Question about Kenmore 24032\24036 Top Load Washer
Kenmore top loader Model 110.20712990
Jsrock,
Appreciate you putting this information here for us. On our Kenmore that is about 6 years old we are getting the clicking / grinding sound as the washer is agitating. An additional problem is during spin cycle with heavy loads we need to give the tub a nudge to get started. Does this sound like the coupler you have referenced here? If so, would you be so kind as to forward me the repair procedure to sorzillo@optonline.net?
Thanks in advance,
Scot
  • dablues Jan 07, 2009
    I had the same problem and have now replaced my second motor coupling.It's really an easy job for most folks.My problem with my latest replacement was the gear case is also going to need replaced.Part of putting coupler on if your not careful is breaking that seal around the shaft of the gearbox(who knew it could hold that much oil) anyway have the old one out and waiting for the part to come in to my local appliance repair shop(one day,gave me a discount probably cause he felt sorry for me) price I believe he quoted was around 150. plus tax. My question is do you have a linc showing this repair,I may have confused the order in which I was removing the portion of the clutch that attaches to the shaft of the gearbox.Hard to make out on my schematic.
    You guys are great,and in these tight financial times this advice that you provide is priceless!!!!
  • 5,911 Answers
It could be the coupler, but I doubt it. More commonly, this is the symptom of a gearcase (transmission) going bad. Couplers typically just snap off or the center hole rounds out causing it to slip. The result: the washer will fill and drain, but will not agitate or spin. The telltale sign of a bad gearcase is the grinding noise you mentioned and the requirement for you to assist the spin under a load. In addition, if you inspect under the washer, sometimes the gearcase will begin to leak a honey colored oil. You may find droplets under the washer, and in extreme cases, you may find spray patterns along the interior cabinet walls.
Now before the sense of panic sets in, replacing a gearcase on this model washer is not that difficult and it can be accomplished by the average do-it-yourselfer with some guidance. I have a link that explains step-by-step how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
Read through the link thoroughly and see if this is job that sounds like you wish to attempt on your own. No special tools are required. A screwdriver set and socket set is all you should need.
A replacement gearcase can be found at searspartsdirect.com. Just type in your model number and locate item number 9 under the "Brake/Clutch/Gearcase/Motor/Pump" heading. The part number is 3360629. If you are going to replace the gearcase, it is also recommended that you replace the motor coupling as well. The coupling is listed under the same heading as item number 13 (part number 285753A). You can also check out repairclinic.com to see if they carry the parts any cheaper. Use the part numbers provided. I will post the link that explains how to replace the coupling as well:
Many of the steps are a repeat, but I try to be thorough. Some of the original motor couplings that came from the manufacturer would not last long under constant use, because they were made entirely of plastic. The manufacturer modified this part to include a steel grommet that makes it much more durable. The new part is listed with the part on the website, and included in the link I provided.
NOTE: If you do order a replacement gearcase make sure you follow the instructions on the outside of the box. There should arrows indicating that the gearcase needs to be shiped in the UPRIGHT position. If not, transmission oil will leak.
I hope you find this information helpful. The staff asks us to refrain from direct contact with the consumer and only allows us to answer questions in this forum. I hope you don't mind. Let me know if you require additional assistance.
Posted on Sep 05, 2008
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Top loader does not spin fast enough to spin dry.
possibly the clutch is slipping, i've heard you can take a #10 washer and put it in one end of your clutch spring caps and that would tighten it up
Mar 23, 2010 | Kenmore Washing Machines
What is the capacity of Kenmore model
This may or may not help.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0305295.pdf
Nov 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
10 year old top loader, stops midway thru cycle
turns out it was the opening and closing the lid while trying to get it to run again. I placed a screwdriver in the hole on the lid sensor deal and it kept running so I order a new stinger or what ever you call the deal on the lid that goes in to the hole. I was going to order a timer until I read your emails on your web site..saved me a lot of money. THANKS
Sep 05, 2009 | Kenmore Washing Machines
Kenmore elite top loader
Call or email the consumer feedback or make a complaint to Sears. I had a similar prob. Sears ending up replacing rhe washer and paying for rental. Took up to 3-6 months, calling and writing complaint letters.
Jun 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Trying to figure out Cu. ft. capacity
hi wanda, most top load whirlpool units, they make the sears kenmore models, are around 3.0 cubic feet.
its not that important for a top loader, but when going to a front loader thats how they rate them.
what i would recommend is you buy a unit that will do the laundry that you will need to do for the next 15 years.
what i mean is if you have 2 or more young children, that you will be doing laundry for the next 15 years, then a full size front loader would do you good. size 3.5 c/f or larger, like a whirlpool he4 or he5.
if it is just for 2 people then a smaller unit would be better, like a whirlpool duet or sport model.
the reason for the choice is a front loader needs to be filled up for it to work properly. doing smaller loads in a front loader will cause them to shake and not work as well.
now be ready as the new washers will cost about 1,000 bucks.
another suggestion for 2 people would be the whirlpool cabrio top loader. i like them alot and they have very few parts to fail and have a good reliability.
good luck and happy shopping.
p.s. remember sears will match prices and give you 10% off the best price!!
Jan 30, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washer Top Load Series 60 won't drain
The water pump is a belt-driven device actuated by a clutch. Your problem could be:
1. Stuck pulley - break it loose and WD-40 it
2. Broken belt - replace
3. Bad clutch - call repair or replace
There is almost nothing that can go wrong in the pump itself. It's probably one of these three.
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Agitator on my washing machine is not rotating the way it should. It seems something is not catching and the piece is only rotating part of the time.....please help. ps How do I remove the agitator to see...
Remove the cap off the top of the agitator. Then remove the 7/16 bolt below. Your problem is inside the top part of the agitator. YOu need to buy an agitator dog kit. When the part is removed you will see how to put it in.
Dec 11, 2008 | Kenmore 15944 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
827 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
