Question about Uniden 2.4 GHz Cordless Phone System
Voic mail How do i check or reset voice mail - i just switced phone companies- its cable hookup. VM not working since the switch.
One Wire
  • 126 Answers
SOURCE: checking voice mail remotely
This may be a little late, you are probably home already, but here it is anyhow:
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a remote
location (when you are away from home, or from another room using a handset).
Additionally, you can turn On or Off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any
touch-tone telephone.
1) Call your telephone number and wait for the system to answer. If the answering system is
off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is off),
press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code" on page 25
or 54).
3) The answering system announces the current time and the number of messages stored in
memory. You hear "To play incoming messages, press zero-two. For help, press one-zero".
You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered within 2
seconds. You may select a command from the following chart:
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help Guidance
* For Repeat a Message function, press 0 then 1 within about four seconds to repeat
the previous message, or press 0 then 1 after about four seconds to repeat the
current message.
** For Memo Record and Greeting Message Record function, the first time you enter the
corresponding command, it starts the Recording function. If you want to stop the
recording, press 0 then 7 or 8.
5) After the command has finished, you hear intermittent beeps indicating that the system
is in the command waiting mode. You may enter another command at this time from the
chart above.
6) When you are finished, hang up to exit the system. The answering system automatically
returns to standby.
Posted on Jan 26, 2008
  • 65 Answers
SOURCE: voice mail is full do not know how to empty it
Many people confuse voice mail with answering machines. Most of the time if you have voicemail that is provided by your phone company you will hear a stuttered dial tone when you pic up the reciever. If this is what you hear you should call the service provider and they will explain how to retreive your messages and delete the old ones. Are you able to listen to you messages? If you have voice mail, you do not need the answering machine turned on on your phone.
Posted on Feb 02, 2008
SOURCE: voice mail message waiting light does not light
Press down the "find handset" button until the paging beep stops (about 5 seconds) and this will reset the indicator lights on the handsets.
Posted on Oct 03, 2008
SOURCE: i can't get the voice
On some older models, try pressing and holding the Find Headset button for five seconds; this clears the voice mail light.
Newer models are a little harder to clear. The suggestion I received from customer support was to call my own number, leave a short message in voice mail, access my voice mail and delete the message to clear the light.
Posted on Dec 04, 2008
  • 4 Answers
SOURCE: indicator light on Uniden exl8650
I work for uniden, and yes it does.
Posted on Mar 07, 2009
I forgot how to clear the stored voice mails
Les,
If you want to delete the actual voice mails, you have to go through your phone company (using their keypad commands) since voice mail is only accessible through your phone (but the voice mail messages are stored through your phone company provider).
Info from the Uniden DECT 6.0 6035 Manual:
Using the Voice Mail Service If you subscribe to a voice mail service, you can use your phone to access your voice mailbox. The new message LED on the handset ?ashes and VM appears in the handset display whenever you have messages waiting in yourvoice mailbox. When you subscribe to the service, your voice mail provider provides you with the access number and the required voice mail signaling tone. You can use your phonebook to store the access number.
Resetting the Voice Message Waiting Indicator
When you receive a new voice mail message, the new message LED on the top of the handset ?ashes and
appears in the handset display. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state. To reset, press and hold [?nd hs] on the base for ?ve seconds. A beep sounds and the message alert tone is reset.
Here is the manual:
Uniden 6035 1 Owner Manual
Nov 01, 2015 | Uniden DECT 6.0 Cordless Telephone...
How do I clear phone of a new voice mail message?
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jul 20, 2014 | Panasonic Lands Phones
Voice mail not working
The Voice Mail system provides the voice mail service based on the existing network. When a call is transferred to the VM system, the system asks the calling party to leave a message for the called party when the called party is busy, powered off, or out of the service area. It provides voice mail, call prompt, and voice short message and email. By adopting VM service, operators' system put-through rate, service usage rate, customer satisfaction, and revenue can be improved.
Aug 20, 2013 | Panasonic KXDT321 Phone
No voice mail was set up on this pnone yet it says new voice mail
It sounds like you recently switched phones. Even though the phone may not have been set up with VM yet, your network is sending the VM notification to it. You should be able to "Reset Voicemail Count" however I can't tell you where to find it because I don't know the model. Please let me know if I can help more.
If this was helpful, please rank me a 4.
Mar 09, 2011 | Cell Phones
My uniden cordless phone says vm on the screen. What does that mean?
It is voice mail and some time you checked voice mail on your cordless phone but light will keep flashing that you need to check your voice mail. if it does not fixed then You need to also delete the voice mail from any voip device and it should turn off blinking lights and will clear vm message.
Feb 17, 2010 | Uniden Lands Phones
I have inherited a KX-T7633 and cannot access voice mail. the previous employee left the company. Can you help?
It depends on what you mean by "can't access". The Panasonic voice mail system is accessed by dialing the VM access code, sometimes 500 or 165, from the phone you want to use. If you, for example, are extension 105, and it has a voice mail box, the lady will either tell you how many messages you have, or ask for a password. If that's how you can't access VM because you don't have a password, then the password can be reset from mailbox 999, the system administrator's mailbox.
There are two passwords YOU ABSOLUTELY HAVE TO HAVE. If you don't know the passwords to 998 and 999, then you will have to get them from the original installer, or call your Panasonic dealer. Alternatively, if you have the VM maintenance console password, you can reset 998 and 999's password.
Carl
Jan 27, 2010 | Panasonic KX-T7633 Corded Phone
Want to turn off voicemail Don't know codes
To turn off voice mail please dial ##002#, this would do the trick.
Regards
Oct 13, 2009 | RCA 25450 4-Line Extended Range Multi...
Call Waiting
THere are two answers to you question, depending on certain options and conditions.
First, where is the voice mail and where is the call waiting coming from?
1. If Voice Mail (VM) is located in the central office and you have a destination for call forward BUSY/NO ANSWER it will go to CO VM.
2. If Voice Mail on premise (Partner Mail), and you have CF BUSY/NO ANSWER set on your phone, it will go to voice mail....IF the call waiting is coming from another line. The CF and ring count is set in Partner system programming.
3. If you have call waiting coming on the same phone line and don't have CO VM, then you have no voice mail.
My CO codes for VM are 72# for Call Forwarding and *92 for CF Busy.
As Always, YMMV
Carl
Sep 14, 2008 | Avaya Partner 34B Corded Phone
RCA Model 25204 2 line speakerphone corded with call waiting caller ID
As bsmither said, how voice mail is accessed is very dependent on your phone company and how they've set things up. They would be the best place to ask about any problems you're having there.
As for programming the voice mail buttons on the 25204, I was confused by that one as well until I finally figured it out. Specializations aside, they're just speed dial buttons, and are programmed in exactly the same way as the ones along the right side of the phone. RCA could have documented that detail better than they did.
In my case, with Vonage, I just programmed the buttons with the numbers for the lines that they're associated with. When they dial and I'm connected to the voice mail system, I'm prompted for my VM password, which I then enter manually.
Jan 30, 2008 | RCA 25414RE3 Corded Phone
Misplaced manuel, how do you set voice mail to come on after 3 rings
Go to http://www.rca4business.com/products/pc/viewPrd.asp?idcategory=11&idproduct=11 and click on the Download Instruction Book link.
Jul 19, 2007 | RCA 25414RE3 Corded Phone
Uniden 2.4 GHz Cordless Phone System Logo
21 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
