I am looking for the spool attachment that is used to attach a full reel of tape to the gx636. I have no idea what it is called, but is designed to hold both the take up and the supply reels.
Audio Tape Spool or Photographic Film Spool? You say 'listen', so we will assume it is audio. Your local Audio Repair workshop will have a reel to reel player and the ability to process it to a CD or to a Memory Stick. Like this place near where I am.
I'm sorry, I don't have information on a specific TSC10SA bait casting reel. However, most baitcasting reels have similar components and can be reassembled in a similar manner. Here are some general steps you can follow to reassemble your reel:
Place the spool back into the reel frame.
Insert the spool shaft into the spool and secure it with the spool retainer.
Place the side plate back onto the reel frame, making sure the spool shaft and spool retainer are in the correct position.
Insert the brake adjustment knob and secure it with the knob screw.
Insert the thumb bar and secure it with the thumb bar screw.
Place the handle back onto the reel and secure it with the handle screw.
Tighten all screws and make sure the spool spins freely.
It's always a good idea to consult the manufacturer's manual for specific instructions and diagrams on reassembling your reel. If you have lost the manual, you can often find one online by searching for the make and model of your reel.
Main code 2X : Mechanism control system error 574 Failed to detect the T reel FG during search.
This means the take up reel stopped rotating during forward search. It shut down assuming tape was spooling loose into mechanism. Could be just a faulty cassette tape. A common problem is also when labels have been placed in the wrong places on the cassettes, stopping the lid from opening fully and stopping the reel reaching the reel motor drive.Manually eject the tape and try another tape. If the fault continues, have a look for something in the way under the cassette such as post it notes, paper clips, torn labels etc. Have you had the unit serviced since you got it? Could be time to get it to a service centre for help.
Verify that you have installed the proper correction tape. The types of tape that can be used with this system are: Item 1030 - Correctable Film Ribbon, 1230 - Correctable Film Ribbon 2pack, 1031 - Multi Strike Ribbon, 1032 - Nylon Ribbon, 3010 - Lift-off correction tapes (to be used with 1030 and 1230 ribbons), 4010 Cover-up Correction tape (to be used with 1031 and 1032 ribbons). Make sure that the correction tape is installed properly. Pass the tape through the left guide, behind the ribbon guide and out through the right guide. The rough side of the tape should face the platen. Attach the feeder spool to the pin on the left. Attach the take up spool to the pin on the right. Turn the take up spool counter clockwise until a small amount of tape has wound around it. Replace the cassette ribbon and close the case cover. Press [CODE] + [RESET] to move the carrier to the previous position.
The tape leader is a band of flexible plastic with a hook on the end that is attached to the reel inside the drive.
When a damaged tape is used in the drive or when the drive is faulty, the tape leader can miss hook the leader and it pulls through and just flaps around on the internal spool leaving the drive unable to accept any tapes and failing self test.
Re-thread the lape leader round the guides and past the head and hook the square hole in the leader back onto the plastic hook just in front of where the tape usually sits and power on the drive and see if it passes self test.
Although this is often just a damaged tape that causes this it can also suggest a faulty drive so dont use any important tapes in the unit till you are sure the drive isnt totally 100%
I have used www.tape-drive-repair.com who are pretty good for this kind of thing and not too expensive - if you need to send the drive away for repair / exchange
Move carrier to middle with spacebar.
Open lid, remove black ribbon and old correction tape.
Gently pull new tape apart a few inches. attach take-up spool (empty one) to right post.
Pass through right ribbon guide, sticky side faces platen!
Unspool carefully thread through left ribbon guide.
Attach feeder spool to the left post.
Turn the right spool to tighten.
The line needs to installed on the reel as it is on the new spool when purchased. Also check spool drag. If it is a spinning reel it is important to install the string correctly and use a quality brand of string.
1). Remove the five screws from top half of cassette shell. If the cassette shell halves are glued together, very carefully split the shell with a Phillips-head screwdriver. Maneuver the screwdriver around the shell to break its seal. Avoid getting cut or damaging internal components of cassette.
2).Carefully lift off the top half of the cassette shell.
3). Pull the head if the tape from the left reel.
4). cut-off the damaged edge, and attached a peice of sctoth tape to the shining side of the tape, and leave about 1/2 inches of scotch tape beyond the head of the recording tape.
5). trim the sctoch tape using single edge of the sctoch tape razor or X-Acto knife to the same width as the recording tape.
6). carefully insert and tape the head of the recording tape to the right reel. and manually wind the tape till the recoding tape is flat to the front of the recoding pad.
7). carefully close the top shell, make sure not to pinch the tape. use your finguer trun the right reel, make sure the tape winds freely.
8). secured the top with screws.
When a VCR eats a tape, it can be cause by a couple things.
1. There is a rubber wheel called a "pincher wheel" that compresses the tape against the "capstan". The capstan is a shiny metal spindle connected to a motor. The pincher wheel can become worn and/or dirty (slick) from the oxide coating off of the tape. You can try cleaning the pincher wheel and capstan with alcohol or try using a re-grip solution on the pincher wheel. Last thing to do is replace the pincher wheel. Look to see that the pincher wheel is doing its job by pulling the tape through. The pincher wheel & capstan are not used during a fast forward or fast rewind, so if your tape is getting caught during the FF or RW and not Play, it's probably not related to capstan & pincher wheel.
2. There is a small tire wheel called an idler tire. This tire pivots between the sending and pickup reels of the player. Its also used during fast forward & rewind as well as play. If the tire is worn, the tape won't be wound up as fast on the take-up reel as the sending reel during play. This means more tape is coming out of the cassette than can be wound up on the takeup reel. You can try using a re-grip solution on the idler tire or replace it.
3. You didn't say if the unit played ok. There's also a brake pad that is designed to grab and stop the tape wheels from spinning when you hit stop. If those pads are worn, the wheels will not stop fast enough and the tape will continue to feed (spool) out of the cassette and not be taken up by the other wheel.
So when when you hit eject, the excess tape that should have been wound up tight in the cassette before the eject sequence, is getting caught inside the player.
Let me know if I can be of further assistance to you.
