple.ipod.plist
Posted on Oct 02, 2005
    Scholar:
  • 57 Answers
Laptop or portable connecting via USB? "See iPod not recognized when connected to Windows laptop over USB for more information. Your computer doesn't meet iPod system requirements Make sure that your computer meets the system requirements to use iPod for Windows. Your iPod displays an exclamation point folder or sad iPod icon, or doesn't appear in iTunes or My Computer If your iPod displays a folder with an exclamation point icon or a sad (unhappy) iPod icon on its screen, or if your iPod doesn't appear in iTunes or My Computer, follow these instructions to resolve the issue. Your iPod isn't formatted for Windows iPod for Windows Software only recognizes iPod for Windows. You cannot use iPod for Macintosh with a Windows PC. To see which platform your iPod is formatted for, follow these instructions. Your iPod isn't connected to a high-power USB port If you're connecting an iPod, iPod mini, or iPod shuffle to your Windows computer, make sure that you're connecting it to a high-power USB 2.0 port on your computer (not a low-power one such as the USB port on your keyboard or bus-powered USB hub). Typically, USB 2.0 high-power ports are located directly on your computer. Try connecting your iPod to another USB port on the computer (or to a self-powered USB 2.0 hub that's connected to a high-power USB 2.0 port on your computer) if the computer still doesn't recognize your iPod. Alternatively, if your computer has a FireWire connection, try using that instead. If you're connecting an iPod, iPod mini, or iPod shuffle to a Windows laptop computer through USB, connect the laptop to a power outlet before connecting your iPod. You're not using a WHQL-certified IEEE 1394 card If you have a FireWire (IEEE 1394) card installed in your computer and are using it to connect your iPod, make sure that the card is Windows Hardware Quality Labs (WHQL) certified. If it isn't, your iPod may not be recognized, or you may not be able to send music to the iPod. If you're not sure about your card's WHQL certification, check the inbox material that came with your FireWire card or contact the card's manufacturer. You can view a list of WHQL-certified cards on the Windows Hardware Compatibility List website. To view this: Go to the Windows Hardware Compatibility List website. Enter All Products in the ""Search for"" field. From the Product Categories pop-up menu, choose 1394 Controller. Click the Search Now button. Note: Windows XP information is not listed on the initial search screen, but is listed when you click on an individual card. You can also check the list of recommended FireWire and USB cards that have been tested by Apple with iPod and Windows XP. (Apple sells FireWire cards that are compatible with iPod at the Apple Store.) To rule out an issue with your FireWire card, try connecting a different FireWire device to the card to see if your computer recognizes it. Your connections aren't secure Make sure that there i
    Scholar:
  • 57 Answers
For Windows users "Can't see your iPod in iTunes or Windows Explorer? Remember these five basic suggestions when you run into a problem with your iPod. If one of the following doesn?t help, read on for solutions to specific problems. Reset, Retry, Restart, Reinstall , Restore Reset your iPod. Retry with a different USB port. Restart your computer and make sure you have the latest software updates installed. Remove iTunes software and then reinstall iPod and iTunes software from latest versions on the web. Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide. Still can't see your iPod? Several things could keep iPod from appearing in iTunes or Windows Explorer. The most likely causes are listed below?you'll find information for both USB and FireWire (IEEE 1394) iPod connections. Check each one starting from the top of the list to see if that is what's keeping iPod from appearing. iPod appears in Windows Explorer but not in iTunes or iPod Updater If your iPod shows up in My Computer, but iTunes and iPod Updater don't recognize it, there may be a software conflict, or iPod Service didn't load. You may see an ""iPod Service Error"" alert or a ""Please Reinstall iTunes"" message.
SOURCE:
  • 57 Answers
SOURCE: Why my iPod doesn?t appear in iTunes?
