Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
Error Code F5 E5
I have a Kitchaid oven - It has an error code of F5E5 - What does this mean?
  • 3 more comments
  • sucker100 Sep 20, 2008
    September 15,2008
    I decided to use the self cleaning cycle for the first time and
    after it was to complete a 2hr30min cycle, it would not shut off
    until my husband hit cancel. The code appeared. We went to use
    the oven the next day and it would not heat. From what others above
    have noted, it is a dangerous defect that KitchenAid should address with a
    recall. We will attempt to follow some of the repair suggestions from this
  • Anonymous Sep 27, 2008
    I'm on my secondF5E5 error and second sensor. I will never use the cleaning function again nor will I ever buy a whirlpool appliance again.
  • Anonymous Oct 20, 2008
    After self clean cycle, oven will not heat?
  • weekendcook Jan 14, 2009
    Self cleaning cycle finished after 3 hrs, error code F5E5 popped up.
    Oven would not heat up, clock works.
    This the 3rd time, in 15 months, I have 5 yr extended warranty,
    This is a design fault which Whirpool /KitchenAid refuses to fix.
    Lesson learned - skip Whirpool and all their associated brands!
  • Anonymous Mar 23, 2014
    what is the part # for the thermostat for a Kitchaid model KEBC147
The repair on this issue will be one of either of these parts.
It is a common issue with Kitchenaid wall ovens.
Posted on Jan 16, 2009
The F5 error code?
Range/Stove Oven Fault Codes, Common Failure
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective
Nov 03, 2007 | Whirlpool GBS307PR Electric Single Oven
What does code f5 on magic chef range means?
The "F5" error code means there is a discrepancy between the clock's hardware and the oven circuit.
Clock assembly may need replacing.
May 18, 2014 | Ovens
Ge oven jkp27 code f5
Hello Donald,
The F5 error code means that the control board has detecteda error within it self and theirfore the control(also called clock or EOC) needs to be replaced. The F5 error code can be cleared by pushing the cancel/off button and if it returns a short time later their is defiently a malfunction inside of the clock and it would need to be replaced.
Sep 28, 2011 | GE JKP27 Electric Double Oven
Tried to Auto Clean. Got error message: Door -F-5. It started to warm up but would not lock. What to do? Manual not to be found in house. Oven is about 13-15 years old. First problem I have had.
The F5 error code means that the control board has detected a error within itself and the control board needs to be replaced. The F5 error code can be cleared by pushing the cancel/off button but if the error code returns the control board would indeed need to be replaced.
FYI when ordering the control board it also may be called the clock or eoc
Sep 23, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning stops after about 1 hr with error code F5E5
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
Nov 18, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My kenmore oven will not work . it flashes an F5 code.
Hi, the f5 error code is a door lock code, which means there is a problem with your door latch. its should lock the door at a crtain temperature and its not.
Oct 19, 2010 | Ovens
Tappan range error codr f5
Hello,error code f5 means temp too hot Replace oven temperature sensor
May 26, 2010 | Tappan 30IN ELEC IGNa Oven
Whirlpool accubake oven error code
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
It may just be a door switch
Dec 18, 2007 | Whirlpool RBS305PDS Electric Single Oven
The F5 error code?
I unplugged the oven and it cleared the code and was able to self clean the oven.
Jun 19, 2007 | Whirlpool GBS307PR Electric Single Oven
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
1,383 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
