Question about Zebra LP 2844 Thermal Printer
TLP2844 prints but does not stop at perforated line resulting in Amber Light.
Printer is a network printer.
Was working fine before.
Tried to install driver again so as to access to printer directly from print server.
Unable to install driver successfully.
Deleted the 'faulty' printer and revert back to network printer (which was not deleted in the first place).
And problem occurs.
Printing ok but does not stop at perforated line hence causing green light to turn amber.
Tried to calibrate but "Out of Dump" message is not printed and problem still occurs.
  • miguel651 Oct 02, 2008
    I do have the problem that the first label it is ok. and the next do not con on the center.
2 Suggested Answers
  • 6 Answers
SOURCE: TLP2844 won't print
Hi David,
Default the printer so you have a green light.
Print a configuration label so you have the printer's settings.
Check the document you are trying to print.
If your "normal document" is using PCL, it won't print because you aren't speaking the printer's language.
Make sure you are using a Zebra driver and that the label/media settings match your printer. Look at your direct thermal/thermal transfer setting and your media length setting -- especially continuous vs. non-continuous.
Posted on Sep 25, 2008
  • 97 Answers
SOURCE: My Zebra 2844 light won't stay green
The amber light means the cover is not closed all the way. Something is preventing the cover from staying latched closed - it's releasing just enough to activate the cover-open sensor. Maybe check if you can see anything broken where the cover latches shut.
Not sure if this will be too helpful...
Posted on Apr 14, 2010
Losing half of top line when printing
Label definition in printer driver may need adjustment. Try calibrating printer, printer on solid green light, hold down feed key & release after light blinks 4 times, (blinks once, twice, three times then 4 times) Download the Zebra setup utility and use it to configure printer.
Sep 29, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Hi there! I work with Zebra TLP2844 through
If you are using Bartender, Make sure to use the Seagull Scientific Zebra Driver. The zebra driver works (but not properly) with bartender. Download the driver from Seagull Scientific site. You can also email bartender tech support, their contact details are available from the help screen on the main bartender design screen. I have always found them to be extremely knowledgeable and helpful.
Jul 01, 2009 | Zebra LP 2844 Thermal Printer
Zebra LP2824 not printing
Sounds like you put your printer into line mode. Line mode prints code so you can see what is sent to the printer to look for possible mistakes in the code.
To switch from line mode back to page mode.
  1. Turn printer off.
  2. Press and hold the feed button down. And switch printer on.
  3. Release the feed button when the LED flashes red.
  4. When the LED flashes green, press down the feed button.
  5. When the LED flashes amber release the feed button.
  6. Try printing now that the printer is back in page mode which is used for print your labels; line mode prints the labels code.
  7. Do this fast or else it wont work if you are slow.
Jan 13, 2009 | Zebra LP 2824 Printer
TLP2848Z blinking red, will not print
1: Is it a TLP2844 or a TLP2844Z.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
Calibration:
If its a TLP2844. Load media. Connect power.
Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
Calibration:
If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute)
Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
Dec 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP2844 print output very light
The problem was the power adapter appeared to be not original, instead of the required 20V this one produces 15V, found the original power adapter and the printout looks fine, darkness looks ok now.
Regards,
Edwin van Hek
Oct 14, 2008 | Zebra tlp2844ps Thermal Label Printer
TLP2844
Constant amber means -
1. The cover open sensor is active. Press top cover to close
and lock.
or
2. Printer has a syntax or command error. Check program
and resend print job.
Hope this helps
May 31, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Printing on the same line after a few pages printed
I first oiled the bar once more and while the printer was off, moved the head across the bar forcefully several times until it felt the ease to move. I then typed a document with numbers 1 to 10 each number typed two lines below the other and tried printing this document several times. This worked perfectly and the printer is now in order.
May 30, 2008 | Epson LX-300+ II Matrix Printer
Firmware corrupted? Only prints some random computer text
The printer is in line mode. Do the following to take it out of line mode:
Turn printer power off.
Hold the feed button while turning printer power on.
When the light starts flashing, release the feed button.
When the light starts flashing again, press and hold the feed button.
When the light turns steady amber, release the feed button.
When the light turns steady green, the mode is changed.
Verify the mode by printing and inspecting a status report.
This requires good timing and may take several tries. You'll know it worked if no labels are reeled out after you're done.
Apr 17, 2008 | Zebra LP 2844 Thermal Printer
TLP 2844 won't print barcodes
Apr 10, 2008 | Zebra LP 2844 Thermal Printer
Missing characters, missing print barcode lines
Hi, It's been a while since I worked on these, so I'll go out on a limb (as far as my rating goes) and say that the few times I've seen that happen usually results from a bad network card. Now you may not be using a network card, so if your not then I'm not really sure what would cause that to happen on the printer side. The environments that I've seen that happen in are with an AS400 and the network card just gave out. You most likely tried this, but you might want to make sure that the computer isn't using one driver for both printers. Good luck.
Aug 28, 2007 | IBM 4039 Model 16L Laser Printer
Zebra LP 2844 Thermal Printer Logo
75 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
lancer284
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
