Question about Gateway FPD2275W LCD Monitor
19" Proview 900p lcd monitor backlight
I brought this monitor from an auction, upon testing the backlights were dead as i shone a lamp on the screen and the image could be seen.
Opening up the monitor i looked around at any obvious problem like buldging capacitors or burnt components but none to report.
There is a a 10 way connector on the board where the inverter and power supply are combined; this connects into the main video board inside the monitor .
The pins are as follows :
I tested the 12v line which is supplied from a 7812A transistor and from this all im getting is 4.3v and this is even with the monitor turned on and the video cable wired up to the pc, So i dont know if the transistor is at fault really.
Could do with a little bit of help on the subject.
  • 159 Answers
Change the capacitors (all but maybe the main should be done- if you change just bad ones now, the others will take the heat and go soon). They do not have to be bulged or leaking to be bad.
Then if that doesn't help, shoot for transistors.
I fix these and have had many pretty ones not work.
ebays bammbammfran
Posted on Oct 10, 2008
The 7812 device is a voltage regulator. Either the reg has failed or the input to the reg is no longer approx 12volts. It should be more than 12volts so that the reg can control the o/p .
Posted on Sep 05, 2008
K53e asus has dark screen how do i find and replace the backlight?
The CCFL lamp is located at the bottom of the LCD screen behind the plastic bezel in between the hinges.
You maybe able to get a CCFL lamp from this WEB site.
LCD screens and Inverters
Feb 12, 2013 | ASUS Computers & Internet
My proview 19 in turn on but then it goes black is it a capasitor and how to fix it or is ther a reset on it
It may be the internal backlight that is failing. You can take a flashlight and hold it close to the screen, move the flashlight all around the screen and check if you can see anything. The display will be dark, but you should be able to make out the image that is there with the flashlight technique. If you can see an image on-screen, then your backlight has failed and you will need to replace the monitor. Weather or not you see an image is not a critical issue, but a tool to verify if the backlight is off or some other issue is causing the problem.
Note, it may be difficult to detect an image on the un-light display, for example if you have a dark image as your desktop background. So make sure to fully scan your display (top to bottom, and left to right covering the entire screen) with the flashlight technique in order to see any image on-screen.
Mar 22, 2011 | Proview PL926WBi 19" LCD Monitor
My monitor screen is coming on and off
Check the cable connections to make sure they are not loose. Do you see the image still on the screen when the light goes off? You might have a bad backlight inverter which would cause the light to flicker.
Mar 03, 2011 | Proview PL926WBi 19" LCD Monitor
I have Monitor Proview PL916S 900P It turns on
spc12b, Have you tried the flashlight test yet? How old is this monitor? Your monitor has a 2 types of power supplys in it. A switch-mode-power-supply and an "INVERTER" supply. One or both of them could be having a problem. The inverter needs DC from the smps to change it into AC to light up the cold-cathode-fluorescent-tubes that are hung in back of the lcd panel. Let me know results of flashlight test. After screen goes black, hold light 1-2" from screen at different angles. Let me know if you still can see the win-desktop screen even though it is still dark.. Bye for now. louie12fix on fixya or lmistyrel
Aug 12, 2009 | Proview PL916S2 Monitor
19" proview LCD monitor light and signal
How old is this thing? Mine is about 4 or 5 years old... junk it!
Mar 25, 2009 | Proview PL926WBi 19" LCD Monitor
Screen flickers for about 20-30 seconds sporadically
Try looking at the LCD screen at a sharp angle to see if ghost-like video can be seen during the 'off' time of the flicker.  If video is still present even though not that visible, then either the backlight or its power supply are failing. The color problem could also be caused by a backlight lamp that is not ionizing completely.
Dec 14, 2008 | Acer AL1912B 19" LCD Monitor
Monitor turns off after 4-5 seconds
hi every one, i hope this helps and am proud to say/or not that i am now using my philips php-19x (aka proview 900w/Mag LT916s Model 900p/ Xerox) and yes turn on the monitor 2 seconds screen goes black and the blue power light stay lit, but if you shine a torch onto the screen you can see the lcd display is working, and if you turn the power off and on the cycle starts again, like most of us we checked the web to no avail, untill yesterday. I have been playing with this monitor for 3 months on and off after a kind fellow gave me this monitor for free on uk freecycle and of course i checked all the caps on the psu/inverter pcb and more components all seemed fine checked the ccfl lamps by taking them out of the lcd panel (15 minutes to dismantle) both lamps where fine not orange, a nice bright light, and knowing that if the monitor started woking ok and the back lights did not fail it would run like this for ever until you turned the monitor off / video blanking so i was convinced that there was no fault with the psu/inverter board, and as i stated i found the solution at last (yeh) and here it is many that's to all on the bad caps forum and of course the main man -----barry wilkins-----
Re: Mag LT916s Model 900p 19" LCD dropping like flies
I have got to the bottom of this ,after I got one of scopes out (PM 97) the output of the TL 494 IC was disappearing .The IC seems to crash easily ,I think the oscillator on pins 5&6 actually stops.
I cleaned the whole board with an aerosol of PCB cleaner and heated up the PCB up with a small craft heat gun to quite hot .
I fitted a 0.01 mfd capacitor across the IC pins 12 to 7 to decouple the VSS supply ,because I felt the cause of the IC stopping could be interference based
The monitor now runs for all day with no sign of the backlights cutting out.
I found out this LCD display was made by proview.
Barry Wilkins
john r uk.
Sep 05, 2008 | Computers & Internet
19"LCD DELL E193FPp ---If to direct a ray of light on the screen that it is possible to see the image.what the problem is,
Your problem in this particular instance is thet either the backlight bulbs have failed, or the inverters that power the backlight lamps have failed.
Good luck.
Oct 07, 2007 | Dell E193FP 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
569 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
