Question about Doro Lands Phones
Phone is not charging, although green lights are on the base unit. I believe it may be the battery in the hand set but i cannot purchase one.
  • m_shakespear Sep 06, 2008
    Do y ou have a name of where to obtain this battery in the
    UK please? Thank you.
    President:
  • 1,263 Answers
If the battery is no longer charging and you can't seem to find one try the battery patrol. it is a store that handles all kinds even the rare hard to find. this should do the trick..
Posted on Sep 05, 2008
I have a vetch base of cs6619 and have ordered and received a new hand set Cs 6609 and can not get it registered although it has been charging foe 2 days. Please advise.
Sometimes you have to start from scratch. Remove the battery from all the portable units (including the one at the base station). Then start by setting up the base station.
You might try less drastic steps that are similar if you don't want to lose your directories.
Mar 05, 2015 | Vtech DECT 6.0 Digital Cordless Phone
How to return product KX-TG9333T purchased Premium Store.com. Item is same as already have. Thought it would be an upgrade.
The hand set never worked since I bought it. All other hand sets work as well as the base. I would like you to send "free of charge" a replacement hand set as well as the base for the hand set Hand set which never worked has #OGBXBO61363 UNDER THE BATTERY COVER. wE TRYED REPLACING BATTERIES SWITCHING BASES ETC.
Oct 17, 2011 | Panasonic KX-TG9333T Trio Cordless Phone
My phone stop the ring
This phone unit it is a cordless phone hand set unit phone,it is a home land line base phone wright?Yes? Did u tries ring high ring low on the phone hand set functions up and down of the phone itself have a ring functions so u make sure is it not the phone unit functions itself.Did u try other phone unit on that phone land line to make sure it is not the land line phone line problems.U can tries take the corless hand set nocking it on a hard surface lightly a couples times.This could clean some dust and dirt loosen or stuck function buttons.The cordless phone hand set battery it is charging?Yes? Phone might have a weak or dying or a dead litium battery.Tries the phone unit itself unplug/replug it back like about and hour later for phone unit to reboot itself.
Oct 04, 2011 | Lands Phones
The in use/charge indictor light does'nt come on when i put phone on it. I just brought a new battery.
Check your connections on hand set and base. Wiggle the handset on base to see if handset starts charging... If it does.. clean your connections or you have loose solder connections either in hand set or Base Unit.. Give that a try..
Chris
Sep 03, 2011 | Uniden Cordless Phone
I have just inherated the at&t e5634b phone system. I have replaced the batteries in the hand sets. As per the manual I have de-registered each hand set. The problem is that when I register the...
This problem can be caused by the following, A bad battery, (which you say you are all new). A full base memory and a Faulty main base unit
This main base unit can only expand to four handsets and no more. If the base unit has been reset then the assigned numbers for each handset would begin with " handset 1" if they show any other number when reset then it would not have been reset..To re-set main base you will have to
De-Register All Handsets
Unplug the power supply from the base unit then Remove all handsets from the charge cradles and base then Press and hold the PAGE button on the base.
Plug in the power supply again while pressing the PAGE button, Continue pressing PAGE until the IN USE and CHARGING indicators are lit. (this could take up to 10 seconds)
Release the PAGE button All Handsets will display "enter base id".
If this does not solve your problem then you will have to replace the main base
Apr 20, 2017 | AT&T E5634B Phone System w/ Caller ID
No dial tone on hand set battery is new lights up
Make sure your connection to the phone jack is secure.
Use another wired phone to make sure connection is good to your phone.
Secure connection in back of phone, and plug it in. The base MUST have power to transmit the signal to the handset even if the handset has a fresh charge.
Although the handset is normally linked to the bases, check to make sure via the instructions. To determine if the base recognizes the handset, press the "LOCATE HANDSET" button.
If the hadset responds, the links is there.
Hope this helps
good luck and don't forget to vote!!!
Sep 27, 2010 | Panasonic KX-TG2356 Cordless Phone
Cordless phone red light blinking no dail tone all of this happened after a breif power outage today
You have not mentioned the model but it is for sure that your phone inter communication has failed. Hence the base and the hand set is not locking on. Remove off all the leads and clean the base terminal charging points. open the hand set and reset the battery, dry off any residue of water moisture on the front panel of the hand set. now connect back and lock it in to see if the set latches. If not check if the power outage had caused a failure in the base unit DC input. check the area for +5 volt to processor , optocoupler and sub circuits. also checck the battery of your hand set for low voltage as it would have gone below the threshold level of charging. Test the voltage, if not replace the battery and set . it must work then. Helpful? Good day
Jul 22, 2010 | Lands Phones
Plantronics CS55 requires lifting handset on phone
Please note that your hand receiver has to be off the hook when using the headset.
This is correct, additionally you can use a handset lifter accessory, such as the HL1 or HL10.
Subscribing Headset to Base:
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
7. If this procedure does not resolve your issue to try a system reset.
May 28, 2009 | Plantronics CS55 Wireless Headset
Sony SPP-A946 base unit intermittently charges the hand set.
Clean the contacts on the handset and base that charge the battery.
AL
Mar 17, 2009 | Sony SPP A946 Cordless Phone
Samsung wep 150
then internal battery is dead sir
its clear
Jun 16, 2008 | Samsung WEP-150 Wireless Headset
Lands Phones Logo
428 people viewed this question
Top Doro Lands Phones Experts
castletech
castletech
Greg Cann
Greg Cann
Gene Tuck
Are you a Doro Lands Phone Expert? Answer questions, earn points and help others
