Question about Konica Minolta Maxxum 7D / Dynax 7D Digital Camera
Camera shuts off after one shot
I'm having a problem with my Minolta Max 7D camera. Its 3 years old, and with a fully charged battery will shut off after taking one shot. If I take the battery out - while the camera is still on - and re-insert the battery it will stay on as normal? What is wrong?
  • Anonymous Jan 10, 2009
    Mine does this also. Usually when I get ready to use the camera I'll take a picture to let it power off. Once I power it off and on again it works fine the rest of the day. However, I too would like a fix to this.
Set the camera to clean ccd mode and carefully remove the lens. If you can't see the ccd but only the shutter then the shutter is sticking. I have this problem when not using the camera regularly. My solution to free the shutter was just to set the camera to long exposure and just keep restarting the camera and taking a photo until the shutter moves. This problem happened from the very first time I had the camera run low on batteries at a few months old but at the time I never checked the shutter and the camera just restarted once and it worked.
Posted on Mar 08, 2009
  • axortagos Sep 02, 2010
    had the same problem, I indeed set the camera to BULB (M with shutter speed one click above 30secs) I take off the lens and keep press the "take picture" button and hold it pressed and with a little screw driver (be VERY careful) I helped the shutter move and thus get unblocked! some times its very tedious to make the shutter move whithout physically damaging the mechanism so be as careful as a good heart surgeon. this block occurs possibly due to the ageing and therefore due to the lack of proper lubrication of the mechanism that activates the shutter. There are some lubricants that someone could use to get this thing going if it ends up blocking too many times. many antioxidant-dust removers for electric/onic boards lubricants can do the job but only a tiny amount should be used and it should not be applied directly from the lubricant's hose but with a special brush while the shutter is allowing the sensor to accept the ambient light. it worked for me!
Try resetting the power save option or restoring the defaults on tools menu (3)
Posted on Dec 16, 2008
Anti-shake problem
symptom 1: referred to as FFB (Firts Frame Black). this is when you do not use the camera for a while and when you attempt to take the first snap shot, the Shutter is either stuck, or takes a blank/black picture (some cases the picture came out bluish). Sometimes the camera would freeze and you would need to remove the battery and re-insert it in order to reset the camera. Usually the camera comes back to life and and is usuable for a while until you store it. Sony will fix this free as they identified it as a design flaw in which the remedied (incorrect gear size for the Shutter charge assembly). Contact Sony support as they own all Minolta camera assets and tell them you have the FFB or First Frame Black problem and they will set up a ticket and instructions on where and how to send it.
symptom 2: Camera does not respond at all to the shutter release. Focus is fine, menu works, every function works no problem except for the most important - taking a picture (releasing the shutter). When you first turn on the camera, you hear the Antishift module attempt to center the CCD with a series of clicking noise for 5 or so seconds (not a good sign, also called the death rattle). All 5 AS bars in the view finder are blinking. In this case, the Tebure Assembly (AS Module) has failed and will need replacing. This is not cheap - sending it in to Precision Camera will run you around $250-$280. You can do it yourself if you order the assembly from Sony: Item - ( TEBURE ASSY ), U3008233U, $118.22 ea. via 1-800-488-7669 (will take 3-4 weeks). And follow the service manual to install and calibrate it (via the service manual download at http://www.dyxum.com/dforum/topic36109_post396839.html#396839).
However, if your camera experienced the FFB and then siezed (symptom 2) you can probably still get Sony to repair it free as its one charge for a complete camera repair. Call them up and tell them your situation.
Jun 02, 2009 | Konica Minolta Maxxum 7D / Dynax 7D...
Camera shut down
Hi the problem your having is that a component on the board isnt letting the correct power come from the battery therefore giving false reading on the batt display the huge problem you have is that they dont repair these cameras it just isnt financially worth it so unless you know how to test all components on the board the chances of getting it reapired are slim to none their isnt anything you can do as it is a board problem.
If you tested the battery and this is fine then the problem is deffinately with the board.