For Mac users "iPod does not appear in iPod Updater or iTunes in Mac OS X Under some circumstances, iPod appears in the Finder in Mac OS X, but does not appear in the iTunes Source list or does not appear in the iPod Updater. Symptom iPod's disk icon appears in the Finder, but it does not appear in the iTunes Source list or in the iPod Updater. Note: The iPod may appear in iTunes, but not in the iPod Updater. Important: If you are using iPod shuffle, you must have 10.2.8 or 10.3.4 or later to connect it to your Mac over USB. Other iPods require 10.3.4 or later Products affected Mac OS X iPod (5 GB) iPod (10 GB) iPod (touch wheel) iPod (dock connector) iPod mini - USB requires Mac OS X 10.3.4 or later. iPod mini (Second Generation) - USB requires Mac OS X 10.3.4 or later. iPod (Click Wheel) - USB requires Mac OS X 10.3.4 or later. iPod with color display (including iPod photo) iPod nano Solution iPod nano Certain models of single processor Power Macintosh G5 computers may show iPod nano mounted in the Finder but not recognized in iTunes. If this happens to you, try restarting your computer and Setting Energy Saver to highest performance and turn off hard disk sleep. If you have an iPod nano, but don't have a G5, then follow the other steps below. Mac OS X 10.4.x Perform an archive installation of Mac OS X10.4. Mac OS X 10.3.x Navigate to /System/Library/Extensions. Drag the iPodDriver.kext file to the Trash (you will be required to enter an administrator account password). Download and install the Mac OS X Combined Update 10.3.9. Restart the computer when prompted to do so by the installer. Connect the iPod. Mac OS X 10.2.8 and earlier To resolve this issue with earlier versions of Mac OS X, you'll need to delete one file and reinstall iTunes. Follow each of the steps below. Step 1 Delete the file using Terminal Warning: The steps below describe how to remove a file by entering commands in the Terminal application (located in the Utilities folder inside of the Applications folder). Users unfamiliar with Terminal and UNIX-like environments should proceed with caution. The entry of incorrect commands may result in data loss or unusable system software. Open Terminal (/Applications/Utilities). Type: sudo rm -R /System/Library/Extensions/iPodDriver.kext Press Return. Enter the administrator account password when prompted. Quit Terminal. Restart the computer (From the Apple menu, choose Restart). Step 2 Reinstall iTunes Download the latest version of iTunes from the iTunes download page. Install iTunes. Restart the computer after the installation has completed. Connect iPod. Step 3 Delete the iPod.plist file Remove the following file in the your home directory and launch the iPod updater again ~/Library/Preferences/com.apple.ipod.plist "
Posted on Sep 28, 2005
mneilsen2084
  • 342 Answers
SOURCE: i think my ipod 80gb is fried can anyone conform.PLZ PLZ HELP
You should go to the following web address and watch the free video on resolving this exact kind of issue. I found it to be very useful. I hope you do as well.
http://fixyouripod.weebly.com/
Posted on May 14, 2009
ipodslinger
  • 688 Answers
SOURCE: 8GB iPod Touch Disabled
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
Restore it and Your all set.
if you need any further help let me know.
Good Luck
Posted on Jun 01, 2009
  • 201 Answers
SOURCE: when i plug my ipod into the computer and open
1) Try other USB ports on your computer, especially those on the back panel.
2) See if the USB cable is damaged.
3) Try the iPod on another computer with iTunes installed, to determine whether the problem is with the iPod or the computer.
Posted on Jan 26, 2010
  • 192 Answers
SOURCE: All of a sudden after 2 years annot get my iPod to
This happens some times the computer has lost the record that the ipod was synced with this computer.
Because the ipod can only be synced with one computer at a time your are getting this message.
if you look in your itunes music library and all the muisc is still there then choose the "erase and sync option" this will erase the ipod and re- sync with this computer -
if your muisc is gone you have a much larger problem you need to search your computer for your missing music then add it back to itune when you find it by :
In itunes you go to the upper left to : File > add Folder to Library > and choose the folder the music is in this will re- add your music to the libray then you can " "erase and sync"
If all you music is gone off your computer a only on your ipod your going to have to download a free ipod rip program to remove all you muisc and put it back into your library. there are free ones you can downalod but they are hard to find I have used www.ipodrescue.com and it worked for me
good luck !
