Philips Philishave Cool Skin HQ6760/HQ 6761 Logo
Posted on Aug 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My philipshave coolskin shaver doesn't work after it has been charged. when it is on the charging stand the green light is showing that it is being charged. Please help!! Ry
shaveroutlet.com
Level 3:
  • Philips Master 1,652 Answers
  • Posted on Aug 14, 2011
shaveroutlet.com
Philips Master
Level 3:
Answers
1652
Questions
0
Helped
765696
Points
4209
Your battery pack is probably dead and needs replacing. You will find the correct battery for model 5605X at shaveroutlet.com. See link below for item and also scroll down item page for installation tip videos
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Why have I got a red light on the bottom of my shaver when I am using it
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here: http://www.manualslib.com/manual/20281/Braun-5301.html#manual
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
capacity.
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
My braun 8975 has a flashing greenlight
its letting you know that the battery's are not charge or are not chargeable so change the battery's first then you will find out what's next.
9595 Charger won't charge while in stand
Your charging and cleaning stand is faulty. They are not repairable because parts are not available. You can purchase a new clean and charge stand at shaveroutlet.com
Braun Series 7 and Pulsonic Clean Charge Base
Help please. My Philips coolskin works fine but has various lights come on and go off. When switched on the amber light above the charging point comes on and stays on. The shaver head light flashes red for...
When the shaver head light flashes, this indicates that the heads should be changed. You will need the specific model number written on the shaver to select the correct type heads
2helpful
I can't get my Philishave Coolskin to accept a charge. Pretty sure that the charger is working as I was getting the red charge light but didn't get the green bar indicators as it charged. Any ideas
Most likely, the battery needs to be replaced. The symptom you describe would suggest this.
You can purchase a replacement battery pack for model HQ6740 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To change batteries you will need to remove the lotion packet cover on the back and then remove all of the screws on the back to remove the back of the case.
For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
3helpful
2answers
WHICH VOLTAGE HAS THE 2 BATERY PHILISHAVE TYPE HQ 6740/A
Input voltage : 100-240 V, 50/60 Hz
Power consumption : max. 9 W
Motor voltage : 2.4 V
Battery : 2x NiMH AA
Battery capacity : approx. 1100 mAh
Charging indicator : 1x duoLED green / red
: charge / battery low
Charging time : approx. 8 hours
Charging current : 200/25 mA time dependent
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
