Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
No Appearance of external hard drive or symbol on My Computer
My Computer does not recognise external hard drive though I have connected directly to USB ports.
  • 2 more comments
  • pet3rnD13 Sep 09, 2008
    I have the exact same problem, the red light is on. I plugged it in directly but my computer, and other computers do no realize that my harddrive is plugged in at all, any help would be appreciated. The blue light does not go on
  • bwhicks Sep 15, 2008
    red light is on, but my PC doesn't recognize the device
  • ddotkalana Sep 17, 2008
    computer won't recognize hard drive-also, no c/d with h/d
  • SarahT3 Oct 11, 2008
    I have a SimpleTech Signature mini that is no longer recognized by my macbook or any of the 8 iMacs I tried to use it with.  Some forums say I can open the case and move the IDE, but I'm not sure what that is or how to do it. Any directions would be appreciated!
Solution is found. Removed hard disc Cover and inside connecting device to hard Disc. A new hard disc cover with with internal connector to hard disc solved the problem. Warranty would not work. but with $ 15 , I solved the problem
Posted on Sep 22, 2008
  • 661 Answers
Hese drive do not usually come partitioned and formatted (as different systems need different formatting)
to do this you need to go into logical drive management to partition the drive. (right click on my computer, select Manage then when the mangement screen comes up select logical drive manager, you should then be able to see your unpartitioned drive which you should then be able to partition and format)
if drive is not detected, remember that these devices need "powered" USB ports, which makes use on some laptops and some ports on PCs difficult as some ports are "low powered" ports, which means the drive can not draw enough current.
this can be resolved by using a "powered" USB hub, to supply the extra power.
My WD elements 1.3 TB external hardisk. It gives a buzz when connected and is not recognised by windows
It sounds like the HDD inside is dead. The USB interface may have an issue but usually clicking or buzzing is HDD failure. If you have a desktop you can try removing the hard drive from the external case and connecting it directly to the computer using a SATA cable.
Jun 19, 2016 | Western Digital Wd Elements Se 1tb...
Iomage macmini 1TB not recognised in disk utilities
Check cable. Try different cable. Try different ports you connect the Iomega with the computer with en on the Iomega itself.
Dec 17, 2011 | Iomega MiniMax Desktop - Hard drive - 500...
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though...
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though the drive is beeping
Aug 09, 2010 | Iomega Silver Series 320GB 3.5 External -...
My external drive turns on but it just makes a low pitch ticking sound.yellow light does not go on and computer does not recognise it can i recover my music a dj...anything helps
you can open your external drive and connect it directly to your computers IDE/SATA connectors and get in contact with the drive.
This only helps if the external drives circuit board is malfunktioning
and the drive itself is intact.
Its worth trying!!! if this helped, Please vote!
May 14, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
My computer is failing to recognise it, therefore I cannot access all my files. My computer started by warning me that the external hard drive has malfunctioned, then it would say it cannot recognise it....
Too Bad.
do this
take apart the hard drive enclosure. and try to connect the hard drive direct to the computer, if you can't do this, try with another adapter, if this fails your HD is Die. sorry
Feb 22, 2010 | Buffalo Technology DriveStation HD-HC500U2...
External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Sep 17, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Windows XP won't recognise LaCie 320g Rugged Hard drive
Based on windows you should go to the control panel, system,administrative tools, computer management and then select disk management.
If you drive shows up here and says healthy then you may just need to add a drive letter.
That can be done from where you are just right click on the drive and use the change drive letters paths option and use the one that windows offers you.
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Aug 01, 2009 | LaCie Rugged All-Terrain (301017) Hard...
Drive manager is grey and says that no drive is attatched.
You need to get a Seagate Harddisk Utility software to check the disk intergrity.
Although hardware issues like can sometimes be very difficult to fix due to the impact on a volatile component on the harddisk which are most times not replaceable
Apr 06, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Corrupt External Hard drive
I have a 250 g I moved all my pictures from my pc to it and now the hard drive will not open. It is nearly full. It acts like there are no files on it. What should I do, unplug it?, restart the pc, plug it into another usb port on the of my pictures are gone!!!!!..........RB
Mar 23, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
188 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
