Question about Edirol UA-4FX External Sound System
Sound device hello i am a student of class 9th my problem is .westerday night i removed sound device from add or remove program. i dont knew that after removing my sound device will not work .now i am asking you at the moment what i can do?my sound device is not working. please give me some solution &email id if you have
  • nell02 Apr 06, 2009
    i cannot play music there a problem with my sound device
Obrigado
Posted on Sep 16, 2008
  • pitir72 Sep 16, 2008
    obrigado
I accidentaly remove a prorgram in my computer using add and remove programs... and unfortunately i think the program i have removed was for my audio devices.. now my computer has no sound... even as i...
You've most likely removed your the program for your sound card. You should have a cd that came with your computer/laptop that will have the drivers for it.
If you don't, you will need to look for the model of your laptop or motherboard and then go to the manufacturers website to download it.
Laptops are the easiest as they are easy to identify the model.
Apr 05, 2010 | Microsoft Windows XP Professional
Tip
Make ESET NOD32 Anti-Virus Auto Scan Flash Drive
Everyone doesn't want computers infected with a virus. The question is, where the virus entered into the computer. There are two possibilities, may be infected from the Internet or external device (flash drive, memory cards, external hard drives, etc). Flash drives are external devices that are often used. When we insert the flash drive to the infected computer, flash drive will be infected with the virus. In a flash drive that is infected, will form the autorun.inf file. Autorun.inf files will work automatically, every flash drive is inserted. Setting the default operating system is windows autorun when inserted an external device. Autorun windows, used by the autorun.inf, to enter into the computer. To protect your computer from viruses, there are a few things done:
1. Update anti-virus
2. Setting anti-virus in the guard position
3. Turn off windows autorun
4. Make anti virus auto scan flash drives
Turn off autorun Windows
Win Xp : Press START - run - regedit - HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer - NoDriveTypeAutoRun - Value Data - Type = ff - OK
Win Vista / 7 : Press START - Control Panel - Hardware and Sound - Autoplay - uncheck "Use Autoplay for all media devices" - SAVE.
Using software USB Safely Remove. Open software USB Safely Remove - click View - Options - Global Autorun - After device plugging - click Add process to launch list - click browse, open directory C:\Program Files\ESET\ESET NOD32 Antivirus\ecls.exe - Open - then double click the drive letter, to add parameter %DriveLetter% - then, on the tab File name and parameters, write /log-file=c:\report.txt /log-rewrite /aind - OK. Then. click Add process to launch list - write "C:\report.txt" - then unchecked "Wait for the process to finish" and "Launch the process for drives only" OK - FINISH.
on Sep 26, 2011 | ESET NOD32 Antivirus
I go to install my home and student software and it says an error has incurred while trying to install
Error message when you try to install a 2007 Office program: "Microsoft Office <Product_Name> 2007 encountered an error during setup. Error 1714"
To work around this issue, use the Add or Remove Programs feature in Control Panel to uninstall the earlier version of Office. To do this, follow these steps:
  1. Click Start, click Run, type appwiz.cpl, and then click OK.
  2. In the Currently installed programs list, click the Office program that you want to remove, and then click Remove.
  3. In the Add or Remove Programs dialog box, click Yes.
After the earlier version of the Office program is uninstalled, install the 2007 Office program.
Jan 16, 2010 | Microsoft Office Home and Student 2007...
I have windows installer keep popping up with homestuden is on a network unavailable and this always pops up when i log on to my computer and also i guess my microsoft.net framework 2.0 service needs...
After the earlier version of the Office program is uninstalled, then install the 2007 Office program.
Can't get office to install; "encountered an error during start-up"
Hello
Thank you for using
FixYa for your problem
This issue may occur if the following conditions are true:
  • An earlier version of the Office program is installed on the computer.
  • This earlier version cannot be uninstalled by the 2007 Office program installation program.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 22, 2009 | Microsoft Office Home and Student 2007...
McAfee says it won't install unless I remove Webroot Spy Sweeper. I never knew I had it and can't find it in add/remove programs list. How to find and uninstall when it's not in add/remove?
just had same problemheres how to fix in 30 seconds or less.........Go to Start/Run and enter regedit hit the Enter key.
Go to:
\HKEY_LOCAL_MACHINE\SOFTWARE\Webroot
Delete the webroot folder
Aug 04, 2009 | Webroot Spy Sweeper (spysweeper) for PC
07 home & student product key will not work
A: Check for the multiple verison
R: If found Uninstall from the add and remove programs and try re installing it
There might be office 2007 system in add and remove programs uninstall it of you havge oone
Feb 18, 2009 | Microsoft Office Professional 2007 Full...
Can't remove or add knew stuff to my zune!
you plug it in the computer,go to the zune program,go to "device"and go to whatever you wanna delete and right click and go to "never sinc with with....."and its gone
Dec 15, 2008 | Microsoft Zune JS8-00001 Digital Media...
On my new HP computer, Office Home and Student 2007 is factory installed for a 60-day trial. I bought Office Home and Student 2007 locally and have tried to install it, but do not think it will install as...
Go to Control Panel>Add or Remove Programs and look for the Office Trial. Click on "Remove", then try to install the new software.
(BTW, any other not wanted pre-installed software programs can be removed the same way.)
Sep 15, 2008 | HP Computers & Internet
Edirol UA-4FX External Sound System Logo
61 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
