Bluetooth in my laptop is not working - Computers & Internet
    Problem Solver:
  • 6 Answers
Check that the driver software is installed properly or the driver is working properly or else u can check for USB whether its working
Posted on Sep 05, 2008
Have bought a Braven wireless speaker (bluetooth) for my QT 5500. It sounds great when plugged into laptop but can't seem to get bluetooth to work. Will I have to buy a dongle
All depends, Does your QT 5500 have bluetooth Adapter? Bluetooth Software? I looked at the specs, I don't see Bluetooth listed, but doesn't mean you don't have it. In Device Manager, is Bluetooth Listed?
Nov 30, 2012 | Computers & Internet
Bluetooth is not working...
make sure that all your bluetooth drivers is installed. you can do two way test. first is, have you laptop detect any bluetooth device that you have there e.g cellphone. if laptop was able to detect your cellphone then theres is no problem with your laptop. second is, let your bluetooth cellphone detect your bluetooth laptop. if cellphone was unable to detect your bluetooth laptop then we have issue here on your laptop.
Apr 03, 2010 | ASUS Eee PC 900 Notebook
Dell Studio Bluetooth Not Working
if ur OS is windows 7 it does not need any bluetooth soft..
Mar 02, 2010 | Dell Studio 17 Laptop
Acer Travelmate 5620 bluetooth button won't turn on
Do you actually see the Bluetooth device in device manager? Normally if it's not turned on it won't appear in device manager. The next thing I can think of is that if the Bluetooth module was not turned on when you loaded the drivers then they won't work.
And lastly the module may have come lose or unseated from the slot. Are you absolutely 100% sure there's Bluetooth hardware on this laptop? Is this built-in or a USB dongle?
If built-in have you turned it on? Acer uses a slide switch to turn Bluetooth and Wireless LAN on and off.
The first thing you probably need to establish is whether the laptop has a Bluetooth module fitted. Plenty of Acer laptops support Bluetooth in some markets and not in others and actually have slider switches to turn Bluetooth on/off but don't have the Bluetooth module fitted.
Does the unit say that it supports Bluetooth on the sticker attached to the front of the laptop? The models that have Bluetooth typically have this listed on these and will also list it on the packaging that came with the laptop that lists its specs. If it doesn't mention it odds are it's not fitted.
Acer laptops have the Bluetooth buttons, but not always have the Bluetooth Module. Check the bottom white sticker for a Bluetooth symbol under the laptop. If you do not see it, there is no Bluetooth. Also, if you press/move the Bluetooth button, and the light doesn't turn blue, there's no Bluetooth module with your laptop (only the button), so your laptop did not come with Bluetooth.
Also, you can add Bluetooth, but you need to be able to take the laptop apart to a certain extent, such as taking off the cover (top portion), keyboard, and maybe the speakers. The Bluetooth should have a 4pin, 6pin, or 8pin Bluetooth Cable connected to a Bluetooth module. You need to purchase the Bluetooth module, and install it, but you need professional help for that.
In case your laptop won't have a Bluetooth module fitted. The switch doesn't mean anything, it's present on all Acer laptops whether they have Bluetooth fitted or not.
You can buy the module as a spare part from Acer and fitting it is easy however buying a cheap USB Bluetooth dongle will be a cheaper option.
Thank You for contacting Fixya.com
Feb 02, 2010 | Computers & Internet
How to enable bluetooth
First of all you need to connect bluetooth device to the laptop because most Acer laptops don't usually come with bluetooth device but they have the software/driver that will make bluetooth to work on it. So, I will advice that you get an external bluetooth device connect it to your laptop, the bluetooth application will make the bluetooth device to work. Thanks
Sep 30, 2009 | Acer Aspire One PC Notebook
Aser 5738 laptop bluetooth not working on widows 7
You will probably have to look on the net for a driver that is compatible with windows 7 for your bluetooth device. If you cant find one designed for windows 7 you could try a driver made for vista as many vista drivers work for windows 7 devices as well
Sep 21, 2009 | Acer Aspire 5720-6661 Notebook PC
My bluetooth is not working on my acer aspire 5738
this problem is due to the improper driver for bluetooth module in your laptop . pls install proper driver and software .your problem will be solved .
thanks
Aug 26, 2009 | Acer Aspire 5720-6661 Notebook PC
Bluetooth Doesn't work
My Acer Aspire has a bluetooth button but it doesn't have bluetooth built in, this is because Acer has lots of different model variations but the exterior looks the same and they use the same hard drive image across the whole model range, this is why I have the software installed but cannot use it as I have no bluetooth device, you can check if you have by right clicking on '(My) Computer' icon then choose manage and then device manager, do you see any bluetooth devices, if not then this is the reason why it's not working.
Jun 02, 2009 | Acer 4220-2346 Notebook
NS-BTHDST NOT WORKING WITH MY LAPTOP ANYMORE
If you are indeed talking about your Insignia bluetooth headset the reason it works with your cellphone is probably because your phone is already bluetooth enabled, but your laptop is not, which is what the usb dongle is for. You must install the drivers for the dongle for it to make your laptop bluetooth enabled. Once you have that working you need to go to Bluetooth places (should be on the desktop once the driver is installed) THEN hold the button on the headset down until the lights flash blue and red alternating. Once it is flashing, click on add new bluetooth device in the Bluetooth Places and it should pick it up. Once that is going everything is pretty straighforward...follow the wizard. Hope this helps!
Feb 22, 2009 | Insignia Bluetooth Wireless Headphones...
Dell latitude d600 bluetooth and infrared devices problems
i have D 600 laptop
my bluetooth is nt working
wht should i do?
Jan 14, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
David Payne
David Payne
