Question about Brother HL 2700CN Laser Printer
Hl 2700 cn 'no opc belt' error
Displays 'no opc belt' on power up, tried a different belt and it says the same.
Anyone got any ideas?
Thanks
You need to go into the settings and reset the counter once the new belt is in.
Posted on Oct 02, 2008
Error el1 after i've cleaned the printer with with compressed air can you help me ?
You will probably find there is some toner on the left hand edge of the OPC belt that interferes with the optical sensor reading the page rotation mark on the edge of the OPC. It may also have coated the optical sensor that is in front of the left hand edge of the OPC belt
Aug 12, 2013 | Brother HL 2700CN Laser Printer
Error message: replace opc belt
You will not like this but the OPC Belt (Organic Photo Conductor) needs to be replaced
They are not cheap.
to order this part call:
Southeast Digital Networks, Inc.
850-681-9528
Authorized Brother Elite Service Center.
Parts Center.
Mar 21, 2011 | Brother HL 2700CN Laser Printer
How do I reset the OPC belt on MFC-9420CN using the menu?
hl-2700" OPC Reset
press GO and "+" at same time
press "+" until OPC BELT appears
press "SET"
that will reset the counter on the expensive OPC.
Since the "MFC-9420CN" is build on the same chassis and engine, the "OPC belt reset for the 9420CN" is as follows:
Press 1 and 7 at the same time
Press 1 to reset the life counter.
Oct 20, 2010 | Brother MFC-9420CN All-In-One Laser...
I have a MFC-9420 CN that is giving me an "unable to print message" after I cleared a paper jam. I have turned it off and on several times, as that is the only help the user guide gives. I've read...
To reset on this machine you press the 3 and 9 together and scroll thru the options to reset. Unable to print without an error code doesn't tell me where your error might be.
Jan 28, 2010 | Brother MFC-9420CN All-In-One Laser...
TALLY GENICOM 8008
The SVC E9 error indicates a 'BELT MARKER' error.
This means the printer is not detecting the OPC Belt as rotating.
This error can be caused by a damaged OPC belt, you can check this by removing the OPC belt from the printer and look at the OPC belt it should have a smooth green coating if there is damage to this belt it may cause this error.
The error can also be caused by a damaged 'Transfer Belt' when the OPC belt has been removed from the printer look inside the printer where the OPC belt used to be located you should see a black belt towards the back of the printer, if this belt is damaged it can also cause the error.
Ensure the OPC Belt locates in the printer correctly.
If the OPC belt and Transfer belt look to be free from damage and a are located correctly in the printer you may have a faulty belt marker sensor or faulty OPC belt.
You can try substituting the OPC belt for an alternative one if you have this available to see if you can narrow the problem down to the sensor.
Jan 23, 2009 | TallyGenicom 8008 Laser Printer
NO OPC BELT on MFC-9420cn
The opc sensor is not sensing the belt. Open the front cover and remove all the toner trays. You will see the green OPC and the sensor is located in the left upper corner. Also open the top cover and remove the OPC. Clean the sensor with a soft bristle brush. Also make sure the OPC left side is free of toner deposits. This may incorrectly trigger the OPC position sensor. Hope this helps.
Jan 14, 2009 | Brother MFC-9420CN All-In-One Laser...
What is opc belt 2700 CN printer
the opc belt is the optical photo conductor belt in your printer. It is the bright green shiney belt you see when you remove a cartridge. You can access it through the top of your unit. You will see a cover where the paper comes out. Inside there are two green clips that push outward. These release the opc belt.
You can purchase a replacement opc belt from most good stationary and consumable suppliers, however, be ready for a shock. the price of the opc belt is almost as much as the unit is worth.
Dec 12, 2008 | Brother MFC-9420CN All-In-One Laser...
Error Message ('replace belt CG')
To reset page counter after replacing the OPC belt or FC Roller please follow the steps below:
  1. Power the printer on while holding down MENU/ENTER key
  2. Release the key when the display shows "Utility Menu Clear FC Roll"
  3. If you have replaced the FC Roller then select this option by pressing MENU/ENTER key. If you have replaced the OPC belt then change this option by pressing MEDIA key so the display changes to "Utility Menu Clear Belt CG".
  4. When one of these options is selected Press the MENU/ENTER key and the display will change to "Utility Menu Clear FC. Roll/ Clear Belt CG Not Execute". Press the MEDIA key and the display will change to "Execute"
  5. Press the MENU/ENTER key and after about 10 seconds the display will change to "Completed Clear FC. Roll / Belt CG"
  6. Now power the printer off and after waiting few seconds power it on again, after it's initial self-diagnosis the printer should now work normally without the error message.
Jul 12, 2007 | Tally T8006 Laser Printer
Error EE9 on Brother HL-2700CN
This is a sensor error (belt marker). Could be a piece of paper or such stuck in there from a previous jam futzing up the sensor. Are you comfortable poking around inside your printer?
Apr 24, 2007 | Brother HL 2700CN Laser Printer
Brother HL 2700CN Laser Printer Logo
652 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
