Problem with playback device - Computers & Internet
  • rhubsexy Mar 15, 2009
    i canyt hear any sounds in my computer.. but i used usb headset only that time i can hear a sound. wat will i do pls help me
    Problem Solver:
  • 6 Answers
Uninstall and later re-install the sound driver, you wont face problem with playback device
Posted on Sep 05, 2008
How to dub tape to tape
Hi Dale,
You're kind of light on details of the equipment you're going to use - so the best I can do is provide generic instructions. You'll need two devices - one must be able to perform playback for source media and the other for recording or copying duties. Inspect the jacks provided on the rear of both units. Most provide standard RCA type "Phono" jacks for left and right audio channels. Connect a stereo patch cable (with plugs that match the jacks of the playback and recording devices) between the left and right OUTPUT (or "PLAY") jacks on the source device and the left and right INPUT (or "RECORD") jacks on the recording device. Insert the source tape, cd, album, etc. in the device that will playback the original and insert a high quality blank media into the device that will provide recording capabilities. Begin playing the source. Set options such as tape bias, Dolby Noise Reduction, etc. on both source and recording devices to match media in each. Advance the playback source to a point that contain the loudest sections. Set recoding levels by monitoring the VU meters on the recoding device and vary the input adjustment levels so that only the loudest prortions of the program just begin to briefly "flirt" with the 0Db or red zone of the meter. Signals that cause the meter to indicate into this area and beyond begin to overload the amount of information that can be recorded on the blank media and often result in muddy audio quality during playback, later. You should also record the same section repeatedly with differnt options (bias, noise reduction, etc.) to actually hear the difference to determine which sounds best to you. Once levels are set, queue the playback device and start recording. In the case of tape, allow enough recording time to let the leader section of the tape to pass beyond the recording heads for several seconds or more. Once the desired amount of silence has elapsed, play the source program. Allow it to run to completion using both sides in the case of tape and then playback the entire new recording to make sure it recorded without any issues.
Apr 09, 2015 | Televison & Video
Have no idea how to turn on speakers. laptop given to me s/hand
Right Click the little speaker - Playback Devices - double click the Speakers (if not shown then
Right Click in the main box on the Playback tab - Show Disabled Devices) - on the General
tab - Device Usage - Use this Device (enable)
Aug 25, 2014 | Dell Dimension E520 PC Desktop
Can't get audio to work
May 29, 2014 | Acer Aspireā„¢ T180 PC Desktop
I have bought creative inspire m4500 4:1 sound box.in reakteck audio manager and control pannel while testing all the soundboxes r responsing.but in any media player two of them isnt responsing..pls help...
Go to Start, control panel, Sound and double left click on Sound. When that opens up it should show a list of your sound devices and which is is set to be the default playback device. You can also change recording and playback volumes here or unmute. Depending which device is set as default the media player should playback on that device.
Dec 09, 2013 | Creative Labs Sound Blaster Live! 5.1...
My computer has no sound driver after installing windows 7
If you have a sound icon(speaker symbol) in your toolbar, right click on it. Click on " playback devices", a window should come up. If nothing is in window then right click on it. See what you have. If nothing comes up, Right click on playback devices again and click on disconnected devices. If you have drivers show up when you click playback devices,right click on the one you want to use. See if there is an option to "enable". Click enable and see if this works. You can also check in Control Panel under sounds or, in device manager, under audio/playback devices.
Mar 05, 2011 | Computers & Internet
Mi problema es con el ciberlink powercinema 5, cuando lo abro la tv se escucha pero no se ve y se queda pillado el ordenador, tengo windows xp sp3 pro.
It can be the TV Tuner Card.See this:
Operating System
  • Microsoft Windows 7, Vista and XP SP3* (Windows XP Service Pack 3 is required)
Processor (CPU)
  • Blu-ray Disc playback: Pentium 4 541 (3.2 GHz), Athlon 64 X2 3800+ or above
  • TrueTheater 3D playback: Pentium D 950 (3.0GHz), AMD Athlon 64 X2 3800+ or above
  • DVD playback: Pentium 4 (2.4 GHz), Athlon 64 2800+ (1.8 GHz) or above
Graphics Processor (GPU)
  • Blu-ray Disc playback: Intel G45, ATI Radeon HD 2400, NVIDIA Geforce 7600GT or above
  • TrueTheater 3D playback: Intel G45, ATI Radeon HD 2400, NVIDIA Geforce 8800GT or above
  • DVD playback: AGP or PCI Express graphic accelerator supporting DirectX 9.0 or above
    • Note: we strongly recommend that you update your graphics card driver to the latest version. 3D display devices are required for TrueTheater 3D playback.