How long have you had the camera if its not long then i would get a refund as repairing is something they wont do sorry i couldnt help you any more but other experts will tell you the same
Feb 05, 2008 | Konica Minolta DiMAGE X1 Digital Camera
Troubleshooting
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Same thing happened for me after I did not use the camerafor a while with the dead battery left in the camera for a long time. After a while of reloading camera firmware and resetting defaults, I came tothis conclusion. You need to do a mock CCD cleaning on the camera which abuilt-in feature of the 7D, in which the camera locks up the mirror momentarilyso you can clean the CCD. But of course you do not need to clean the ccdat this point. Below are procedures to help get your camera back inoperation.
1.Try turning the camera off, then take out the battery.
2.Then replace the fully charged battery back in and turn the camera on but donot take any pictures.
3.Go to the menu of your camera and activate the CCD cleaning, which willactivate mirror lockup.
4.You will hear a mirror lock up/half exposure cycle sound.
5.One you hear this, take the lens off and make sure you can see the CCD but donot touch the CCD or allow dust to get on it.
6.Now place the lens back over the camera and turn the camera off.
7.You will hear the mirror unlock itself, then the camera will shut down.
8.Now turn the camera back on and start taking pictures.
This worked for me and my camera started taking better pictures; however, thesame problem came up again when I let the camera sit too long with a deadbattery. So I repeated the procedures and my camera is back.
My advice is never leave a completely dead battery in the camera. Alwaysstore fully charged batteries in the camera.
-Jay
Oct 25, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
CAMERA SHUTS DOWN
AFTER FOUR YEARS OF SERVICE, YOUR CAMERA MIGHT BE IN NEED OF A REPAIR VISIT TO CLEAR THESE PROBLEMS BEFORE YOU HAVE A COMPLETE FAILURE. I HAVE ENCLOSED A COUPLE OF SITES FOR YOUR INFORMATION AND BOTH GIVE FREE ADVICE AND ESTIMATES ON REPAIRS. PROBABLY YOUR BEST BET FORM YOUR POST. GOOD LUCK!
www.precisionCamera.com
www.xtra-range.com/camera.repair/Minolta2.htm
BOTH ARE HOTLINKS SO JUST CLICK ON THE SITE. IF YOU NEED MORE HELP, REPLY TO: ARCLIGHT1217. THANKS!
WHILE I DON'T ENDORSE ANY WEBSITE, I PROVIDE THEM FOR YOUR INFORMATION.
Aug 28, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Won't take pictures
Aug 07, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
BLANK (BLACK) PICTURES
Yes this is a common problem. Set the camera to take a long exposure shot (5 seconds) and with the lens off take a photo. Can you see the ccd or just the shutter (black)? If its just the shutter the shutter is jammed. It's basically a question of persisting with rebooting the camera and taking shots until the shutter frees itself.
Jul 23, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
CAMERA PROBLEMS
I had the same problem. Took picture; camera turned itself off after one shot; review of picture showed no image (black). Thought it was battery or card but battery fully charged. Took card out; turned camera on; activated shutter; camera turned itself off. Reinserted (same) card; turned camera on; took picture; problem solved. No idea why. Gary
May 05, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Minolta 7000 SLR
The Konica-Minolta 5d, and 7d, both discontinued but available used on ebay and other places will work with your AF lenses, as well as all the sony alpha camera bodies. KM sold their camera business to sony, and most of the whole maxuum/alpha/dynax group of engineers went with the sale to Sony. I had a 7000, and an 8000i, and all my lenses are quite happy on the 7D I picked up a few months ago on ebay.
Mar 27, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Minolta maxxum 7d
Have you checked to make sure your batteries are fully charged? Thats what happened to me after my camera had sat out in a cold auto trunk for a couple of hours.
Dec 19, 2007 | Konica Minolta Maxxum 7D / Dynax 7D...
LCD Display
I was cleaning my CCD and damaged the shutter. Same problem. Click to take a picture and the camera locks up and powers off. Turn the camera back on and the shutter releases and the camera resets and powers on. $281 service call later and Precision fixed it quickly. Replaced the shutter. They warranty their work for 6 months. Priced way too high, but nobody would touch it. As soon as I told other repair services how I messed it up, they turned me down. I had to much money invested in the camera to toss it in the closet.
Nov 24, 2007 | Konica Minolta Maxxum 7D / Dynax 7D...
Konica Minolta Maxxum 7D / Dynax 7D Digital Camera Logo
400 people viewed this question
Top Konica Minolta Cameras Experts
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
