Question about Samsung PS42S5H 42 in. HD-Ready Plasma Television
Samsung ps42s5h Can you help,I turned my tv on one day and only sound came out, the screen was blank then after about 5 min while i was checking the connections it started clicking as if it was turning itself off and on, so i turned it off completely and sort professional help.A tech person told me the y lower buffer had gone on inspection that was correct, a hole was in the board, so thats been changed but when i turn the tv on it constantly clicks its self as if its trying to start up just as it did when i first encountered the original problem, is there something to reset or gone?
IF YOU ONLY CHANGED THE BUFFER, YOU SHOULD CHANGE THE Y-MAIN ALSO, THAT BUFFER TAKES OUT THE Y-MAIN AND VISA-VERSA
Posted on Sep 05, 2008
I turn my tv on the picture and sound all work and after about 20min the picture goes to a black screen and I still have my sound. I turned the tv off wait about 5 min turn it back on the picture come on...
If you have electronics experience - check the power supply and make sure you are getting the correct voltage to your inverter boards and main av board - also do you see any movement on the screen take a flashlight and shine on the screen - if you can see a dark image on the screen check inverter boards and power first.
thanks,
michael
Mar 21, 2011 | Element Electronics FLX3210 32 in. LCD TV
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
Samsungh LA40B530 No picture but sound
try connecting tv to cable direct also try unplugging both converter and tv for wile like 5 mins plug both back in see if tv and converter sync, but if otherwise then
The ysus board is the most common reason.
you can try websites on ebay.com to buy parts for replacement...
Aug 03, 2010 | Samsung LA40B530 40 in. HD-Ready TV
My Sylvania flat screen sound keeps going off
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/ The most probable cause is with its audio output IC itself; overheats.
May 11, 2017 | Sylvania Televison & Video
My tv screen keeps flickering on and off
  1. Need Model # of set and the brand so I know if its a plasma, LCD, or CRT set keep me posted
Aug 23, 2009 | Televison & Video
My tv turns on u can watch it for about 5 mins then the picture will flash on and of for about 3 mins then the screen will go blank but u can still here the program u were watching
Sounds like bad capacitors on the power supply board. Locate power supply board, remove it carefully and check capacitors on an esr meter.
Aug 21, 2009 | Televison & Video
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Blank screen on my cell, Help!!!!!!!
If both screens are blank: Check the ribbon cable running from the bottom of the phone to the top, apperantly this is a common problem with these. You will need a t6 screwdriver. Part is about 8 bucks on e-bay.
Feb 26, 2008 | Cell Phones
RCA 20f510td
Sounds like a thermal breakdown of a componet. it could be in the main power supply regulaor supply or even a bad capacitor in the power or sweep supply. In some cases Zener diodes can break down and change values after warm up. In some cases also bad solder connections in the highvoltage section, or the power supply can cause this problem. It is a hard call without being able to look at the set. Just a few leads on where to go first. most likly a combo unit, such as this one , would cost you more then a new one these days. Good Luck PS Please dont forget to rate this thread.
Dec 09, 2006 | RCA 20F510TD 20 in. TV/DVD Combo
Samsung PS42S5H 42 in. HD-Ready Plasma Television Logo
320 people viewed this question
Jerry Greenberg
Jerry Greenberg
