Question about Indesit WA 115 Front Load Washer
Indesit washing machine mca
I no this sounds a strange request but how can i wire up the machine to be on permanant spin cycle. Or can u tell me which ires live , neutral and which creates the permanant spin cycle. Thanks
  • 76 Answers
Wow this is strange,but you can do it.
You would have to dis Connect the timer for a start.
Then trace the wires from the spin cycle to the motor.
Connect that strait up to each other,you can put a on off switch in to control it other wise you should plug it in and out.
Hope you get it right.
Regards.
Wouter...
Posted on Sep 11, 2008
My kenmore ad 80 series washing machine won't spin
The lid switch is probably out. Bypass it and see if she magically comes to life. Their are 3 wires to the lid switch 2 of which are live wires. Jumper them 2 live wires and see if she runs in spin.
My home video: Washer won't spin It's a doozy
Jul 20, 2012 | Kenmore Washing Machines
I own a Fridgiaire washer Model# FXW223LB56. The machine will not spin on the final spin cycle and leaves the clothes soaking wet. Tub does drain but does not spin. Sounds like it's engaging but still...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
=- =- =0
Sep 10, 2011 | Frigidaire Washing Machines
At the end of the cycle prior to spinning the washer sometimes doesn,t start to spin, it just makes sounds like it,s trying to spin but won,t catch. If I open and close the lid it begins it,s proper cycle....
The timer is not allowing a cycle stop for the neutral pack to drop. Replace the timer and you should be in good shape. The whistling sound is likely something in the pump.
Kelly
Mar 21, 2011 | Whirlpool Washing Machines
In the permanent press cycle only the spin cycle isn't spinning enough. Clothes are extremely wet must run another spin to get out the water.
Thts right....the permanent press cycle my only spin at 600rpm because the clothes would be creased otherwise. Hence the PP cycle.
Some machines lock the PP cycle to low spin RPM. Some allow you to over ride this setting. Check your machine and have a play with the controls. Some PP clothing should even be drip dry to retain the premanent press in the garment. If you want PP then low spin is needed. fast spin will not be a PP cycle...
Aug 07, 2010 | Washing Machines
GE washer top load makes "chunking sound" in agitate cycle
unplug the machine- you should be able to turn the agitator by hand- turn it by hand- if you hear a noise, get a butter knife, or some other flat, thin item and move it around under the edge of the agitator, there may be a small object jammed under it! if so, then remove it, and enjoy the quiet! the agitators in many machines are removable- but you have to un-screw the top retainer, then use tool to loosen the agitator from the shaft- which can be a bit of a chore!! the older the machine, the more difficult! may want to check if your machine is level- but the spin cycle would tell you more! if it 'walks' across the room on spin, it's really out of level!!
good luck!
Oct 04, 2009 | GE WHSB8000B Top Load Washer
Strange growling sounds on rinse and spin cycle
I would check the motor control board located near the floor on the right side for burnt components. The motor is a 3 phase unit and if one of the phases are working the motor will growl and won't be able to supply the proper torque.
See www.neptunehelp.com for disassembly photos and for more info on the faulty door latch wax motor.
Jan 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Duet HT has Knock in Spin cycle
well id be leary myself and honestly not at the machine but the tech(s) that are looking at it. i would put back in for another call request a different company if possible.Theres probably 7-8 authorized Whirlpool service Companies in my area alone. acn demand that the tech call the Technical assistance line if unsure of problem.I cant see telling a cust "normal noise don't worry about". these units spin very quietly.On a side note they were installed correctly??? strange to get 2 with came problem..
Mar 13, 2008 | Whirlpool GHW9400 Duet Washer
Kenmore washer - water is emptying from tub but clothes are not spinning dry
replace door switch.If the computer thinks the door is open, it will not fast spin as a safety precaution.
Feb 27, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Open Questions:
See all Indesit WA 115 Front Load Washer Questions
Indesit WA 115 Front Load Washer Logo
66 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
