Question about Xerox Office Equipment & Supplies
Copier 5309 works and starts process of copying, but paper comes out blank. Can this be caused by bad copy drum? any suggestions are appreciated. Thank You, Greg Szymanski
  • 48 Answers
Yes. change the photoconductor first, if the same thing happens after replacing the photoconductor, replace the fuser.
Posted on Sep 05, 2008
Whats the cause of a blank copy in a copier machine Nashuatec,Ricoh or Gestetner machine
can be several causes.
1-Tansfer rollers or wires broken or not charging.
2- no charge to the drum
3-laser unit --could be the shutter not opening or bad laser(should give a code if bad laser)
4-Developper not charging and transferrring toner.
If you can open machine and cheat door to make copier run, make a copy and stop paper as it gets to drum you should see toner on the drum. If there it is not transferring to the paper problem should be the transfer roller or wires(directly under drum. ) If not you need a tech to determine which one is not working.
Sep 05, 2012 | Standard Registar SD650 Color Copier
Dont copy the paper out with out any word copy
you didn't mention you copier type but this some tips to solve your problem,
possible cause for blank copy inmost copier :-
  • the developer unit disengage ( tray to reinsert the developer unit correctly)
  • the main corona didn't work or sparking ( It is located in the upper of drum unit try to clean unit and re attache it properly)
  • the drum unit didn't rotate
I hope this helpful
Feb 07, 2011 | Office Equipment & Supplies
My al-1631 gives blank copies. just replaced toner. no warning lights of any kind. no message lights. it just prints out blank paper. could it be the drum? can't find instruction manual. purchased...
Was the copier working fine before you changed the cartridge? If so I think your cartridge is the problem. If it started making blank copies right after you changed it. If this is not the case the first thing I would say is it is not the drum. Try opening and closing the right side door. There are contacts in the door that will cause blank copies. I have had several customers do this and it fixed the problem. You can also try pulling out the toner and then pull the drum unit partially out and re-seat it. Then re-install the toner.
Good Luck
Jan 05, 2010 | Sharp AL 1631 Copier
Copy coming out blank
Normally a blank copy is caused by the image not being transfered from the drum to the copy paper. Which indicates a problem with the transfer step of the process, check for a bad transfer roller or a bad transfer belt. If this is not very obvious, run a copy and try to turn the machine off or open the front cover during the copy process when the copy paper is about half way under the drum and check for a toner image on the drum. If there is no toner image on the drum you may have a developer problem, broken drive gears etc. But if there is a toner image on the drum but no image on the paper then it is a transfer issue.
Sep 15, 2009 | Office Equipment & Supplies
Copies blank
This is normally the corrona wire that needs to be replaced in the transfer unit and drum unit.
Sep 14, 2009 | Minolta EP4000/5000 CS/PRO Copier
Xerox 5309 - ghost image on the second half of the print
Has to be a roller problem. First check that the drum is being cleaned properly by the drum blade, it is responsible for cleaning the leftover image of the copy/print before it ( when you remove or look at the drum you should not see an image or toner ,it should be clean , if not replace  drum and blade). Next check that the upper fuser roller is not damaged ( This is the rollers that heat up and fuse the image into the paper  ). If these check out it could be the erase array or laser unit ...Good Luck
May 03, 2009 | Office Equipment & Supplies
Print quality
Ghosting can :
1-prints on the fuser roller, check if yes try cleaning it off, wait until it cools off
2-blanking lamps dirty or not working,(deletes image off the drum, before it gets ready to accept a new one)
BL mirror-(new image)
drum
3-Bad drum (although I doubt it this far in the process.)
Sep 05, 2008 | Ricoh Aficio 1013F Copier
Al-1631 Sharp copier
You could have one of several problems. Seeing as how you just replaced the toner, it could be a defective toner. Did you have the trouble prior to cartridge replacement? Did you replace it with OEM or after-market/refurbed stuff? You could also have a broken corotron wire. On the right side door is an assembly that has a very fine tungsten wire strung across it. This wire places a charge on the paper to "pull" the image off the drum. if it's broken, you will get blank (or almost blank) images). A 3rd possibility I have seen is that your scanner lock is on. Usually this will cause L1 codes, but I have seen cases where it didn't, and your scanner never moves from "home" position to scan your originals, again, resulting in no image being processed, and therefore blank copies. The scanner lock is under the scanner assembly (above the area where your copies come out) on the left side of the machine. It is a dial mechanism that can be turned to either the locked or unlocked position. It's hard to see, and you almost have to stand on your head to get a good view of it. It is not uncommon that in the process of removing copies from the "catch tray" area to accidentally brush it with one's hand, or watch, or ring, and spin it to the locked position. Certainly a bad drum can effect copy quality as well, but before spending the money, I'd check/re-check the other 3 first.
Feb 07, 2007 | Sharp AL 1631 Copier
51 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
