Question about Brother MFC-7820N Printer
Not able to send fax to an eFax number
My MFC-7820N is working fine. I can fax to a regular fax number, but when I try to fax to an eFax number, a fax connection is not completed. I can hear the fax tone start after the second ring but then it drops, it does not continue to make connection and I don't hear the fax connection tone as I hear when faxing to a regular fax machine. This same sending feature was working fine all along but suddenly started acting up recently. I have already changed the Compatablity to Basic and I continue to have the same problem of not able to send a fax from the MFC-7820N to an eFax number.
I've had the same problem before. I don't know if it will solve your problem directly but I can offer a work around or two.
1. I have an efax number but with a company called callwave.com , I fax stuff to other customers using callwave and my MFC 7820n completes each fax successfully. So if you can get yourself a callwave efax number you can fax to yourself and forward fax as an email to your intended party.
2. Or, you can use your mfc 7820n to scan your fax docs as a pdf directly to your computer and then emailing them to your intended party.
Unfortunately it might be a brother issue because at the office when I use the hp fax machine instead of the brother machine, the hp faxes to efax numbers without a problem.
Posted on Oct 22, 2008
Fax automaticaly daling #365 etc like tha number how can reset my MFC 7450 printer
Found this here...
(For MFC-7420)
When you turn off the MFC's power switch its memory will be cleared. To check
whether the MFC has faxes in its memory see Checking if the MFC has faxes in
its memory on page 11-5. If there are faxes you need to save them before following
the suggestions below (See Transferring faxes to your PC on page 11-5 or
Forwarding faxes to another fax machine on page 11-5).
Turn off the MFC's power switch and then turn it on again. If the error message
continues, leave the MFC for several minutes and try it again.
Check the settings in your application software to make sure it is set up to work
with your MFC.
(For MFC-7820N)
continues leave the MFC for several minutes and then try it again. (The MFC can
be turned off for up to 4 days without losing faxes stored in the memory.)
Looking through this manual, this is the only solution that I could find. There are options on the 7820N model in the menus that will allow you to reset the printer itself, and i quick search through the above link for "printer reset" should bring you to the menu selections for that.
Jun 29, 2011 | Brother MFC 7420 All-In-One Laser Printer
Im using the Brother MFC 7820n at a hotel. how do i fax? i've tired 9+1+area code+the number, 9+area code+the number and a few others but nothing seems to work, what am i doing wrong?
Depends on the hotel.
Some have a specific dedicated line that allow direct dial (no 9). Some block long distance calls and required the use of a calling card.
Otherwise, dialing 9 should work.
Can you hear the dial tone? What kind of sound do you hear when it fails? Is ti list a fast busy signal? Or do you just hear nothing?
If they have the speaker off, try to call your cell phone from the FAX just to see if it can make an outbound call at all.
Also, try tracing the wire from the fax machine. Make sure it is plugged into LINE and not PHONE. (or the jack with the picture of a wall jack, not a picture of a phone). Some hotel patrons disconnect FAX machines to use the phone line on their laptop modem and then neglect to properly reconnect the fax machine. Also make sure it is connected at the wall.
Apr 20, 2011 | Brother MFC-7820N Printer
Cannot send or receive faxes
Try to call from your fax if u make calls then the line is ok,if not check the line.check the cable have 4 pin ,Take the user settings in the reports menu,check and confirm the mode is "tone" if its "pulse" change it as Tone.
May 05, 2009 | Brother MFC-7820N All-In-One Laser Printer
Fax Confirmation Page
I used another website that allowed me to look at a printable version of the manual I needed.
Dec 01, 2008 | Brother MFC-7820N Printer
Brother MFC 7820N
how do i program one touch dialing on my brother MFC 7820N fax machine
Sep 09, 2008 | Brother MFC-7820N Laser Printer
Fax machine stoped receiveing fax
First, check your fax's phone line. Put a regular phone on it and check for dial tone and line noise. If the line is dead or noisy, this will cause a problem.
You can also try dialing your fax number from another phone and see if the fax unit picks up the line and starts initiating communication. (sounds like modem noises)
Jul 30, 2008 | Brother MFC-7820N All-In-One Laser Printer
Fax problem
For some reason the fax doesn't seem to work.
Need help badly
thanks MMD
May 11, 2008 | Brother MFC-7820N Laser Printer
Communication error
keep the window closed ok? that's more along the lines of the phone issues, than the fax machine itself..there are many ways to outwit the phone tree issues, but each number would need to be encoded directly.
solution?
get a dedicated inexpensive fax machine, or use efax.com
Apr 18, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Brother mFc 7820
I had work done on my laptop. I have a Brother MFC 7820N printer, scanner,fax,copier. I cannot find my cd for setting the drivers to have my laptop use the 7820N. Where can I pull the information down on line to enable my laptop to use my printer?
Shaun at WardLF357@aol.com:
Oct 17, 2007 | Brother MFC-7820N Laser Printer
Brother MFC-7820N Printer Logo
1,124 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
