Question about Zenith IQB60M92W 60" Rear Projection Television
Zenith IQB60M92W 60in Rear Projection
My television was working fine and i turned it on this evening and the picture has shrunk in size. It has shrunk from top to bottom and the image has a bowing effect with horizontal lines in it. Any idea what component may be bad.
    Novelist:
    Champion:
  • 277 Answers
Sounds like some kind of local interference. The first thing I'd try is disconnect the antenna input. If the wavy line goes away, it's probably something coming in through the antenna. Then I would start shutting off the circuit breakers until I was down to just the one the set is plugged into. If it goes away I would start flipping the breakers on, one by one until the noise returned. If you can isolate it to one circuit, start looking at everything that is on that circuit. If all else fails, call a TV tech.
Posted on Oct 02, 2005
Missing the hd antenna
I doubt the set listed here ever came with a hd ANTENNA.---what are you trying to do?
Jun 06, 2012 | Zenith IQB60M92W 60" Rear Projection...
Picture goes into an hour glass shape. red/orange color on one edge of the hour glass and green/blue color on the other edge.
You have a bad cap or two in the horizontal deflection [Pincushion problem] and you may have to look for a burned resistor. Use your vision to inspect burned areas on the board, this will most likely tell you where the problem may be. Area should be between the Vertical and Horizontal deflection. Look for the flyback transformer that is the board you are looking for! Hope this will you a good start. Thanks for asking!!
Oct 11, 2009 | Zenith IQB60M92W 60" Rear Projection...
Blue Bands on sides of Zenith Projection TV D60WLCD
Go to the Zenith repair site. This has been resolved in a lawsuit. Zenith will fix it free of charge through 7/1/2010. The shop just picked my up to replace the light engine free of charge. Call 1-800-228-1757, have your model number and serial number, and where you purchased it. Here's the neat thing-the question I asked is "have they fixed the problem with the light engine, or is it going to keep going bad?" If happens again (blue lines/spots) before 7/1/2010, they'll replace the TV with a new and different TV of equal value!
Dec 23, 2008 | Zenith IQB60M92W 60" Rear Projection...
Sound but no picture 60in phillips television
I beleive you can get a chip to fix this problem from www.magnavoxhelp.com.
Aug 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Zenith rear projection 60 in a60m91w1
The power supply section is not working.
Common possibilities are:
- Convergences amps have failed overloading the supply
- High-voltage section (flyback transformer) has failed
(happens sooner or later, about 8 years typical))
- CRT tube has failed overloading the supply
- Power surge has popped the power input circuit.
(Fuse, rectifier diodes, turn-on relay etc)
- One of a hundred of electrolytic capacitors has failed short overloading the supply. They dry out with age, are cheap to replace, but hard to find which one it is.
- Or any of many other possibilities.
In short, you need a experianced tech to troubleshoot this.
Feb 14, 2008 | Zenith IQB60M92W 60" Rear Projection...
No picture no sound
replace your power supply broad.
Jan 25, 2008 | Zenith IQB60M92W 60" Rear Projection...
MY ZENITH MODEL # Z60Z83R8 BOW'S VERTICALITY
You have a problem MOST LIKLY!!, that happens to almost if, not to all projection tube sets ever made. Its the old bad convergence IC falure. It's not something you can do unless you have had exstensive electronic training and soldering skills. There are no user replaceable parts inside of this set so please call out a pro to repalce the convergence IC for yop! A repair such as this should cost around 250 to 400 bucks, depending where you live..Good Luck
Aug 04, 2006 | Zenith IQB60M92W 60" Rear Projection...
Zenith IQB60M92W 60" Rear Projection Television Logo
82 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
