Question about Dryers
Dryer not working in washer dryer
The heating facility no longer works so it goes for however many minutes you set it for but it does not get hot.
    President:
  • 1,462 Answers
Take top of machine off. you will see dryer duct running across the top and mounted on it various stats. one of these may be a resettable overheat stat. if so, there will be a small button in the middle. press button, there will be a slight click and dryer should then operate. also check continuity thro the heater itself with a multimeter
Posted on Sep 05, 2008
GE dryer starts up ignitor gets hot you see flames everything is working. 2-3 minutes later the flame goes out. Is this a bad thermostat?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101''';;
Apr 22, 2011 | GE DRSR483GD Gas Dryer
The dryer no longer gets hot
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Dryers
The Dryer is no longer producing hot air
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 06, 2010 | Zanussi TD4212W Electric Dryer
Dryer no longer gets hot to dry clothes
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My whirlpool AWZ510E washer dryer - the dryer doesn't seem to be working - it goes through the cycle but the clothes are still as wet as before. I am using the same cycle as I always have which used to...
there are 3 reasons for a dryer not doing the job yet running through the motions. 1st, the heat is not being produced and only cool room temp air is circulating. this can be a burned-out electric element or an over-heat sensor, or in0line safety fuse. ( if gas, can be ignitor or gas valve coils).. It could be that the washer is not ringing (spinning) dry the clothes verywell and there is too much moisture stiil in clothes which would double the dry time from 50-60 minutes to 2 hours. 3rd, could be clogged vent line and the hot moist air cannot leave the dryer so the clothes get hot by the moisture stays.
Apr 28, 2010 | Whirlpool Washing Machines
My dryer is no longer getting hot. it will go through 1 heat cycle then it will not re-ignite. The glow plug heats up to re-ignite the dryer but the gas never re lights. If you un-plug the dryer and...
if it heats for the first 15 to 30 minutes and then no more heat you have bad gas coils,when they are defective they will work until they heat up and then no heat when it cools down they will work again.they are on top of the gas valve,very easy to change
Feb 18, 2010 | Kenmore Dryers
Dryer blowing cold
Check the following to address this issue.
Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Please rate and have a great day:)
Jun 01, 2009 | Hoover Dryers
Kenmore 70 gas dryer will heat for 7 minutes then nothing
Change these:3d37aa7.jpgthey get hot and quit, then cool off and work some more.
Dec 31, 2008 | Kenmore 73952 Gas Dryer
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Dryers Logo
Top Dryers Experts
