Question about Sharp AL 1631 Copier
Sharp AL1644 Hi, I have a Sharp AL1644 with the code H2. I have been told that there is no reset code for this machine and that I have to replace the fuser, could you either confirm this or let me have the reset code? Thank you Carole
  • Anonymous Oct 13, 2008
    I had power outage and now 4 H flashing and I can restart copier at all how do I reset the copier
  • Sharp Master
  • 2,794 Answers
The error code happens because the fusing temperature isn't getting to the right setting in time. No reset code is available for the fuser unit. It could be the thermistor that has gone bad with it but usually on this machine it's better to get the whole fuser assembly replaced.
Posted on Sep 05, 2008
Sharp AR- m205 error code h2
Hi
Should probably read H2-00, which is your thermistor in the fuser. Open door on right, three screws hold the fuser in (hot bit), release fuser slightly, being careful as it is still connected, the thermistor is sat in the top, you should be able to reset it by pressing the little button and you should here it click. re-fit fuser and secure.
To reset the code, press these buttons:
Hash, interrupt, clear, interrupt., enter 14, then the print button.
Cheers
Andy
Feb 17, 2014 | Sharp AR-M205 Copier
How to initialize SHARP 5127 after Code error H2-00 appers
Hi Ambroise,
The error H2-00 means there's a problem with your thermostarts/fusing unit.You need to check them for they may be blown.Replace the fuser if damaged.To reset the code,push P*C* then 14 and then press on the start button[the one you use for copies making].The code is reset.If not,then you need to replace the fuser.
Hope this helps.Thanks!
Please rate this answer.
Nov 17, 2011 | Office Equipment & Supplies
Sharp AL-1631 Fuser Unit
The fuser codes are only H2,H3 and H4. To reset , press C, Exposure, C, Exposure.Display goes off enter 14 press print.
Nov 05, 2009 | Sharp AL 1631 Copier
Sharp 5320 H2 error code
this is a fuser error message. You must fix the problem causing the fuser to post an error. Then clear the message.
Jun 19, 2009 | Sharp AR-5320 Black and White Copier
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
SHARP AR163 Displaying H2 error code
Dec 11, 2008 | Sharp AR-163 All-In-One Laser Printer
Sharp AR-275 Getting H2-00 Erron on power on
In AR 275 Sharp copier H2 00 is very common problem, U have to only reset the above fuser error code as fallows
press # then intrrupt then c them intrrupt then display will show simulation mode then enter 14 then press ok key
If this is not enough then press press thermostat on fuser unit by removing the unit from machine this requires tech knowledge
OR you can try by replacing thermistor of fusing unit
If by above procedure the prob is not solved then and then you replace the fusing lamp
Even though u can check the lamp by removing back cover and turn on the machine u can observe the light of fusing lamp
pl ask for any difficulty.
Sep 18, 2008 | Sharp AR-5320 Black and White Copier
Message H2-00 in sharp ar m207
You have an open Thermistor in the fuser unit or the code is false caused by power surge. To reset it, press P*C* and hit 14 start, then hit either ok or start again and machine chould reboot and clear code. If code returns then the thermistor is bad. You will have to have your local dealer replace either the themistor or the entire fuser unit.
Aug 08, 2008 | Sharp AR-M207 All-In-One Laser Printer
H2-00 Error Code, cant clear
Sounds like a tough one, take off the back cover and make sure all connectors are making good contact. You may have a fault in the main logic board.
This might need a tech to check out.
Hope that helps...
Apr 25, 2008 | Sharp AR-M277 All-In-One Printer
H2 Error
You have a thermistor open. That means that the device that reads the temperature in the fusing unit, has broken. You will need to replace the fusing unit to fix this problem. You could try a Sim 14 reset. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
Dec 31, 2007 | Sharp AR-5320 Black and White Copier
Sharp AL 1631 Copier Logo
232 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
