Question about Hotpoint NWSR483EBWW Electric Dryer
Squeaking due to weight of clothing
My wife's dryer squeaks when she places a normal size load of clothes in it. She cuts the load in half and it squeaks less. As the clothing drys, the squeak dissipates...less water...less weight.
Do you guys think it might be a motor issue??
  • Anonymous Feb 14, 2009
    They replaced the drive pully and the belt, and it still squeaks, but not as bad.
  • Hotpoint Master
  • 19,396 Answers
When you need this kind of noise and there is no abnormal vibration, then it depends on the drive pulley that pull the belt.
If it depends on the weight, and you get vibration it can also depend on bad dumper pads.
Here you can locate dumper pads and drive pulley below the tub.
Both parts are serviceable, repair should not be expensive.
If you need to contact a repair service, you can use the number listed on the owner manual.
Posted on Sep 05, 2008
What is wrong with my dryer?
the squeaking could be due to bad rollers or pully system? if the drum is not tight and sitting correctly on the pulleys it will allow heat to escape? check these as well
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Oct 19, 2014 | Dryers
My Frigidaire Gallery dryer squeaks and leaves brown crescent burn marks on our laundry items.
If you live in Pasadena, CA and you need a Dryer repair service our professional technicians will perfectly repair your dryer as fast as possible. All you need to do is to call at (626) 460-0903 or visit our website http://www.appliancerepairspasadena.com .
Dryer repair Pasadena CA Bosch LG Electronics Amana Beko
Sep 02, 2017 | Frigidaire Gallery Series GLHS269ZDB 36"...
My dryer was squeaking really bad, so I sprayed WD 40 on the pulley & belt, squeaking stopped but the dryer also stopped turning. The pulley still turns but the dryer drum doesn't
The belt is slipping now. Need to clean the WD40 off, use methylated spirits, isopropyl or rubbing alcohol on a cloth.
Jan 02, 2011 | Dryers
My dryer started making a squeaking sound. It's
Belt needs to be replaced,have you ever had a car drive by and heard a squealing noise? dryer belts "glaze" and squeal due to wear just like the ones in your engine
Apr 01, 2010 | Frigidaire Electric Dryer
Loud Squeaking noise when drying clothes
Might be the issue with the rotor bearings.
2.Might be there is some dust or other thing in rotor drum so please check and clean.
Aug 11, 2009 | GE DBSR453EBWW Electric Dryer
High pitch squeak and removal of cloth support
try some felt from fabric store in same place
May 06, 2009 | Dryers
Dryer makes small holes (cigarette burn size) on clothes
Get a new dryer. Old ones tend to tear-up clothes and burn holes.
Apr 29, 2009 | Dryers
I have an Amana gas dryer that is squeaking. Does something need to be lubricated? If so can I do this myself?
Good Afternoon,
Lubricating would be just a temporary fix. You need to replace the drum rollers. If you think you can do it yourself I'll try to walk you through it. Once the rollers are worn they start squeaking and squealing at a very high pitch. This happens because the roller bushing spinning on the shaft has dried out from the heat. The weight of the clothes in the dryer plus the drum itself rests totally upon these rollers. If you decide to install new rollers clean up the shaft with lite emery cloth then wipe clean. Next apply "High Heat" Lithium Grease to the shaft and inside the new roller bushing, they will last 2 to 3 times longer. Let me know if you need guidance if you attempt to change the rollers yourself.
Have a great day!
Mar 26, 2009 | Amana ALG331RAW Gas Dryer
Irregular squeaking from stackable dryer
Post your make and model please. Sounds like the rear drum bearing is dried up
Feb 20, 2009 | Frigidaire FEQ332E Electric Dryer
Hotpoint NWSR483EBWW Electric Dryer Logo
260 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