Memory
  • Blu-ray Disc playback: 2 GB required for Vista and Windows 7; 1 GB required for Windows XP
  • DVD and TrueTheater 3D playback: 1 GB required for Vista and Windows 7; 512 MB required for Windows XP
Hard Disk Space
  • 300 MB for product installation
Display Device
  • DVD and Blu-ray Disc playback: HDCP compliant display for digital output. TV or computer monitor for analog output
  • TrueTheater 3D playback: 3D display and 3D glasses required. HDCP compliant display for digital output. TV or computer monitor for analog output
Disc Player
  • Blu-ray Disc playback: BD-ROM/BD-RE or Super Multi Blu combo disc drive
  • DVD and TrueTheater 3D playback: DVD-ROM, DVD+-R/RW, DVD-RAM or DVD Super Multi combo disc drive
Microphone
  • A microphone is required for recording voice-overs in Movie Remix mode
Internet Connection
  • Internet connection required for web services
Dec 20, 2010 | Microsoft Computers & Internet
No audio ouput device installed
First we have to determine whether or not you have the required drivers installed in order for the operating system to communicate with your sound playback device. Following is the keyin sequence for Windows XP - The key-ins will differ somewhat for other Windows operating systems:
Click on START
Right Click on MY COMPUTER
Tnen click on PROPERTIES followed by HARDWARE and then DEVICE MANAGER.
Double click on SOUND, VIDEO and GAME CONTROLLERS
Your sound playback device (such as Avance AC 97 Audio) should be listed. And there should NOT be a yellow exclamation mark in the left margin (If there is, this is an indication that the device is not working properly - see CORRECTIVE ACTIONS below.
If a playback dvice is NOT listed se CORRECTIVE ACTIONS below.
Double click on your sound playback device.
In the device status box you should see the statement "This device is working properly"
If you get any other messages indicating that drivers are required or need to be updated, see CORRECTIVE ACTIONS below.
If everything look OK, click on the "X" in the upper right corner to close device manager.
If everything was OK in device manager we will now see if the operating systen is sending sound to your playback device.
Click on START
Click on CONTROL PANEL
Select the Classic View (If not already displayed)
Click on SOUNDS AND AUDIO DEVICES
Double Click on AUDIO DEVICES
Click on the AUDIO tab.
In the Sound Playback dialog box your sound device (something like "AC 97 Audio") should be listed. If it is not, click on the pull-down menu and select it if you can..
If it is NOT listed, see CORRECTIVE ACTIONS below.
If it is listed, perform the following tests:
Click on the SOUNDS tab
Set the Sound Scheme to WINDOWS DEFAULT
Click on APPLY and OK
In the Program Events dialog box, click on any event that has a speaker Icon to the left of it
Underneath the Program Events dialog box you will see a small box with a triangle inside
If the triangle is black that means that the operating system has recognized your sound playback device (sound card).
Click on the triangle.
You should hear the sound through your speakers (the triangle will change to a rectangle while the sound is playing)
After the sound plays the black triangle will re-appear.
If the triangle is black and changes to a rectangle when you click on it and you DO NOT hear sound through your speakers either your speakers are plugged into the wrong jack or you have a problem with your speakers. Test or replace the speakers.
If the triange is gray that means that the operating system does not recognize your sound playback device (sound card). See CORRECTIVE ACTIONS below.
CORRECTIVE ACTIONS
If the playback device is built into the motherboard, the device may not be enabled in the BIOS. Check your BIOS settings. If your sound device is disabled, enable it and repeat this procedure.
If you do not have built-in sound on your motherboard you will need a sound card installed in an expansion slot on the motherboard. This card may not be present. If there is no sound card, install one and then repeat this procedure.
If you do have a playback device installed and enabled and either you have an error indication, drivers are not installed, or device manager reccommends a driver update, you will have to download drivers from either the motherboard or sound card manufacturer's web site. Also, if the drivers are installed and you no have no error messages, but you do not hear sound when you click the black triangle, you may have a hardware problem on your motherboard or sound card.. At this point, you may want to get some help from a qualified PC technician.
If you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Regards,
Yavacotech
Dec 08, 2010 | Computers & Internet
I lost ALL sound when Iinstalled Xitel's Inport
Have you trying to rollback using windows sistem restore
Aug 23, 2009 | Xitel INport Deluxe for PC
HI, I have an emu 1616m soundcard. My laptop recognizes the EMU and the pulgins, but no sound comes out of the monitors.Only from the laptop speakers.
You have to select the EMU as the default playback device in Windows and or select it as the playback device in the software you are using for recording or playback.
Go to Control Panel and Sound and Audio Devices icon, and select the Audio tab. There is a drop down box that lists all playback devices. You have to select the EMU in there.
That should get you working.
Dec 29, 2008 | E-Mu 1616M Sound Card
Tapes won't Playback in other deivice
Hello! If the recorded tapes playback ok on the camera and not ok on another devices, you need to readjust the playback on this camera using a tape which playbacks fine on the other devices. This means that is a small difference on the tape transport. So when the supply and takeup post rollers readjusted and the audio and video playback are good, then your camera is fine.
Sep 14, 2008 | Panasonic AG-DVX100A Mini DV Digital...
Computers & Internet Logo
752 people viewed this question
David Payne
David Payne
