Question about Garmin Nuvi 660 GPS Receiver
Speaker of garmin nuvi 660 doesn't work anymore
I also have the same problem with my nuvi. My internal speaker also doen't work anymore.
Today I opened the garmin with the intention to solder the speaker wires again. I thougt that the wires made a bad connection. But against my expectation the wires made a very good connection. So the conclusion is a broken speaker.
Now I need to replace the speaker. Can you tell me where I can find/order a similar speaker. For your information I come from Holland.
Best regards
  • 1 more comment
  • bruce24 Sep 06, 2008
    The headphones still work. Today I measured the resistance of the speaker between the + and -. This is approximate 1500kOhm. It varies when you tap on the speaker (goes from 1300 to 1800KOhm). In my eyes this means that the speaker is not totally broken. Please correct me of I am wrong.
    Jim do you know the specs of this speaker? If I have them I can try to look here in Holland to find a similar speaker.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Hi Bruce,
    On my repair bench at home, I have a Nuvi that is open. I will measure the speaker resistance for you and let you know what it should be.
    1500 ohms is high to me. The speaker should be somewhere between 8 ohms and 32 ohms, the same as a typical set of headphones. After all, the headphone jack is just a switch that switches the Nuvi's audio amp between the internal speaker and the headphones. You would want the impedance to be the same either way.
    If you want to do a quick test. Get a pair of alligator clip test leads. Connect them across the speaker leads of your Nuvi and the other ends onto the plug of your headphones or another speaker. If you hear sound and its good, then your Nuvi speaker is bad.
    The resistance should not change when you tap on it. The speaker voice coil is fixed to specific resistance. It's essentially a piece of wire wrapped in a coil. The resistance should not change.
    - Jim
  • SHARCNET-USA
    The Nuvi 660 uses the same speaker as a Nuvi 350. You might be able to locate an as-is unit on eBay and swap them out.
    I am in the process of finding a source for this speaker. It's a 1.3" Diameter speaker and held in place with adhesive.
    Do you hear sound with the headphones? if so, the speaker is bad.
    - Jim
  • Garmin Master
  • 2,130 Answers
Bruce,
I measured a speaker on a Nuvi that I had opened up on my repair bench. It measured 7.8 ohm. I'm pretty confident that your speaker is bad.
- Jim
Posted on Sep 08, 2008
  • SHARCNET-USA
    SHARCNET-USA Sep 08, 2008
    Thew Nuvi 660 uses the same speaker as the nuvi 350. It's held in with adhesive.
    -Jim
  • SHARCNET-USA
    SHARCNET-USA Sep 09, 2008
    Bruce,
    I have found a substitute.
    email me at ks3r at sharc dot net
    - Jim
Where can I find an internal speaker for a Garmin Nuvi 660
Hi
Depends which country you are in but i would try
radio shack, maplin, farnell or even have a look on ebay.
Please dont forget to vote if you liked my answer
many thanks
Feb 13, 2011 | Garmin Nuvi 660 GPS Receiver
Nuvi 660 internal speaker quit working and freezes sometimes on a street-- what do I do? Very recent problem.... at first I thought it was becasue it is overly cloudy here recently and maybe it couldn't...
Open the the antenna and look on the back. There is a small reset button. Push that button to reboot the software. This should clear up the problem.
Feb 25, 2010 | Garmin Nuvi 660 GPS Receiver
INTERNAL SPEAKER NOT WORKING GARMEN 660
The garbled voice has nothing to do with the map update. You internal speaker is defective. Please see this link to see more info on this problem.
http://www.sharc.net/gps_audio_repair.htm
- Jim
Sep 04, 2009 | Garmin Nuvi 660 GPS Receiver
No sound from Garmin nuvi 760 by any method
Sounds like your speaker went south. Since your fm transmitter is working I'll be your earphone jack is too. So you could always use an earphone. Only other option is a speaker replacement.
Dec 20, 2008 | Garmin Nuvi 660 GPS Receiver
Audio gone from my gps garmin nuvi 660
If you can hear audio through the headphone jack but not the internal speaker jack, then the speaker is bad.
This is a problem I have seen many times before. I will be posting an article soon on how to replace the internal speaker, however this is not a repair that just anyone can do.
You have to have skills in dissassembly & soldering.
- Jim
Jun 09, 2008 | Garmin Nuvi 660 GPS Receiver
Garmen nuvi 660
- Jim
Mar 21, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
1,201 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
