MONITOR when you leave the monitor open for sometime it will go blank so to use it again you have to restart the pc again
  • 4 Answers
Hi ,
Log in as Administrator , Go to Control panel
Open Display -> Select Screen Saver Option -> Click on Power
There is Option Turn off Monitor select never option. and
There is other option System Stand by select Never..
Click OK click apply and again click OK....
This will definitely work for u r problem
Posted on Sep 05, 2008
Youtube video is not play in my lg gs290
Try some of these things:
1. restart browser (internet explorer, firefox, or other browser). - If you leave the browser open for too long sometimes the videos do not play because of a software problem.
2. restart computer - sometimes restarting browser is not enough. you need to try restarting pc
3. if all else fails, try going to adobe.com and download the "flash player" again to make the movies start again. use this address for the flash player: http://get.adobe.com/flashplayer/
I hope this helps.
May 18, 2011 | YouTube Videos
I have HCL Beanstalk Desktop, Monitor - Samsung Syncmaster 794MG. I don't have a ups. I get frequent powercuts in here resulting in interrupted shutdown of the computer. Sometimes while playing a game...
You seem to have a corrupt display card. Is it on board or do you have a separate graphics card installed in your PC. Either way on restart graphics processor is not turning on. What does the Power and HDD indicator on the PC show during boot up. You could also have damaged the Hard Disk because of your abrupt shutdowns. You can open the side cover and try disconnecting the HDD power (Yellow, Black & Red ) cable and IDE ( 40 pin flat ribbon wire ) cable and try restarting. If your monitor starts up and shows BIOS page you have a faulty HDD. Also see if the processor fan is a working when you start the PC. If not you have a failed mother board. Are you getting the boot up RAM beep. If not before you do any of the above mentioned things Just pull out the RAM ( with PC unplugged ) and reinsert into the slot. It might get your PC working after all
Mar 08, 2011 | MSI Computers & Internet
I was using the computer for a short time, just reading news on the internet when it beeped three times and the monitor went blank and the mouse and keyboard also stopped working. I had to do a hard...
hi your cpu fan might be loose or your RAM open pc and make sure cpu fan is secure if its loose a little tighen it or your RAM might have popped out it can get very hot around RAM and sometimes it pops out ...hope this helps be carefull...bonnell
Sep 23, 2010 | Gateway FX7026 PC Desktop
My monitor went black, and the power switch just flashes.
is your CPU working properly? if that the case, your monitor is in need of a service.
reasons for why a monitor goes blank?
Reason 1: Wetness
The number one reason why computer monitors go blank is - wetness. Believe it or not, when your computer monitor is exposed to humid air, sometimes water can condense and accumulate in the monitor. This causes the monitor to malfunction and go blank. I've had this happen to my desktop PC at least three times before. What you need to do is to leave the monitor alone for some time and allow the water to evaporate. That usually solves the problem.
Reason 2: Faulty Graphics Card
The next reason why your computer monitor goes black is due to a faulty graphics card. The best way to detect this kind of problem is to connect up a new monitor to your PC, then check if you have a blank screen. If you continue to have a blank screen, then it's likely your video card is faulty.
Reason 3: Faulty RAM
This one is less obvious and less common, but it can happen. You might sometimes get bad RAM modules which prevent your PC from booting up even to the basic BIOS startup screen. To detect this kind of problem is more troublesome, you might need to remove those RAM modules and insert them into another computer.
Reason 4: Loose Connections
Another reason why your monitor goes blank is due to loose connections. The connection from the monitor to the mains is usually a culprit, as is the connection between the monitor and the video card. Check those connections before you declare your computer monitor as faulty.
Reason 5: A Short Circuit In The Motherboard
And the final reason why your computer monitor goes blank? It's possibly because of a short circuit in the motherboard. This is the most undesirable outcome of course, as you might have to replace your entire motherboard. However, it's possible that this can happen - so keep your fingers crossed and hope it doesn't happen to you.
try this.
please rate my solution.
have a nice day.
Jul 05, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
The W1907 goes blank when i turned the monitor off and then on
I would say don't turn off the monitor at the switch at all unless you are not going to use it for a long time. I just leave mine switched on and the power save blanks the screen if I am away from it for 20 minutes. I leave my PC switched on all the time as well. If I need to use it for any reason it takes ages for it to start up fully so it's more convenient to just leave it all going so it's ready when I need it. If away from the PC for a day or more switch it off but I keep going back to it all day and night so it's easier for me to leave both on all the time.
Jun 17, 2009 | HP w1907 LCD Monitor
Screen truns blank after starting up
Check the caps all eight and the 5v transistor it's seem like it braking down under a load (heat up and shut down)
Mar 11, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor goes blank less than a second after turning on.
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Jun 19, 2008 | Dell XPS 200 PC Desktop
Computers & Internet Logo
455 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
