Question about Roper RS22AQXKQ Side by Side Refrigerator
The refrigerator on our Roper side by side refrigerator/freezer has frozen everything from veggies to milk. Any clue as to what the problem might be? Greg Russell
  • Roper Master
  • 8,220 Answers
Your thermostat has probably got its contacts withing fried together and it is not shutting down.
Obviously the compressor and fans are working fine. It has to be in your control. Your ice box has a mercury based control. The temp is controled by it and nothing else. It can fail by burnt out contact. (open) OR Fried together contacts (stuck together won't shut down). OR Loss of mercury in the probe.OR kinked probe.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 14, 2011
SOURCE:
Kenmore Model 10654613300 Freezer over freezing
In the freezer side there is a panel in the back. behind the panel are the evaporators. over the evaporators are heaters you will find one of then broken from water dropping on it the bottom one was broken on mine. put a fan to the freezer and thaw it out. get the model and serial numbers and look on ebay.com. or there is a place called http://www.repairclinic.com/
These are not hard to change but above all UNPLUG THE FRIG OR THEY MAY PUT YOU IN ONE.
Hope this helps.
Sep 21, 2014 | Kenmore Elite Side By Side Refrigerator -...
Our 2004 GE gsl251grb bs refrigerator is freezing food.
1st try cleaning the condenser core cooling fins
Aug 23, 2017 | GE Refrigerators
My refrigerator Kenmore model 795 77563600 freezes up the vegies on the left side drawerand werever I store on top of that drawer. What can it's wrong with it?
Your refrigerator as cooling tubes that allows the cold air or the freezer to go to the refrierator side. If one becomes blocked with frost all the cold air is then forced to route through the other cooling tube. And that what it sounds like is happening to you.
Jan 04, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer not freezing ice cream and milk
Icecream is a tough call. Some brands have to many artaficial ingredients and that doesnt get solid. What temps are you getting in the freezer? Is everything else frozen solid?
Jul 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
No Water
is there stuff freezing in the veggy drawers water storage is behind it, if not find water valve test for power to it wile button is pushed the one with the larger line is the one your testing if you got power replace it
Jun 18, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Some items in freezer are not frozen: bread, cool whip, etc. Meat and veggies ARE frozen. any idea?
This is normal for these particular items. They don't "seem" to be frozen but they are fine. If everything else is frozen that should be, like, ice cream, ice cubes, frozen vegetables, then you don't have a problem. Do make sure your freezer is not building up ice anywhere and that the door is completely shut when you close it.
May 22, 2009 | Refrigerators
Ice Maker problem
Problem is either that the water is spilling over when the ice tray fills or the ice shut flap is not closing correctly allowing warm air to enter the ice bin. Regards Advisor
Aug 20, 2007 | Maytag MSD2758G Side by Side Refrigerator
Water always inside refrigerator sometimes ice forms
LadyBlues, This is a top mount freezer. What's happening is that the drain in the freezer area is frozen over. When the unit goes into defrost, the water is running into the refrigerator area instead of going down the drain hole. You will have to remove the freezer bottom panel and then the freezer rear panel to unclog the drain hole. It will be under the evaporator in the drain tray. Use some nice hot water from the microwave and pour it into the tray until the water flows down the drain tube. This should clear up your problem. Catriver.
Jul 12, 2007 | Roper RT14DKX Top Freezer Refrigerator
Roper RS22AQXKQ Side by Side Refrigerator Logo
48 people viewed this question
Top Roper Refrigerators Experts
Steve Allison
Steve Allison
Sal De
Bruce Denton
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
