Question about OKI MICROLINE 320 Turbo Matrix Printer
Disable Power Saver
How do you disable the Power saver?Thanks
I come Hong Kong, China.
My printer is Microline 320, it functioned weel but one smaal thing I want to get away from it. I use this printer once a week, after using I will power off and disconnect the power cable from the socket, and store it.( space problem ). Everytime I have to re-set the setting again, because my printing paper is 11.5 inches while the OKI 320 will return to factory setting of 12 inches. My request is how to fixed the setting into 11.5 inches all the time whenever I re-use the printer. Or will there be something wring for my printer?
awheha
Posted on Oct 13, 2008
  • awheha Oct 27, 2008
    I would like to ammend the above, The factory setting default is 12 inches, I have change to 11" to fit my paper. Can anyone help me to fix it when I restart the printer.
    awheha
Disable power saving mode
Sorry, but you will NOT be able to DISABLE the power saver mode on this printer. The printer will still go into "power saver mode", but it takes longer to do so, if you set diffrent as default time delay [ Two power saver modes: (1) print to standby mode 35 Watt, user-definable 1-30 minutes, default 3 minutes ; (2) print to powersaver mode 4 Watt, user-definable 5-60 minutes, default 10 minutes ].
See also:
Dell 1250C problems with sleep mode
Oct 01, 2014 | Dell 1320c Laser Printer
Disable screensaver LG PB66** series plasma
This should not happen, you can go into settings and alter the screen saver time out delay or disable it, select "none" in screen saver type.
Sep 28, 2014 | Televison & Video
How to disable energy saving on KitchenAid Range
The Energy Saver Mode deactivates the display to reduce energy
consumption.
To Activate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver on."
will appear in the upper text area.
2. The setting will be activated after 5 minutes.
Any cooking function may be used with the range in Energy
Saver Mode by simply selecting the desired function.
To Deactivate the Energy Saver Mode:
1. Press and hold OPTIONS for 3 seconds. "Energy saver off."
2. The clock will reappear in the display, and the range can be
operated as usua
Oct 10, 2012 | KitchenAid Ovens
How to disable the tecra m1 power saver feature
Go into the control panel and select add and remove and look for the Toshiba Power saver utility and click remove. If you are running windows 7 go to my computer and select uninstall at top.
Jun 08, 2012 | Toshiba Tecra M1 PC Laptops
If i try to bring back from screen saver using touch pad the screen goes dark and i can only just see faintly the desktop. i have to switch off and restart machine to get it back
u must remove screen saver and go in screen saver property than go on the power there are some setting u must disable the power option and hdd sleep mode too be disable good luck enjoy vote for my comment
Aug 06, 2009 | Computers & Internet
My nokia phones battery backup is very less
Disable bluetooth if you are not using it- Disable screen saver (power saver always enabled)
- If you are listening MP3's and you don't expect phone calls, enable flight mode (if you have 6.65 firmware)
- FM tuner eats lots of battery life, so you need to be aware of it
- It's not a bad idea to always carry a spare BL-5C battery (fully charged)
Jun 20, 2009 | Nokia N72 Cellular Phone
Stuck in power saver mode
Go the desktop, right click with mouse and select properties (if it XP) then it will open Display properties --> there you need to go to Screen saver and then to power option
Disable any power off mode on/ Sleep mode. It will solve your problem.
Please rate the solution. Otherwise let me know for further assistance.
Nov 03, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Energy Saver
On most copiers, you can't totally disable it... it's all part of that "energy star" rating thing. It's annoying, i know.
Jan 09, 2008 | Toshiba 2060 Copier
OKI MICROLINE 320 Turbo Matrix Printer Logo
246 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
