Question about LG WM-1485FHD Front Load Washer
LG WM 1485 Washing Machine
Pump needs replacing how difficult is the task
SOURCE: LG WM-1280 DD front loading washing machine
Be sure the unit is level, not just stable,with the four feet touching the floor. If the unit is not level the centrifugal force of the spin cycle will be distributed unevenly, causing more pressure to be exerted in one corner then the other. this causes the unit to slighty lift in the opposite corner, thus shaking or vibrating. Many people citing this problem have their washers in an upstairs laundry room. Some of these houses may lack the needed support to sustain these washers without the floor flexing. the quality of the building is a factor.
Posted on Nov 30, 2006
BIKER T
  • 909 Answers
SOURCE: suspect drum bearings
most lg front loaders have the plastic outer drums which have about 16 h/duty screws holding the two halves together. extreemly tricky to strip to gain access to inner bearing and seal. Th/stat, motor, piping and other items have to be removed and dissassembled to enable drum to be removed. that repair i suggest for a service repair.
Posted on Aug 16, 2007
SOURCE: my washing machine does'nt start
Had that problem before. CL means child lock. You need to press the wash and rinse buttons together to unlock.
Posted on Apr 03, 2008
SOURCE: LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
Posted on Dec 14, 2008
SOURCE: lg washing machine wm-1460fhd door locked wont
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Posted on Jun 16, 2009
My LG WM 2010CW washing machine is showing this error "OE".
You have some drain problem, check drain pump, drain house, filter
Good Luck
Mar 15, 2013 | Facebook Apps
Wm-0642 ltw is not spinning
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | LG WM-2077C Front Load Washer
Mt LG washing machine (model wm2277hs) displays an error code containing an upside-down "F" and an "E". What part(s) do I replace?
Replace the thermistor, part # 6322FR2046C
It is located right next to the heating element at the bottom front of the outer tub. (just below the door gasket) It is very difficult to replace without removing the front panel.
Mar 03, 2011 | LG WM-2277HW Front Load Washer
Is it a big job to replace the bearing on a WM2277HW front load direct drive washer, and what kind if tools would I need.
quite a task if you have never done before . have a look at utube.com this will show you generally how to fit a drum bearing alot of time its simpler to replace machine
Feb 10, 2011 | LG WM-2277HW Front Load Washer
My washer keeps getting an error message and keeps stopping. It does this part of the way through the cycle. DO you know what would cause this?
There are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
INSTRUCTION BELOW
  • A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  • 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  • 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  • 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  • 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall
  • thanks and good luck.
    Oct 03, 2010 | LG WM-2277HW Front Load Washer
    Need to see diagrams for removal instructions for the drain pump on lg washing machine wm2277hw
    LG WFS7012ds model washing machine while starting of washing operation after start 5 min machine geeting stopped with beep sound
    Jun 21, 2010 | LG WM-2277HW Front Load Washer
    LG WM-2277HW will stop at the rinse cycle and flash te code. Manual says to unplug and call tech. Is there anything else that can be done?
    If you are having a problem with your top load washer then check out this tip...
    Washing Machine2_bing.gif does not Pump or Spin
    http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
    If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
    Front Load Washing Machine2_bing.gif not draining and or not spinning
    http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
    heatman101
    Jun 01, 2010 | LG WM-2277HW Front Load Washer
    How do you change drum bearing on lg wm-1290fhb washing machine
    It is a difficult job in terms of handling! You require spanners and bearing puller. You require one extra assistance to hold the drum and pull from the front.
    You have to change the full set of Bearings with same type and design. Check the bearing housing and the shaft before fixing new ones! Replace the water seals if any
    Apr 05, 2010 | LG WM-1290FHB Front Load Washer
    My lg front loading washing machine does not start
    sounds like you have a faulty door lock and it will not turn on if it cannot lock, you will need to get it replaced. Look around at different repair shops as some charge more than others
    Jan 14, 2009 | LG WM-2277HW Front Load Washer
    LG WM-1485FHD Front Load Washer Logo
    37 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
