Afico 3235 yellow dev keep being dumped come up with sc code
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
SC Waste toner full
Empty the waste toner, it shoukd go away. Look on the right rear side there should be a door, inside should be a big white plastic container 3/4 full of toner.
Posted on Sep 05, 2008
Richo afico 5002 code sc 878
1. Improper firmware update.
2. SD Card size greater than 2 GB used.
3. Multiple ROM data folders in SD Card.
4. Improper Java firmware update.
5. Power failure during firmware update.
6. Power line issues on the outlet.
Replacement of the Controller Board is necessary in case SC Code 878 occurs.
Apr 11, 2017 | Ricoh Aficio Office Equipment & Supplies
After replacing the main motor of my richo afico 2018 the copy result reduces is the cause of mismatch main motor?
Yes, If you have installed a main motor from Aficio 1015 the machine will work and there will be no SC Code displayed, but the machine will print a reduced image.
The part number for the main motor for Aficio 2015 is :
" AX06 0270 Brushless Motor 24V/20W "
Oct 05, 2013 | Ricoh Aficio 2015 Copier
Imprimente ricoh afico 1224c sc670
SC 670 - Engine response error.
After powerig on the copier machine,a respons is not received from the engine .possible defect controller board or SBCU installed incorrectly.Try reset the code to turn ON/OFF the main power switch.
Mar 01, 2013 | Ricoh Aficio 3232c 3214c 1232c 1224c Oil...
Sc 305 1075 afico
SC305. Occurs after replacing charge corona unit.
trnsp.gifAnswer [Cause]
PCU-side quenching lamp has come loose from bracket.
[Action]
Return quenching lamp to correct position.
Aug 20, 2011 | Ricoh Aficio 1035 Copier
Eror sc 500
remove all paper from the trays then turn machine off wait a few second then turn back on should reset then reload paper
Apr 08, 2010 | Ricoh Aficio MP 2000 Black and White...
Lanier SC 363
check the td sensor it has a high reading.. if this is a colour machine check the yellow dev unit.. some times the gears jam and can cause errors it may need replacing
Aug 03, 2009 | Lanier Office Equipment & Supplies
Aficio 3235
depends on where and how it is dumping toner??/
but it comes from two sources
a)drum: which has the waste toner drive system, it may be full or not working properly
b) developper : bad toner/ developper- mag roller or seals going bad-
Sep 05, 2008 | Office Equipment & Supplies
Error sc 422
I HAVE THE LASER C522 AND I HAVE PROBLEM TELL ME REPLACE WASTE TONER
Feb 10, 2008 | Ricoh Aficio CL2000N Laser Printer
JFS224 change drive order
You need to get into bios to change the boot order. You can usually get into bios by tapping F12, esc, or whatever depending on who wrote your bios. Once you get into bios, you should see something like change boot order somewhere. If you don't know where it is then just keep scanning each page and you will find it. It will be called something "boot order". Use the directions on screen to change it to whatever drive you desire and you should be good to go. If you can't do it then write back and let me know.
Feb 01, 2008 | Chaparral Technologies CHAPARRAL - JFS224
64 people viewed this question
jasbo
jasbo
