Question about JVC AV-27750 27" TV
Jvc hd 52g787 my position adjustment in my menu will not highlight so i can adjust picture over to the left. help please
    Top Expert:
  • JVC Master
  • 76,115 Answers
Hello
Just make the picture status button on the remote control and get the display setting to its factory mode.
The VIDEO STATUS button gives you a choice of three TV picture display settings, including a
display of your own preferences.
Standard - Resets the picture display to the factory settings.
Dynamic - Heightens contrast.
Theater - Gives a rich, film-like look to video. (AV-27D303, AV-27D203 and AV-20D303 only)
Sports - When you watch a sports program. (AV-27330, AV-27320 and AV-27S33 only)
Press the VIDEO STATUS button repetedly to get these choices.
Posted on Aug 13, 2011
  • The Knight
    The Knight Aug 13, 2011
    If this cannot rectify the problem of your TV, the power regulator section in the circuit board should be checked for over secondary voltage. If there is voltage more than normal [DC regulated voltage, not the Line voltage of your hose]; picture will bloom out and some pard at the edges will be invisible.
SOURCE:
JVC HD-56FN97 when turned on blue light is solid,red ligt blinks a few times and goes out. My picture is very dark despite adjustments I make in the menu, any help or feed back apreciated.
The set does use a lamp for a light source and average life is 2 years or 2000 hours---many lamps before they actually fail get to be darker.
Dec 04, 2012 | JVC HD-56FN97 56" Television
Tv is about 6 years old hd-ila 56g657 have replaced lamp 3 times over that time but the picture started to get darker and darker.the last time i replaced the lamp it did very little good and the ptcture...
you cleaned the reflector glass, then tried to make the manual adjustment of the color to have good convergence. you can do the adjustment in the menu set up. if can not get with adjustment, their might be a problem in the convergence circuit board.a bad convergence ic or resistor.
Nov 18, 2012 | JVC HD-56FB97 HDTV
Have a jvc hd-52g787 with no remote how do i start autotuner using the front panel buttons?
Your gunna have to buy a universal remote, program your model number into the reomote and you should be good to go.
Aug 12, 2011 | JVC HD-52G787 52" Projection Television
Jvc hd-61Z786 REAR PROJECTION TV . is dark. replaced the lamp. did not help much
all u have to do is to
Reset Picture and Sound Adjustments
1.Press the "Menu" button.
2. Press the "CH+" or "CH-" button to "Reset" listed on the display.
3. Press the "Volume+" or "Volume-" buttons to move left or right to enter your Reset selection. The Reset will reset all of your picture adjustments, including the color, brightness and tint to the default settings. Reset also resets your sound adjustments to the default settings, like the balance, bass and treble.
4. Press the "Menu" button to complete the resetting process
Feb 23, 2011 | JVC HD-61Z786 61" Rear Projection HDTV
No tv picture
Call a professional and have the V setup again.
A1 Elmbrook Electronics Inc. EEI.Vstore.ca [email protected]
Mar 30, 2010 | JVC HD-52G787 52" Projection Television
Needs bulb
Just under $200 for the JVC hd-52g787
CLICK HERE to see the lamp and price.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 01, 2009 | JVC HD-52G787 52" Projection Television
The sound went out on my jvc hidef tv
Reset- resets all picture adjustments (tint, color, picture, bright, detail, color temperature, dig.
noise clear, Color Management and Dynamic Gamma) at once to the default settings.
Press the MENU button
arrow To RESET
arrow To enter
The onscreen menu disappears for a moment,
and then the settings are reset to the default
setting for all the picture/audio adjustments.
Press the MENU button when finished
Here is a LINK to download your owners manual
Feb 12, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Televison & Video Logo
220 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
