Philips DVP-3005 DVD Player Logo
Posted on Sep 05, 2008
My dvd model is philips dvp 3005 and it is in standby mode when i start my player standby led glows and when i press stand by button on the player or power on from remote control the screen shows no disc and disk door is not opening
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Feb 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1470
Points
5
My dvd player did the same problem. and i solved this just with a screw driver:) if your dvd player s guaranty finished!! switch off the player and open the screws which r 2 on sides and 3 behind the dvd. open the cover and take off the two group of cables on the chipset which are on the mechanical part side! (mechanical side: dvd driver) than plug the cables again to their socket. its done! close all and go on ! i hope this will solve your problem as mine...
  • Anonymous Feb 18, 2009
    i wrote the solution in my first post but first of all try this!
    unplug the dvd player from electricity all and touch the player to a metal which has a ground connection than try. if this isnot okey do the first.
My Philips DVD DVP 3005 won't play any sound. The picture is absolutely fine though. What can I do?
Find out the protection transistors between buffer ic 4558 and sound output rc socket and remove them and also check both + / - 12V on ic 4558
Thanks & regards
Shrinath inde
maharashtra india
13helpful
2answers
The "L ch" message is
To cancel child lock in DVP-SR200P dvd player, press power button to turn unit Off (standby mode) then press Return, Enter and Power buttons on remote.
This will cancel child lock in dvd player.
Hope this info will help you.
Thanks.
As I am watching a movie, I accidental press a button on my remote of the dvd then something came out of the screen. inorder to get back to where i am watching i keep on pressing buttons on my remote. The...
It sounds as if you have inadvertantly locked your dvd player. Try using the code 136900. If this passcode is accepted, then access the general setup menu (using your remote) and choose the Disc Unlock option.
I hope this helps. I completely relate to the frustration of this very problem.
2helpful
2answers
How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
My DVD 3005 is locked on a DVD do not know how it happened but obivously I have pushed the wrong button is there a common decode number I can use, I am unable to locate the manual for the player. Regards
I'm not sure whether this will work. Can you locate a small hole under the disc inserting outlet of your DVD player. If yes, push the eject button and insert a small pin well into the hole. The DVD struck in may come out in a few seconds.
How can I make the DVP 3005 DVD player multi regional
I think you are looking to make your DVD Player, Region Free?? If so, here is a link that has an upgraded firmware that is NOT RELEASED BY PHILIPS, so use this at your own risk. Please read very carefully before attempting any of this. Use at your own risk.
Click Me
Heop This Helps
Philips dvp 3020 dvd player
Pls try a full master reset which if done correctly would revert the unit back to factory default:
1. Power on the unit;
2. open the front panel lid to have access to the controls;
3. simultaneously press and hold the channel up and down buttons;
4. wait till "BYE" is displayed;
5. wait till clock switches off;
6. power on again and re-configure.
You may need to restore "Region Free"
1. Power on the DVP 3005.
2. Bring up the System Menu.
3. Navigate to the Preferences page.
4. Press the following combination of keys on your remote in this order to bring up the secret menu showing the Region Code.
1 3 5 5 6 6.
5. Use the arrow keys on the remote control to change the Region. To make it region free, set the Region code to “0′ (zero).
6. Exit the System Menu.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Software upgradation
Its called firmware, and you would need it on a disc, you would have to get it from Philips or maybe their website.
Don't download firmware from anyone else but Philips.
Standby
i have a dvd philips,dvp3005k ...no work only red led is on / no display...? I see the switch is good...
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
