Question about Nokia 3230 Cellular Phone
Memory card is not working.
I have nokia 3230, I purchased new memory card of 1 GB. I can see the containts in memory card, but I cant copy, or create or save images or sounds in that. Even trying to capture the images from camera, not getting stored in Memory card. Every time I am getting error “Retry or data will be lost”, Kindly suggest the solution for it.
Bro format mmc
Posted on Sep 05, 2008
I have a memory card from my nokia 3230,.. im on transferring files from my USB device to my memory card... while the transferring is on process, my USB cable interrupt it.. Then, the memory card and USB...
your memory card is not usable anymore, because during the transfer process it should be not interrupted because this will really lead to hardware damage. as for now we can do nothing about it but just to purchase a new memory card.
Jul 11, 2011 | Computers & Internet
I cant save my messages to my memory card
In nokia 3230 you cannot save the messages to memory card.You dont have option in this mobile itself.
Dont worry, please download MSV driveE software in your mobile phone so that messages can been directly saved in MMC.
Download the MSV software from below website
http://www.ziddu.com/download/8277766/MsvDriveE.jpg.html
After you downloaded it, you’ll find that you save file named MsvDriveE.jpg. Don’t worry! You just downloaded the right file. Rename the extention *.jpg, and change it to *.sis. Then you’ll get MsvDriveE.sis then install it to your phones.
But in this feature it just saves the incoming messages to the memory card instead of saving it to phone memory to keep the phone memory unused.But you cannot read your messages.
To read your saved messages in PC please install a software called as FE explorer.
You can download FE explorer from below website
http://gallery.mobile9.com/f/1210278/
Using this FE explorer you can copy the messages in your inbox and you can paste in any of the folder in memory card.Then you can open the messages in your computer using Note Pad and read the messages.
To copy please follow the below steps,
1.Select inbox from the main page in FE explorer.
It shows the messages in Your inbox,sent item,saved messages also.
2.Copy it and Paste where ever you want to copy in E:/ drive(Memory card)
3.Then you can put your memory card in your PC and can open up the messages in Note Padfd6f18b.jpg Thank you
Aug 08, 2010 | Nokia 3230 Cellular Phone
After formating nokia 3230 memory card is locked autometically
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
May 13, 2010 | Nokia 3230
I couldnt access my memory card in mobile it can be formatted but cant copy files from pc
i think ur memory card is corrupted. u could low level format ur memory card. or there is an easier way. go for a new one
Jan 26, 2010 | Nokia 3230
How can I move all my files from my existing 1GB micro SD to my new 4 GB micro SD? I'm using Nokia N95.
You can try moving the contents of the 1 GB memory card in a new folder in the phone memory using a file explorer and after that you may remove the 1 GB card from the phone, insert the new card and move the files from phone memory to SD card. However, since there is a lot of data in the old card, moving the files to the phone memory is not recommended. The recommended way is to use a memory card reader on your PC, copy the contents from the old card to a location in your computer and then move them to the new card by simple copy/paste technique.
Please rate this solution in case you find it helpful, in case you need further support, do not rate the solution, leave a comment instead and I shall get back to you.
Aug 11, 2009 | Nokia N95 Cellular Phone
Sir i gave password for my nokia 3230 mmc memory card to protect against illegal use. but unfortunately i dont remember the password,so I am unable to use my memory card. please help me unlock it
Install and launch MMCPWD application. It will display some special characters including your password.
Option 2:
Locate mmcstore file. Install and launch System Explorer or FExplorer application. Go to c:\system\ and open (using unicode/hex editor) the mmcstore file. it will display your password. NOTE: you can also copy the mmcstore file to any folder of your phone memory, rename it to mmcstore.txt and open it without using any unicode/hex editor).
Option 3:
1. Open up fe explorer thingy.
2. Go to C:\system\ folder and locate a file called mmcStore. Scroll down till you find it.
3. Copy it to C:\nokia\others
4. Highlight it
5. Click options
6. FILE>RENAME
7. IT should turn blue: right click then write ".txt" (should look like "MMCSTORE.txt"
8. Try to open it, (that should be your password, if nothing happens then go to 9.)
9. Connect phone to pc
10. Open the file from C:\NOKIA\OTHERS\MMCSTORE
11. Copy the file to your desktop
12. Open with Windows notepad/ microsoft word
13. That should be your password
May 06, 2009 | Nokia 3230
Corrupted memory card
3230 memory card corrupted
Nov 24, 2008 | Nokia 3230 Cellular Phone
Iwant to expand the memory of the nokia 3230
It support up to 2 GB Memory card.
You can visit this link for confirmation.
I hope it will help you.
Nov 15, 2008 | Nokia 3230 Cellular Phone
Wall paper Settings
The 3230 isn't able to show you what memory is actually being used, so it isn't giving you an accurate reading.
Do you have a memory card installed? Copy some files over to your memory card and try it that way.
Hope you solve your problem.
Mar 13, 2008 | Nokia 3230
Nokia 3230 mobile camera problem
change memory card and try with a new memory card.
Aug 25, 2007 | Nokia 3230
Nokia 3230 Cellular Phone Logo
85 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
