Question about NAD C372 Amplifier
Nad c372 prob
Hi There trying to turn on my nad 372 orange light comes on sound for about 10 secs then it trips to red.
Any ideas?
  • Scott Frye
    Scott Frye May 11, 2010
    If solution #1 didnt help then the amp needs a tech to fix it.
  • 4,234 Answers
The unit is detecting a problem and shutting down in what is usually called "protect" mode. Look for bad connections on the board near the voltage regulators.
Dan
Posted on Sep 09, 2008
My NAD C372 integrated amp was working normally everyday. One day, on pushing in the "Power On" button, it did not light up. No response at all.
It could be anything from a blown fuse from a power surge to a shorted capacitor ijn the power supply. There are fuses in all amplifiers. Locate it and test it with an ohmmeter.
Dec 16, 2013 | NAD C372 Amplifier
How do I connect a cd player to both a tv and an audio amplifier so Ican play either Cd's or DVDs?
Does the TV have a line audio outpot (red and white jack)? If so feed the amplifier input from there.
Dec 23, 2012 | NAD C372 Amplifier
How do I connect a Mirage Omni s-10 Sub Woofer and a Parasound Model 2100 Pre Amp to the NAD C372 Amplifier?
You DO realize the preamp is duplicating stuff in the Nad C372, right? This Preamps adds nothing but PHONO connectivity and control. That's why they're called "preamps".
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-C372-Amps-manual/id/8043dj592/t/2/
http://www.retrevo.com/support/Mirage-OMNI-S10-Subwoofers-manual/id/14438ag918/t/2/
Model 2100 Picture and article:
Use the Sub Out pair on the Preamp (joined by an RCA Y-cable) for the Sub Input on the sub (duh):
http://www.hometheaterhifi.com/preamplifiers/362-a-secrets-preamplifier-and-power-amplifier-review.html?showall=1
Run RCA from the Preamp Main Out to the C372 Aux In to hear any sources attached to the preamp.
Or, if you don't NEED the preamp because you don't have a turntable,ditch the preamp and connect the sub using the speaker outputs on the NADS, according to the manual.
Mar 08, 2011 | NAD C372 Amplifier
I have and old NAD C 320 with all of a sudden started to produce a burning smell and smoke. It definitely was not overheating; I was not even using it at the time it was just turned on. Now onlt the red...
You'll need to take it in and have an electronics technician fix it. Sounds like it has popped a channel. Sometimes it just happens.
But you might also check your speaker wiring. Sometimes it gets frayed and shorts, which will strain the outputs and sometimes cause damage that doesn't immediately kill the output transistors.
This is not customer serviceable.
Steve Greenfield
Electronic Engineering Technician student
Electronic Technician 20+ years
CET Computers and Consumer Electronics
IPC-A-610D CIS Specialist
Feb 06, 2010 | NAD C372 Amplifier
Nad c372 problem with left speaker output
Hiya, did you try to swop the inputs as well and see if the problem swops. Try that as the input could also be low. If so try change the cable.
If not there try cleaning out the balance pot with switch cleaner (have to open to that and only you are comfortable).
If thats not there then likely an internal problem and will have to send it in.
Best of luck
Jul 14, 2009 | NAD C372 Amplifier
Right loudspeaker problem
Doesnt sound like the selector as it "sometimes" works. Redo the speaker connections on the back of the amp and speakers first. If it persists, swop the speakers and cables, if the problem swops, then it could be inside the speaker or the cable, if still the same then amp has dry joints/loose connections probably
Jun 24, 2009 | NAD C372 Amplifier
Excess clipping on nad 372 amp
อิอิ ขอบคุณคับ
May 24, 2009 | NAD C272 Amplifier
Sound through one channel
Only the right channel had a sound,the left channel is mute, whatever adjustment you did and whatever balancing you done nothigs happen,even you interchange the speakers. The problem is in the power amp. The STK IC there is busted already, it's better to change it with a new one so the performance become normal again.
Jun 14, 2008 | NAD C372 Amplifier
No power
Unplug for 20 min. and then plug in to try and see if it will come back on.
Nov 27, 2007 | NAD C372 Amplifier
NAD C372 Amplifier Logo
509 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
