Question about Fellowes PS60C-2 Shredder
Shredder won't grab paper
The green light is on, the shredder heads are rotating, but when I try to feed in a sheet of paper, the shredder won't grab it, it just sits there, the very edge gets a bit of shredding on it, but the paper won't feed through. I've emptied the basket, oiled the heads & made sure the slot & tab are aligned but it still won't feed. It worked fine yesterday. Not sure what to try next. Any ideas?
  • Anonymous Oct 13, 2008
    Problem is just like the other guy says. There was a clunking noise happened at the same time it stopped grabbing and which, in the past, has gone with oil. I've tweezered out every bit of paper, oiled - but it still rotates and won't grab the paper
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
There has to be something in the path.
once you put the paper in it triggers a sensor that rotates the blades and grabs the paper there is nothing else in between the entrance and the blades. get a flash light and lok in to see what is blocking the path.
unless there are some paper in between the teeth /blades, that need to be cleaned out.
Posted on Sep 05, 2008
How do I fix a staples spl tmc 10 paper shredder that does not feed?
It may be clogged with shredded paper. With power removed, examine the shredding mechanism and remove any bits you find. You may not be able to remove all of the bits but enough to restore operation.
Oct 09, 2014 | Office Equipment & Supplies
Shredder only hums will not grab paper
What sort of hum? Very quiet? Loud with vibration? Have you tried feeding anything else into the unit? Envelope? It's possible that you're not pushing the paper far enough in to let the shredder's teeth grab it.
Jul 24, 2014 | Royal HG140MX Shredder
Paper jam, what to do
Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Oct 12, 2013 | Embassy Intek Tx40b 4 Sheet Countertop...
Won t shut off
Blow out the sensors with some compressed air, Using a can of compressed air, look for the sensors that detect the paper and give them a blast or two, then try it, it may take a couple of tries.
This may also be a good time to lubricate the cutting heads, if it is a good machine with metal heads a light oil applied to paper then run through the shredder will pass the oil onto the heads.
A shredder oil or light oil like 3 in 1, these usually have a narrow nozzle to limit the oil flow, draw lines, do a picture or spell your name on the paper with oil and shred it. You have just serviced your shredder.
If it is a less expensive shredder with plastic heads, shredding a couple if sheets of waxed paper will pass the wax onto the cutting heads reducing friction.
Hope this helps.
Ed
Oct 01, 2013 | Office Equipment & Supplies
I have the CX6 shredder, the paper get jammed in the feed,can i oil the feed?
How to Oil a Paper Shredder shredder_oil.jpg Paper Shredder OilProper shredder maintenance is required by all paper shredder manufacturers to maintain warranty coverage. Perhaps the most effective way to care for your shredder is to oil the cutting heads regularly. Why should I Oil my Paper Shredder?
The frequency of shredder oil applications is determined by a number of factors. First of all cross cut shredders must be oiled more often than strip cut shredders do. A cross cut paper shredder will require regular applications of shredder oil while a strip cut can go for a longer period of time without decreased performance. Secondly, paper shredders that are used more will need more lubrication. A paper shredder under heavy usage will need oil about once every four hours, while one under normal use will only require oil once or twice a month. Most manufacturers recommend oiling the cutters once every 30 minutes of accumulative shredding, but an easy way to remember is just to oil your paper shredder every time you change the bag. The type of material as well as amounts fed at once can also effect performance and lead to the need for oil.
Directions
You should only use specifically designed shredder oil to oil your paper shredder. This oil is designed to lubricate precision heat treated shredder cylinders, and any other lubricant or oil will void the manufacturers warranty. So don't use WD-40 or the like to oil your paper shredder.
Shredder oil can come in both liquid and aerosol varieties. However, the most common is liquid shredder oil.
The first way to oil your shredder is to spray or squirt lubricant into the opening and onto the cutting heads. The oil is packaged in a squeeze bottle and is applied directly onto the cutting head in a fine stream. This is done through the paper entry throat. Take 1-2 seconds to oil from one side of the opening to the other. Turn the machine in reverse for about 10-15 seconds to allow the oil to transfer to all parts of the cutting head. The final step is to shred a few sheets of paper to remove any excess oil.
The other, and perhaps most common, way to oil your paper shredder is illustrated in the image above. Simply spread a small amount of shredder oil onto a piece of paper in a zig-zag type motion. Make sure that you spread the oil over the entire sheet. (NOTE: you don't need to soak the paper in oil, just ensure total and even coverage.) Feed this sheet through the shredder and then operate the machine in the reverse mode for a few seconds. This will make sure the oil is dispersed throughout the shredders cutting cylinders. The final step is to shred a few sheets of paper to remove any excess oil. You may want to repeat this procedure depending on the results, and is recommended for up to three applications to be assured of thorough oiling.
You should oil your cross cut shredder on a regular basis. If you are shredding a small quantity such as only 50 sheets a week or if you are using a small shredder, then you should oil your shredder every other day. If you are shredding a large quantity such as hundreds of sheets, then oil after 30 minutes of usage or after you empty the bag.
Start oiling your paper shredder now. The shredder will run smoother, faster, and put less strain on the overall motor, gears, and bearings.
Oct 03, 2011 | Office Equipment & Supplies
My VF 1012mx paper shredder won't feed the paper in order to shred it. Green light is on but nothing happens when I put the paper in.
Does it run in reverse.????
You may just have dirty "eyes" where the paper is inserted, OR they may be defective.
Jun 04, 2011 | Royal VF1012mx Shredder
Should the shredder ever be oiled? if so...where
Directions
Dec 16, 2010 | Office Equipment & Supplies
I have a Royal VF1000MF shredder. While shredding
Try running the shredder in reverse and oiling the blades. More assistance with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder back to good condition it looks like you might have to get a new paper shredder. Great place to learn about new paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Royal VF1000MX Shredder
Royal VF700 won't barely shred one sheet of paper. It givexs the overload red light when 1 sheet of paper has just barely started to be shredded.
Royal. Haven't heard of that brand. Could get in contact with tech service, but it's probably easier to grab a new paper shredder.
Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 24, 2010 | Royal VF700 Cross-Cut Shredder
All lights turn on as needed and has power but won't grab paper to shred
suspect paper jam try using reverse button the dislodge paper.
suspect paper feed sensor is blocked or damaged there is a light beem in front of the teeth that starts the shredder if this defective the shredder will not start.
suspect a panel or bin is not correctly seated causing the shredder to not start.
Nov 13, 2009 | Fellowes Powershred 320C Shredder
Fellowes PS60C-2 Shredder Logo
770 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
