Question about Philips AJ3120 Clock Radio
AJ3120 alarm clock having time delay
Sir, I bought a AJ3120 alarm clock which has rather a peculiar problem. The time is running a 1/2 to 1hr delay during a 24 hr period. I have to daily manually correct the time. Is there any solution for that?
Mozz
  • Truong Pham Sep 20, 2008
    I have bought this clock and have to adjust time manually everyday. Time is always faster day after day on this clock
  • Anonymous Mar 12, 2009
    I HAVE THE SAME. NOW THE PROBLEM IS VERY LOW INTENSITY OF THE DISPLAY
  • 3,037 Answers
No, in this case I would contact the manufacturer to see if they will send you a replacement especially if it is under warranty. let me know if you need anything else
Posted on Sep 05, 2008
How do i set the alarm on my ihome alarm dock?
Once the time is correct, users can move on to setting the alarm itself. Many iHome systems come with dual alarms allowing couples to set different times for each person or individuals to designate a weekday and weekend alarm. Each alarm has its own time, wake-to source, and frequency. The process of setting the alarm is the same for both options, the only difference is what button, either 1 or 2, users depress when setting it.
Once ready to set an alarm, users need to push and hold the button down, waiting for the alarm time to appear on the clock's display. From there, the up and down arrows or plus and minus buttons adjust the time backwards or forwards accordingly. Once that is complete, users select the frequency of the alarm by pressing the alarm button again and then opting for 7, 5, or 2, which correlates with all week, weekdays, and weekends respectively.
The final part to set is the wake source of the alarm. Users press alarm buttons one more time, and then use the same directional buttons to choose from iPhone and iPad on some models, radio, buzzer, or playlist. If users choose playlist, they must also setup a playlist within their Apple device titled iHome.
Because frequency is part of the alarm setting process, there is no need to turn on the iHome alarm manually as one would do with a normal alarm clock. However, users can check to see if the alarm is active by looking at the screen of the clock for the earliest alarm time, displayed on its lower part.
In the mornings, when the alarm sounds, users have two options: Snooze and disarm. The disarm process turns off the alarm until the next day in its frequency chain. Users disarm the alarm by pressing the power button. On the other hand, users must manually program the snooze button. Users do this by pressing and holding the snooze button and then toggling to the desired snooze time, generally between one and 29 minutes. Once this is set, users simply press the snooze button in the mornings to delay the replay of the alarm for that amount of time.
Jul 18, 2014 | iHome Audio Players & Recorders
RCA Alarm clock with cd player, CD will not read discs
cd players have their laser fail often. How old is it? A three year run with a player is not bad.
Nov 24, 2013 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Need manual for Travel Companion Model S1500 Alarm Clock
Travel alarm clocks can have varying instructions, depending on the type of clock you are using. Here are some tips for use that will apply to any alarm clock.
  1. Power source
    • Travel alarm clocks will need to have some sort of power source. Depending on the type of alarm clock, it might be battery-powered or it might have a cord that needs to be plugged in. Battery-powered alarm clocks can take mini watch batteries, AAA batteries or sometimes AA batteries. Travel alarm clocks, because of their tiny size, usually have the small batteries that need to be bought from a watch store or a dollar store. Before you leave, make sure you have a working power source and can turn it on.
    Changing the time
    • After you reach your final destination, power the alarm clock on. Now you'll need to set the time and date correctly. Check a watch, cell phone or television to get the exact time and locate the buttons or dials on your alarm clock. On some, there will be a "time" or an "hour" button you need to press and hold to activate the alarm time change. While you are holding it down, turn the dial, press the hour button or press the (+) button until you notice a time change. On others, simply pressing the hour or minute button will let you change the time shown.
    Setting AM/PM
    • The AM/PM option is critical in setting your alarm clock correctly. Make sure the LCD display on your clock has a light beside the correct AM or PM setting, or look for the letters AM or PM on the display. If you get this wrong, the alarm won't go off in the morning!
    Setting alarm time
    • To set the alarm time, look for a button or a switch that says alarm. If there is a switch, move it to the alarm setting. If it is a button, you'll need to hold it down until the time starts flashing, signaling time to change the hours and minutes to the desired alarm time, or hold it down while you press the hours and minutes buttons to reach the alarm time you want.
    Turn alarm on
    • Now double-check that your regular and alarm times are correct by switching the switch back and forth again, or by pressing the alarm/time buttons long enough to read the time set. There should be a picture of a bell somewhere on your LCD display showing that the alarm is set to "on." If there isn't, look for the on/off alarm button and move it to the correct position.
    Music options
    • The last step is finding the alarm wake-up option. Not all travel alarm clocks have this option, but if yours does there will be a switch or button that lets you choose to wake up by a buzzer, the radio, a CD, or another device.
Read more: Travel Alarm Clock Instructions ' eHow.com http://www.ehow.com/way_5250617_travel-alarm-clock-instructions.html#ixzz1YfneKhGw
Sep 22, 2011 | Vacuums
I am using my mother's Elgin 3400E travel alarm
On my Elgin alarm clock, you just push the nap button and it will add 15 minute increments for a nap. I haven't figured out how to turn it off if I change my mind or wake up earlier than I set it.
Jul 21, 2011 | Elgin Travel Alarm Clock
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? (i am in Australia.) Thank you in anticipation.
I bought a Caixing CX-2158 led digital clock in Thailand and there aren't any instructions to operate it eg; set time alarm etc. Can you help please? Philippines Thank you in anticipation.
Jul 12, 2010 | Vacuums
Alarm won't set
You have the room tech Beingz? If so, you go to set time, and then first set the hour with the first buttons. Then, you click the very top once, and you should, after it loads, be able to set the minutes.
Jan 26, 2009 | Hasbro Room Tech Beingz Alarm Clock Radio...
How do I set the sleep timer?
To adjust snooze time - The system is set for a standard 10-minute snooze time (the number
of minutes you can delay the alarm). While the selected alarm is flashing, hold down Sleep⁄Snooze
and press the Time or to adjust the snooze time (from 1 to 30 minutes) for that alarm. The
number of minutes and Sn appear on the display to confirm your selected snooze time. You can
set a different snooze time for each alarm.
Oct 01, 2008 | Homedics SS-4000 Clock Radio
Changing between the buzz and cd setting for alarm clock
From the manual (miraculously, I still have it)...
To switch the alarm sound between buzzer, church bells, radio or CD, press MODE one time, and then press REPORT.
If CD is selected, press TUNING up (>>+) or down (-<<) to select desired wake-up track.
When alarm sounds, press ALM ON/OFF to silence alarm and reset it for the next day.
SNOOZE-BOOST
To postpone the alarm once it sounds, press SNOOZE/LIGHT. Each press of this button will add 10 minutes to the postponement time. (Pressing three times will give you a 30-minute delay).
Sep 14, 2007 | Sharper Image SI686 Clock Radio
Philips AJ3120 Clock Radio Logo
167 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