Posted on May 11, 2010
Ipod stufed up
Hi jett
1...Make sure you have an Internet connection, you may need to download new updated versions of the iTunes or iPod Software.
2...Download and install the latest version of iTunes.
3...Open iTunes.
Connect your iPod to your computer using the USB cable that came with your iPod.
4...After a few moments, your iPod will appear in the Source panel in iTunes.
5...Select your iPod in the Source panel.
You will see some information about your iPod appear in the Summary tab of the main iTunes window.
6...Click Restore.
7...A progress bar will appear on the computer screen, indicating that stage one of the restore process has begun.
When this stage is done, iTunes will show one of two messages with instructions specific to the iPod model you are restoring.
8...Disconnect iPod and connect it to iPod Power Adapter this typically applies to older iPod models.
Leave iPod connected to computer to complete restore this typically applies newer iPod models.
9...During part two of the restoreing process, the iPod will display an Apple logo as well as a progress bar at the bottom of the display.
NOTE: It is very important that the iPod remain connected to the computer or iPod power adapter during this stage of the restore.
10...After the restore process is complete, the iTunes Setup Assistant window will appear.
It will ask you to name your iPod and choose your syncing preferences.
Please take time to rate me.
Bud
Mar 15, 2013 | Apple iPod touch
When i plug my ipod on to itunes it wont show up
Sometimes your iPod fails to display in iTunes, which will keep you from being able to transfer songs from your computer to your iPod. If this happens, there are a number of steps you can take to resolve the issue.
Is it the iPod? Your iPod could fail to show in iTunes for a variety of reasons and this issue can be resolved by something as simple as rebooting your iPod. To reboot your iPod, first lay it on a flat surface. Using your thumb and index finger, press the play and menu button at the same time. If done correctly, your iPod screen will go blank and then you'll see the Apple logo. Is it the USB cable? Your iPod could fail to show in iTunes if you are using a defective USB cable. Try connecting your iPod to another computer that has iTunes installed using the same USB cable. If iPod again fails to show in iTunes, replace the USB cable. Is it my computer? One of the most common reasons your iPod doesn't show in iTunes is because your computer doesn't recognize your iPod is connected. Troubleshooting your computer/iPod connection Disconnect your iPod from the computer and reconnect. If your iPod still doesn't appear in iTunes, disconnect your iPod and reboot your machine. Once your computer has restarted, reconnect the iPod. Is it iTunes? Your iPod could be fail to display in iTunes if there is a issue with your iTunes program. If there is a problem with iTunes you can try updating the software to the most recent version. If that doesn't resolve your problem, re-install iTunes. b> http://www.itunes.com/ b> http://www.apple.com/support b> iPod Won't Connect to iTunes b> Apple's iTunes software contains mechanisms specially designed to sync with your iPod, allowing you to transfer music, videos and other media from your computer. If you find that iTunes does not recognize or allow you to access your iPod, then you cannot perform some of the device's most fundamental functions. Fortunately you can often resolve this problem without expensive maintenance, simply by doing a bit of troubleshooting and determining the cause of your connectivity problem.
