Question about Dryers
How to take apart an indesit tumble dryer - Dryers
  • Dryers Master
  • 19,396 Answers
5 Suggested Answers
  • 3 Answers
SOURCE: Tumble dryer trips electricity
I own the same machine and this happened to me, if the internal working of the machine get wet it will cut off causing the electrics to trip. This model is a condenser dryer, at the bottom of the machine if you open up the flap you will see the condenser on the left hand side, the manufacturer recommends that you clean this unit once every month and also empty the reservoir and clean the fluff filter after every use. While this may seem like a lot of hard work there is a very good reason for this. I suspect that your problem is due to a build up of fluff and or gunge in the condenser and bottom of the machine. Remove the condenser and give it a good clean of all fluff, you can run water through it either in the sink or bath as the best way to do this it is very fiddley using just your hands. Next check to see if there is a build up of water in the back the machine where the condenser usually sits, you will have to lie on your stomach and reach into the back of the machine (OBVIOUSLY ENSURE THAT YOU HAVE UNPLUGGED FROM THE MAINS SUPPLY BEFORE YOU DO THIS!) along the floor of the machine you will feel a channel cut into the plastic which runs into the sump at the back of the machine, if you have not cleaned the machine properly this is probably blocked and is the culprit. With this blocked the water is unable to travel to the pump that takes the water from the condenser into the resevoir at the top of the machine, and therefore it stays in the machine and can get thrown about onto the electrics and could cause the machine to cut out and trip your electrics! If this is not blocked check the black rubber pipe leading from the pump to the reservoir is not blocked, failing that perhaps the pump (in the plastic case at the back of the machine) is faulty and will need to be replaced. If water has built up in the machine you will also need to check to make sure none is sitting in the heater coil compartment (it did with mine) to get at this you will have to unscrew the metal plate at the back of the machine and let any water out. Leave the machine for a few hours to make sure it is dry and then give it another go. If your machine is still under warranty though i would call indesit first as they may get a little funny if you remove any of the machine covers yourself and refuse to look at your machine.
Posted on May 28, 2009
AlmostBob
  • 550 Answers
SOURCE: how to fit a belt on a tumble dryer
unplug the dryer,
220v is not fun
dryers are generic inside, regardless of maker
while you got it apart to replace the belt is a good time to clean out exhaust vent pipes and the squirrel cage fan, no lint, better air flow, less $$ to run
3cd9043.jpg the tensioner may push Up on the lower run.
  • open case, most front panels are removed including door, remember to disconnect door switch wires, set panel aside
  • pull drum out
  • check drum support rollers
  • check drum felts, bushes guides
  • locate tensioner pulley, belts have been known to pull them out of the mounting when it breaks, check , reinstall if out
  • pick up broken belt off floor of case
  • take belt to parts store and match it, despite the huge number of dryer models there are very few belts.
  • If any felts or rollers are worn,stuck,damaged take them too to the parts store, and replace in pairs, despite the huge number of dryer models there are very few rollers or felts
  • after ensuring rollers anf felts and bearings are serviceable, loop new belt around drum at the wear mark from prior installation, reinsert drum
  • loop new belt around motor pulley.
  • pull tensioner pulley against spring to end of motion
  • loop belt around tensioner pulley
  • allow tensioner to slowly move back by spring tension till the belt is taut
put front panel back on, plugging in door switch
plug in mains
dry clothes
takes longer to type than to do
Posted on Aug 29, 2008
SOURCE: indesit condenser tumble dryer water
Maybe trapped water in the dryer. Switch off and remove power from wall. Remove condenser unit from the dryer (clean the condenser while you have the chance with plenty of water and an old toothbrush - it will probably be filthy). With the condenser unit removed stick an old tea towel in the hole where the condenser was and then tip the dryer on its side. If there is water it will either run onto the tea towel or onto your kitchen floor OR into the water container!
It worked for me, honest...
Posted on Mar 13, 2009
apart4u
  • 213 Answers
SOURCE: Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Posted on Jan 10, 2010
My indesit condenser tumble dryerwont start
try door interlock......................cheers
Oct 07, 2016 | Indesit Dryers
How to put belt on hotpoint dryer
Dryer Belt Replacement - YouTube
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
How to replace tumble dryer belt Hotpoint, Indesit, Ariston ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
Dryer Drive Belt (part #WE12M29) - How To Replace ...
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
Jan 01, 2016 | Hotpoint Dryers
Indesit idv65 tumble dryer squeaking really loud
hi check drum bearing to see if worn
Jan 21, 2014 | Dryers
I have an indesit IS70 SC tumble dryer which is very noisy. The noise appears to be coming from the air intake fan and sounds a bit like a piece of cardboard against bicycle wheel spokes. Any ideas?
Dryers are not hard to take apart.
There is possible something caught inbehind things.
Make sure to unplug the dryer first. Then proceed to take it apart carefully noteing thing as you do it, so that you can reasseblem
Jan 12, 2013 | Indesit IS70C Electric Dryer
Make a lot of nosie
Hi mervyn2011
Sounds like you have a bearing problem or drum roller/slide problems.
You will need to take the dryer apart to determine which problem it is.
For an owners manual go to the following webpage
Please take time to rate me
Bud
http://www.indesit.co.uk/indesit/_pdf/manuals/19504260005_UK.pdf
For parts go to the following webpage.
http://www.ransomspares.co.uk/parts/brands/indesit/tumble-dryers/is70c/
Oct 16, 2012 | Indesit IS70C Electric Dryer
INDESIT IS60 V (UK) TUMBLE DRYER smoking
get fire extinguisher and through it out side lol
Aug 14, 2012 | Dryers
How to access belt on indesit idv65 tumble dryer
Indesit tumble dryer not turning? How to replace a Indesit tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts How to Repair Home Appliances
Jun 22, 2012 | Dryers
Indesit is60v tumble dryer is not spinning although still heats, would this need a new belt?
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts from How to Repair Home Appliances
Jan 18, 2010 | Dryers
How do i replace drive belt on an indesit is60v tumble dryer please
Sep 09, 2009 | Dryers
Indesit is60v dryer
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Nov 30, 2007 | Dryers
Dryers Logo
701 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
