Question about DeLonghi Pinguino PACL90 Portable Air Conditioner
Help please...blinking FE but E does not have top line to the right
Hi, I have a DeLnghi Pinguino Pac L90. I woke up and it is off but flashing two characters as described above. It is blinking FE but the E does not have the top line to the right. I can not find my manual and can't seem to find this particular manual on line. I have two cats and it is will be too hot today when I go to work. I hope you just may be on line right now? Thank you!!!!
  • DeLonghi Master
  • 19,396 Answers
Check that the error is not Ft, that means Full Tank.
Drain the internal safety tank through the drain hoses by opening the cover on the rear of the appliance.
there you will find two drain hoses,pull them out, take off the caps, and let all the water flow out.
When finish draining the water place the caps and the hoses back in place.
You also need to clean the filters and let them dry before putting them back in place.
Here is the user manual, see self diagnosis section.
Posted on Sep 05, 2008
How to conect my air condittinion pinguino pca L90
This really Expensive AC quite on me. The fan works great, I hear the Compressor turn on and it still doesnt blow cold air. Should I flip out?
May 14, 2009 | DeLonghi Pinguino PAC-700T Air Conditioner
DeLonghi PAC L90
I would venture that your unit requires cleaning of the filters or at worst it may be a fan motor. Initially, try removing the front panel holding the filters and clean it as instructed in the user's manual. Should this not be corrective, i would suggest to seek the services of a qualified professional
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 24, 2008 | DeLonghi PAC C100 Air Conditioner
PINGUINO PAC-L90 PORTABLE AIRCONDITIONER
yes we charge freon if it leaks out, but we fix the leak first. but also it may have electrical problem only, better get it check with a technician
May 09, 2009 | DeLonghi Pinguino PACL90 Portable Air...
PAC-L90 NOT BLOWING COLD AIR . DO YOU HAVE TO ADD ANY R22 OR FREEON TO THESE SYSTEMS
they all take refrigerant but there are other things like dirty filter or condensor coils that will cause the same problem
How do i empty the tank
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, fe shows in the display how do you empty the tank.
This is the user manual site.
scroll down to the diagram on page 16 and they describe how to empty the water from the system
http://www.delonghiusa.com/manuals/PACL90.pdf
To empty the tank on the rear of the
appliance.
Pull out the 2 drain hoses, take off the caps
When all the water has been drained, place
the caps back on the hoses and put the
hoses back inside.
Clean the filters and dry thoroughly before
putting them back.
Remember to give me a solved rating before you log off!
Thank You Huuum
Aug 12, 2008 | DeLonghi Pinguino PACL90 Portable Air...
PAC L90 water tank capacity
when tank is full you will get the letters FE will signal a FULL TANK
(The tank is full)
You have it setup to constantly drain GOOD.
Should you should not plug the drain hoses to get colder air.
Do let it drain . It is more convenient!
If the unit is the proper BTU for the square footage of the area to be cooled it will be cold!
If the tank gets full you will not get cool air?
Please remember to leave a rating before you go!
Thank you
Jul 28, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Jun 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi Pac L90
Hoses for proper connection should have been included with your purchase. Without the hoses the set-up can not be done satisfactory. One is for fresh air supply and the other is the hot air exit hose. These are normally vented out a window. Check with the dealer where you perchased the unit from. If from a private individual contact them.
May 21, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Delonghi Pinguino PAC L90 is flashing Lt on the display.
It is in Frost Prevention mode - the appliance will start up again automatically once finished.
Nov 18, 2007 | DeLonghi Pinguino PACL90 Portable Air...
Heating & Cooling Logo
488 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