Try resetting your iPod. Apple recommends this as a first step in troubleshooting an iPod not appearing in iTunes, since a quick reset will often restore functionality. If you use a click wheel iPod, hold down the "Menu" and center buttons until the Apple logo appears on your screen. For the iPod Touch, hold your "Home" button and "Sleep" button simultaneously until the Apple logo appears. Charge your iPod battery. If your battery has absolutely no power left, your iPod will often remain unresponsive even when plugged into iTunes. Try charging for three to four hours and then try connecting again. Plug your iPod into your computer using a different USB port. Sometimes a failed connection can mean you have a faulty USB port, so try plugging your USB cable into a different port and see if the iPod appears in iTunes. Verify that you have the latest version of iTunes. Visit the iTunes page Apple.com and check to see the latest version available. If you do not know which version currently runs on your computer, click "About iTunes." For Mac users, this option will appear under 'iTunes" on your menu bar. For Windows users, the option will appear under "Help" on your menu bar. Download the latest version of iTunes if necessary. Reconfigure your iPod service. If running iTunes on a Windows computer, click "Start > My Computer > Manage," and select "Services and Applications." Under "Services," select "iPod Service" and click "Stop." Leave the window open and connect your iPod to your computer. When your iPod shows up on your computer, click "Start." Reinstall iTunes. If simply updating iTunes does not work, you may have defective software. Try removing the program from your computer and completely and reinstalling it.
Jan 29, 2013 | Apple iPod touch Second Gen (8 GB,...
My ipod wont show up on the bar when i plug it in the itunes
MY IPOD NANO IS FROZEN
i will be glad to assist you with this. If this step doesnt help please let me know and i can instruct you on how to reset your ipod.
  1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
  2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
  3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
  4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
  5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
    • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
  6. Try putting the iPod into disk mode.
    • While in disk mode, connect the iPod to iTunes and try to restore.
    • If the iPod is still not recognized by iTunes, the iPod should be serviced.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Aug 20, 2010 | Audio Players & Recorders
When i got done chrging my ipod it froze
Important: If your iPod is frozen or won't turn on, it may be because iPod is paused or the Hold switch is in the locked position. If so, a lock symbol appears on the screen. Slide the Hold switch to the unlocked position and check the screen.
Resolution If you experience any of the above issues, try the following steps:
Dec 17, 2009 | Apple iPod Photo MP3 Player
My screen is on language selection and does not let me scroll or anything i think its frozen.
If your iPod is frozen or won't turn on, the steps to reset it vary by model.
    Hope i helped you.
Thanks.
Aug 06, 2009 | Apple Ipod Nano Second Gen. Green (4 GB)...
APPLE IPOD VIDEO 30 GB WHITE
You can try to reset :
http://support.apple.com/kb/TS1382?viewlocale=en_US
http://support.apple.com/kb/HT1320?viewlocale=en_US
If you still have the problem you can try restore :
Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
1. Make sure you've reinstalled the latest version of iTunes.
2. Open iTunes, and then connect your iPod to your computer.
3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software.
The 4 possible restore options are:
Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
For Mac:
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
6. A message will appear prompting you to enter an administrator's name and password.
7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Or
Try to reinstall
To update and reinstall your iPod software, first download the latest version of iTunes.
http://www.apple.com/itunes/download/
Next, open the new version of iTunes and connect your iPod to your computer.
Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
Good Luck.
Live, Love, Laugh.
May 05, 2008 | Apple iPod MA446LL/A MP3 Player
Corrupted
To Restore follow these instructions :
I think you wont be able to do that.
For Windows:
For Mac:
Or
Try to reinstall
Good Luck.
Live, Love, Laugh.
Apr 25, 2008 | Apple iPod MA446LL/A MP3 Player
Resetting passcode to ipod 2gb
you need to restore your ipod
Restore
  • Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod: For Windows:
  • 1. Make sure you've reinstalled the latest version of iTunes.
  • 2. Open iTunes, and then connect your iPod to your computer.
  • 3. After a few moments, it will appear in the source list in iTunes.
  • 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
  • 5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  • 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
  • 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
For Mac:
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
    • Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
  • 6. A message will appear prompting you to enter an administrator's name and password.
  • 7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
  • 8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Dont forget the rate the solution as fixya!
If you need more assistance let me know, I'm here to help
Apr 04, 2008 | Apple iPod nano
Unlock my ipod
useing restore should unlock your ipod
Restore
For Windows:
For Mac:
Mar 22, 2008 | Apple iPod nano
Apple iPod nano Logo
1,047 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
