Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Hi claire64 - Usually when "PAU" displays on the screens, it indicates that the unit thinks that the door is not securely latch when you started the cycle, or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit and resume cycle. If fault reoccurs, then it typically means that the unit either has a faulty door latch assembly or a communication error from the control board. Since there are cost differences in parts, it is always a good idea to have a service tech properly diagnose your appliance.
